Post Tue Nov 11, 2014 8:41 pm
Raw Video files not visible on samsung telly
I have been using serviio for some time (fantastic product!) and have always found answers on the forums. However, in this case I have spent quite some time trawling the boards and have not been able to find the answer to my issue.
I am running serviio 1.4.1.2 on ubuntu 14.04 successfully, but somehow I am not able to get raw digital video .dv to be viewed on my samsung 55C6000 telly. The raw dv files were uploaded using dvgrab and are simple home videos. On the telly when i browse to the videos folder i am not able to see any .dv files.
The serviio.log file run in debug mode does not detect the .dv files, there is no record of them in the detailed log file. Other files (.avi, MTS) I am able to view and play without any problems in the same directory as the dv files, so it is not a connection issue between the telly and serviio. ffmpeg is installed and appears to be working OK :
carmen@carmen-System-Product-Name:~$ ffmpeg -i ~/Videos/christmas2004.dv
ffmpeg version 1.2.6-7:1.2.6-1~trusty1 Copyright (c) 2000-2014 the FFmpeg developers
  built on Apr 26 2014 18:52:58 with gcc 4.8 (Ubuntu 4.8.2-19ubuntu1)
  configuration: --arch=amd64 --disable-stripping --enable-avresample --enable-pthreads --enable-runtime-cpudetect --extra-version='7:1.2.6-1~trusty1' --libdir=/usr/lib/x86_64-linux-gnu --prefix=/usr --enable-bzlib --enable-libdc1394 --enable-libfreetype --enable-frei0r --enable-gnutls --enable-libgsm --enable-libmp3lame --enable-librtmp --enable-libopencv --enable-libopenjpeg --enable-libopus --enable-libpulse --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-vaapi --enable-vdpau --enable-libvorbis --enable-libvpx --enable-zlib --enable-gpl --enable-postproc --enable-libcdio --enable-x11grab --enable-libx264 --shlibdir=/usr/lib/x86_64-linux-gnu --enable-shared --disable-static
  libavutil      52. 18.100 / 52. 18.100
  libavcodec     54. 92.100 / 54. 92.100
  libavformat    54. 63.104 / 54. 63.104
  libavdevice    53.  5.103 / 53.  5.103
  libavfilter     3. 42.103 /  3. 42.103
  libswscale      2.  2.100 /  2.  2.100
  libpostproc    52.  2.100 / 52.  2.100
[dv @ 0x13f22c0] Estimating duration from bitrate, this may be inaccurate
Input #0, dv, from '/home/carmen/Videos/christmas2004.dv':
    timecode        : 00:00:00:02
  Duration: 01:02:23.68, start: 0.000000, bitrate: 28800 kb/s
    Stream #0:0: Video: dvvideo, yuv420p, 720x576 [SAR 16:15 DAR 4:3], 28800 kb/s, 25 tbr, 25 tbn, 25 tbc
    Stream #0:1: Audio: pcm_s16le, 32000 Hz, stereo, s16, 1024 kb/s
    Stream #0:2: Audio: pcm_s16le, 32000 Hz, stereo, s16, 1024 kb/s
The debug log indicates that it is using the profile for Samsung TV / player (C/D-series).
Attached is a debug file, with me browsing to the /Videos folder from the telly (fixed IP .87)
If anyone can help I would greatly appreciate it - the kids are driving me nuts to see the home videos on the big telly in the living room :)
serviio (copy).log
(84.98 KiB) Downloaded 596 times
