Cant play .srt in mkv on C5500. Works wit USB though
magfei
Post Wed Feb 16, 2011 2:07 pm
Hi.
New guy on this forum from Sweden. :)
Hope you have som understandning that my english isn´t allways the best. ;)
Now to the problem. I´ve been surfing around in the forum a little and reading a little about my problem. But the thing is that i didn´t find any solution.
I´ve tried to run mkv with .srt file. Theay have of course the same namne in one folder. But when i play it i cant get the subs using the tools on my remote. Buyt when i run the same files via USB in my BD it works fine. When pressing tools i can choose subs.
What shall i do? Is there something i can do in for example settings?
I have the latest firmware (updated today feb 16) in my BD. Have Serviio 0.4.2. The reason i have that one and not 0.5 is that i´ve read in here somwhere that just that version works with mkv files. I´ve had some problems running mkv when i had 0.5. Therfore did i change version.
Would be greateful for som answers if u have any. :)
Post Wed Feb 16, 2011 2:12 pm
Re: Cant play .srt in mkv on C5500. Works wit USB though
The tools menu won't work. If the file is there next to the mkv and has the same name and you have the Samsung C profile selected it should just be displayed.
magfei
Post Wed Feb 16, 2011 2:37 pm
Thanx for your answer. :) But i have exacly thoose things u say, but it doesn´t work anyway. What else is there to do?
Post Wed Feb 16, 2011 3:34 pm
Can you post detailed log of when you attempt to play the file?
magfei
Post Wed Feb 16, 2011 5:30 pm
How do i do that? I´m not competely "stupid" regarding computers, but this one i don´t knew how to do. ;)
Post Wed Feb 16, 2011 5:34 pm
