Samsung and Serviio does not connect thru wifi
sven
Post Sat Feb 14, 2015 11:55 am
I just moved to a new apartment and are trying to get Serviio up again. I have a iMac 27" 3,1 GHz Intel Core i5 with OS X Yosemite 10.10.2. WiFi comes through a Technicolor TG389 Ethernet gateway and behind that there is a Raycore Mediabox. The TV is a Samsung UE46D6535.
With Servo 1.4.1.2 and a Airport Extreme it usually worked fine. This time I downloaded 1.5 an now the TV does not find serviio at all, it only connects to the modem and shows it's empty folders.
Anyone with a clue?
Post Sat Feb 14, 2015 10:42 pm
Re: Samsung and Serviio does not connect thru wifi
My guess is there's something wrong with the Wi-Fi settings on the gateway box. However, I'm a little unclear about your network layout. Your Wi-Fi is provided by the Technicolor box, but then you say the Raycore box is "behind" it. Is it behind, the same way your TV is behind it?. Does your TV see the Raycore box (or is it something that the TV can see at all)?
Next we need to look at your IP address settings. Assuming your Technicolor box is assigning all IP addresses for your network, every device should be assigned an address in the same subnet. This means the first three numbers in the IP address should be the same (i.e. 192.168.0.x, with x being different on each device). If not, then your Wi-Fi is being assigned a different subnet, and nothing on the local network will be visible.
It is also possible the Wi-Fi is set up for "guest" access only, which means it will block the Wi-Fi device from seeing anything other than the Internet. It may or may not assign an IP address from the same subnet as the internal addresses. I've done a quick web search for your Technicolor TG389, but can't find anything detailed about its functionality, at least in English! I finally did find one spec sheet that indicates it support four SSIDs, which means it could be assigning your Wi-Fi to a guest service, rather than allowing access to the entire internal network. You'll need to check the settings. I can't find an instruction manual online to help out.
sven
Post Sun Feb 15, 2015 4:41 pm
atc98092 wrote:My guess is there's something wrong with the Wi-Fi settings on the gateway box. However, I'm a little unclear about your network layout. Your Wi-Fi is provided by the Technicolor box, but then you say the Raycore box is "behind" it. Is it behind, the same way your TV is behind it?. Does your TV see the Raycore box (or is it something that the TV can see at all)?
Thanks for your time. I'm no network expert, but as far as I understand the Raycore Mediabox split up the different services - broadband, TV and telephone - which all come thru the same fiber in this apartment. The Technicolor box is connected to the Raycore box and works as wifi router. TV is connected to wifi and so is the computer.
atc98092 wrote:Next we need to look at your IP address settings. Assuming your Technicolor box is assigning all IP addresses for your network, every device should be assigned an address in the same subnet. This means the first three numbers in the IP address should be the same (i.e. 192.168.0.x, with x being different on each device). If not, then your Wi-Fi is being assigned a different subnet, and nothing on the local network will be visible.
Correct. The box itself is 192.168.0.1, my computer is 192.168.0.69 and TV is 192.168.0.72. Youtube and other apps works fine ot the TV so Internet is fine. When I open AllShare it only shows the empty folders of the technicolor box and nothing from the computer.
atc98092 wrote:It is also possible the Wi-Fi is set up for "guest" access only, which means it will block the Wi-Fi device from seeing anything other than the Internet. It may or may not assign an IP address from the same subnet as the internal addresses. I've done a quick web search for your Technicolor TG389, but can't find anything detailed about its functionality, at least in English! I finally did find one spec sheet that indicates it support four SSIDs, which means it could be assigning your Wi-Fi to a guest service, rather than allowing access to the entire internal network. You'll need to check the settings. I can't find an instruction manual online to help out.
OK, I'm not sure I understand this part. Could my Technicolor box prevent a local network and just supply internet? I have a swedish manual, but I'm not sure it covers this. I'll see what I can find out.
sven
Post Sun Feb 15, 2015 6:36 pm
This it how the setting look for the TV in the router: http://www.tiikoni.com/tis/view/?id=87b44e8
Post Sun Feb 15, 2015 10:02 pm
Try removing the TV from Serviio (renderers list on the Status tab) and also if possible, removing Serviio or refreshing the server list on the TV (not sure if the Samsung has this option).
Then let the TV and Server refresh and rediscover everything.
Did anything else change? Eg were you wired and now wireless. Does the IP address of the TV match what is listed on the Serviio server. Otherwise post a detailed log.
Post Mon Feb 16, 2015 12:12 am
OK, computer and TV are both on Wi-Fi. That eliminates my thought of them being on different subnets or the Wi-Fi being set to guest access only.
Follow what DenyAll suggests and let us know.
sven
Post Mon Feb 16, 2015 5:55 pm
DenyAll wrote:Try removing the TV from Serviio (renderers list on the Status tab) and also if possible, removing Serviio or refreshing the server list on the TV (not sure if the Samsung has this option).
I did before posting here. Nothing showed up. A day later the computers IP showed up as Unrecognized device. I have also deleted all units from the All Share settings on the TV. Only the router (Technicolor) shows up there now. I have been refreshing several times.
DenyAll wrote:Did anything else change? Eg were you wired and now wireless.
Router and ISP changed. I also upgraded Serviio to 1.5 when things did not work. Computer and TV are the same an I was wireless before too. I have not yet received my TV decoder, but I can't see how that should be interfering with Serviio. IP numbers are different now. They used to be 10.0.0.x now they are 192.168.0.x. I also recently upgraded to Mac OS x 10.10.2 (Used to be 10.10.1 something i think).
DenyAll wrote:Does the IP address of the TV match what is listed on the Serviio server.
I can't even see the IP address of the TV in Serviio, only the computers IP shows up. In the TV I can only see the router as a unit. They does not discover each other at all.
DenyAll wrote:Otherwise post a detailed log.
I have activated the detailed log.
sven
Post Mon Feb 16, 2015 6:22 pm
This is what I got the first minutes after filtering the library out:
2015-02-16 19:16:07,553 DEBUG [ApplicationInstanceManager] Listening for application instances on socket 44331
2015-02-16 19:16:07,555 INFO [MediaServer] ------------------------------------------------------------------------
2015-02-16 19:16:07,555 INFO [MediaServer] Serviio DLNA media streaming server v 1.5 (rev. 19ceb8acec8c)
2015-02-16 19:16:07,555 INFO [MediaServer] Petr Nejedly 2009-2015
2015-02-16 19:16:07,555 INFO [MediaServer] http://www.serviio.org
2015-02-16 19:16:07,555 INFO [MediaServer] Java 1.8.0_20-Oracle Corporation x86_64
2015-02-16 19:16:07,555 INFO [MediaServer] OS Mac OS X 10.10.2
2015-02-16 19:16:07,555 INFO [MediaServer] File encoding: UTF-8
2015-02-16 19:16:07,555 INFO [MediaServer] Headless mode enabled: true
2015-02-16 19:16:07,555 INFO [MediaServer] User: root
2015-02-16 19:16:07,555 INFO [MediaServer] User home dir: /var/root
2015-02-16 19:16:07,555 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2015-02-16 19:16:07,559 DEBUG [MediaServer] Runtime params: -Xmx512M, -Xms20M, -XX:+UseG1GC, -XX:GCTimeRatio=1, -XX:MinHeapFreeRatio=10, -XX:MaxHeapFreeRatio=20, -Djava.net.preferIPv4Stack=true, -Djava.awt.headless=true, -Dorg.restlet.engine.loggerFacadeClass=org.restlet.ext.slf4j.Slf4jLoggerFacade, -Dderby.system.home=/Library/Application Support/Serviio/library, -Dserviio.home=/Library/Application Support/Serviio, -Dffmpeg.location=/Library/Application Support/Serviio/lib/ffmpeg, -Ddcraw.location=/Library/Application Support/Serviio/lib/dcraw
2015-02-16 19:16:07,652 INFO [WebServer] Socket buffer set to 65535 bytes
2015-02-16 19:16:07,653 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2015-02-16 19:16:07,716 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2015-02-16 19:16:07,716 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2015-02-16 19:16:07,727 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2015-02-16 19:16:07,733 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.sql' has been run
2015-02-16 19:16:07,734 INFO [DatabaseManager] Using DERBY database language
2015-02-16 19:16:07,895 DEBUG [ConfigEntryDAOImpl] Reading all ConfigEntries
2015-02-16 19:16:08,184 DEBUG [DBLogDAOImpl] Checking if script 'script-0.1.1.sql' has been run
2015-02-16 19:16:08,185 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2015-02-16 19:16:08,185 DEBUG [DBLogDAOImpl] Checking if script 'script-0.2.sql' has been run
2015-02-16 19:16:08,185 DEBUG [DBLogDAOImpl] Checking if script 'script-0.3.1.sql' has been run
2015-02-16 19:16:08,186 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.sql' has been run
2015-02-16 19:16:08,186 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.1.sql' has been run
2015-02-16 19:16:08,187 DEBUG [DBLogDAOImpl] Checking if script 'script-0.4.2.sql' has been run
2015-02-16 19:16:08,187 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.sql' has been run
2015-02-16 19:16:08,188 DEBUG [DBLogDAOImpl] Checking if script 'script-0.5.1.sql' has been run
2015-02-16 19:16:08,189 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.sql' has been run
2015-02-16 19:16:08,189 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.1.sql' has been run
2015-02-16 19:16:08,190 DEBUG [DBLogDAOImpl] Checking if script 'script-0.6.2.sql' has been run
2015-02-16 19:16:08,190 DEBUG [DBLogDAOImpl] Checking if script 'script-1.0.sql' has been run
2015-02-16 19:16:08,191 DEBUG [DBLogDAOImpl] Checking if script 'script-1.1.sql' has been run
2015-02-16 19:16:08,191 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.sql' has been run
2015-02-16 19:16:08,192 DEBUG [DBLogDAOImpl] Checking if script 'script-1.2.1.sql' has been run
2015-02-16 19:16:08,193 DEBUG [DBLogDAOImpl] Checking if script 'script-1.3.sql' has been run
2015-02-16 19:16:08,194 DEBUG [DBLogDAOImpl] Checking if script 'script-1.4.sql' has been run
2015-02-16 19:16:08,194 DEBUG [DBLogDAOImpl] Checking if script 'script-1.5.sql' has been run
2015-02-16 19:16:08,196 INFO [Device] Created UPnP Device with UUID: a5817be9-7c16-30f5-844c-2cf722d2a8cb, bound address: 192.168.1.74
2015-02-16 19:16:08,199 DEBUG [LicensingManager] Updating license
2015-02-16 19:16:08,200 DEBUG [LicenseValidator] Validating license file (339 bytes)
2015-02-16 19:16:08,269 INFO [MediaServer] ------------------------------------------------------------------------
2015-02-16 19:16:08,269 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2015-02-16 19:16:08,526 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-02-16 19:16:08,528 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 1
2015-02-16 19:16:08,575 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2015-02-16 19:16:08,575 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 2
2015-02-16 19:16:08,581 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2015-02-16 19:16:08,581 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 3
2015-02-16 19:16:08,583 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2015-02-16 19:16:08,584 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 4
2015-02-16 19:16:08,584 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2015-02-16 19:16:08,584 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 5
2015-02-16 19:16:08,584 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2015-02-16 19:16:08,584 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 6
2015-02-16 19:16:08,585 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2015-02-16 19:16:08,585 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_h
2015-02-16 19:16:08,586 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2015-02-16 19:16:08,586 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sam_ef
2015-02-16 19:16:08,587 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2015-02-16 19:16:08,587 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 7
2015-02-16 19:16:08,587 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2015-02-16 19:16:08,587 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 8
2015-02-16 19:16:08,588 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2015-02-16 19:16:08,588 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012
2015-02-16 19:16:08,589 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2015-02-16 19:16:08,590 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2013
2015-02-16 19:16:08,590 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2015-02-16 19:16:08,591 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2013
2015-02-16 19:16:08,591 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2015-02-16 19:16:08,591 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2012
2015-02-16 19:16:08,592 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2015-02-16 19:16:08,592 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010
2015-02-16 19:16:08,593 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2015-02-16 19:16:08,593 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2010us
2015-02-16 19:16:08,593 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2015-02-16 19:16:08,593 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile bdp2011
2015-02-16 19:16:08,593 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2015-02-16 19:16:08,593 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 13
2015-02-16 19:16:08,593 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2015-02-16 19:16:08,594 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile tosh2012
2015-02-16 19:16:08,594 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2015-02-16 19:16:08,594 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 14
2015-02-16 19:16:08,595 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2015-02-16 19:16:08,595 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 15
2015-02-16 19:16:08,595 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2015-02-16 19:16:08,595 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 16
2015-02-16 19:16:08,596 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2015-02-16 19:16:08,596 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 17
2015-02-16 19:16:08,596 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2015-02-16 19:16:08,596 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 18
2015-02-16 19:16:08,596 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2015-02-16 19:16:08,596 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011
2015-02-16 19:16:08,596 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2015-02-16 19:16:08,597 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2010
2015-02-16 19:16:08,597 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2015-02-16 19:16:08,597 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile plps2010
2015-02-16 19:16:08,597 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2015-02-16 19:16:08,597 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 20
2015-02-16 19:16:08,597 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2015-02-16 19:16:08,598 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2009
2015-02-16 19:16:08,598 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2015-02-16 19:16:08,598 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile 22
2015-02-16 19:16:08,598 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2015-02-16 19:16:08,599 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2013
2015-02-16 19:16:08,599 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2015-02-16 19:16:08,599 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2011a
2015-02-16 19:16:08,599 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2015-02-16 19:16:08,600 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2015-02-16 19:16:08,600 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viera2010
2015-02-16 19:16:08,600 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2015-02-16 19:16:08,600 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2012us
2015-02-16 19:16:08,600 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2015-02-16 19:16:08,600 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile sony2011us
2015-02-16 19:16:08,600 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2015-02-16 19:16:08,600 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonySTR
2015-02-16 19:16:08,601 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2015-02-16 19:16:08,601 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile SonyCMT
2015-02-16 19:16:08,601 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2015-02-16 19:16:08,601 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile viziotv
2015-02-16 19:16:08,601 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2015-02-16 19:16:08,601 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile win8metro
2015-02-16 19:16:08,602 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2015-02-16 19:16:08,602 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile panasonicBDT220
2015-02-16 19:16:08,602 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2015-02-16 19:16:08,602 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile philips_streamium
2015-02-16 19:16:08,603 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2015-02-16 19:16:08,603 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile roku
2015-02-16 19:16:08,603 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2015-02-16 19:16:08,603 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile RokuMPApp
2015-02-16 19:16:08,604 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2015-02-16 19:16:08,604 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile YamBD
2015-02-16 19:16:08,604 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2015-02-16 19:16:08,604 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile TNDC
2015-02-16 19:16:08,604 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2015-02-16 19:16:08,604 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile xbox_one
2015-02-16 19:16:08,605 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2015-02-16 19:16:08,605 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile raumfeld
2015-02-16 19:16:08,605 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2015-02-16 19:16:08,629 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2015-02-16 19:16:08,630 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile flv_player
2015-02-16 19:16:08,630 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2015-02-16 19:16:08,630 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile ios
2015-02-16 19:16:08,630 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2015-02-16 19:16:08,631 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile html5
2015-02-16 19:16:08,631 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2015-02-16 19:16:08,631 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_standard
2015-02-16 19:16:08,631 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2015-02-16 19:16:08,631 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2015-02-16 19:16:08,632 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_hls
2015-02-16 19:16:08,632 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2015-02-16 19:16:08,632 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile serviigo_gtv
2015-02-16 19:16:08,632 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2015-02-16 19:16:08,632 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile googlecast
2015-02-16 19:16:08,633 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2015-02-16 19:16:08,633 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile chromecast
2015-02-16 19:16:08,633 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2015-02-16 19:16:08,633 DEBUG [ProfilesDefinitionParser] Parsing profile definition for profile wp8
2015-02-16 19:16:08,633 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2015-02-16 19:16:08,656 INFO [PluginCompilerThread] Looking for plugins at /Library/Application Support/Serviio/plugins
2015-02-16 19:16:08,656 INFO [PluginCompilerThread] Started looking for plugins
2015-02-16 19:16:08,657 INFO [UpdateChecker] Checking if a new version is available
2015-02-16 19:16:08,662 DEBUG [FFMPEGWrapper] Invoking FFMPEG to check if it exists of path /Library/Application Support/Serviio/lib/ffmpeg
2015-02-16 19:16:08,664 DEBUG [ProcessExecutor] Starting /Library/Application Support/Serviio/lib/ffmpeg
2015-02-16 19:16:08,676 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
2015-02-16 19:16:08,678 DEBUG [DCRawWrapper] Invoking DCRAW to check if it exists of path /Library/Application Support/Serviio/lib/dcraw
2015-02-16 19:16:08,679 DEBUG [ProcessExecutor] Starting /Library/Application Support/Serviio/lib/dcraw
2015-02-16 19:16:08,691 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2015-02-16 19:16:08,711 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2015-02-16 19:16:08,711 INFO [WebServer] WebServer starting on port 8895
2015-02-16 19:16:08,711 INFO [Device] Updated bound IP address of Device with UUID: a5817be9-7c16-30f5-844c-2cf722d2a8cb, bound address: 192.168.1.74
2015-02-16 19:16:08,718 DEBUG [DiscoveryManager] UPNP device a5817be9-7c16-30f5-844c-2cf722d2a8cb (192.168.1.74) is available
2015-02-16 19:16:08,718 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-02-16 19:16:08,719 INFO [EventDispatcher] Starting EventDispatcher
2015-02-16 19:16:08,719 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-02-16 19:16:08,734 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2015-02-16 19:16:08,734 INFO [RendererSearchSender] Searching for Renderer devices
2015-02-16 19:16:08,736 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:16:08,736 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:16:08,746 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2015-02-16 19:16:08,754 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.74:58622s
2015-02-16 19:16:08,755 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.74:58622s
2015-02-16 19:16:08,756 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.74:58622s
2015-02-16 19:16:08,785 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:16:08,785 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:16:10,652 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2015-02-16 19:16:14,752 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2015-02-16 19:16:18,788 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:16:18,788 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:16:20,628 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2015-02-16 19:16:28,789 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:16:28,790 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:16:30,639 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:59 (advertisement duration is 1800 sec.)
2015-02-16 19:16:34,755 INFO [FeedUpdaterWorker] Started looking for information about online resources
2015-02-16 19:16:34,755 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2015-02-16 19:16:34,790 INFO [LocalLibraryManager] Starting automatic library scan
2015-02-16 19:16:34,806 INFO [LibraryDeltaScanner] Added repository '/Volumes/Data_2/Nerladdat/Newly downloaded complete files' to delta scanner (NATIVE)
2015-02-16 19:16:34,833 INFO [LibraryDeltaScanner] Added repository '/Volumes/Data_2/Filmer/_Fiction' to delta scanner (NATIVE)
2015-02-16 19:16:34,833 INFO [LibraryDeltaScanner] Starting the library delta scan
2015-02-16 19:16:34,834 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2015-02-16 19:17:15,193 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2015-02-16 19:17:16,294 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2015-02-16 19:17:16,541 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2015-02-16 19:17:16,871 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2015-02-16 19:17:22,283 DEBUG [ActionsServerResource] Action with name 'forceLibraryRefresh' was requested
2015-02-16 19:17:22,286 INFO [LocalLibraryManager] Starting manual library scan
2015-02-16 19:17:22,538 INFO [PlaylistMaintainerWorker] Finished looking for playlist changes
2015-02-16 19:17:22,642 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2015-02-16 19:20:30,292 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:20:30,292 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:20:32,130 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:38 (advertisement duration is 1800 sec.)
sven
Post Mon Feb 16, 2015 8:39 pm
Here is some more:
2015-02-16 19:24:10,307 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:24:10,307 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:24:12,129 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:26 (advertisement duration is 1800 sec.)
2015-02-16 19:25:41,818 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.74:65427s
2015-02-16 19:25:41,818 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.74:65427s
2015-02-16 19:27:38,541 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:27:38,541 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:27:40,371 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:12 (advertisement duration is 1800 sec.)
2015-02-16 19:28:31,708 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2015-02-16 19:28:44,583 DEBUG [ActionsServerResource] Action with name 'stopServer' was requested
2015-02-16 19:28:44,583 DEBUG [DiscoveryManager] UPNP device a5817be9-7c16-30f5-844c-2cf722d2a8cb (192.168.1.74) is unavailable
2015-02-16 19:28:44,583 DEBUG [WebServer] Socket closed
2015-02-16 19:28:44,583 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2015-02-16 19:28:44,584 DEBUG [WebServer] Marking the web server for exit
2015-02-16 19:28:44,584 INFO [WebServer] WebServer shutting down
2015-02-16 19:28:44,584 DEBUG [DiscoverySSDPMessageListener] Socket closed: Socket closed
2015-02-16 19:28:44,584 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-02-16 19:28:44,584 INFO [EventDispatcher] Leaving EventDispatcher
2015-02-16 19:28:44,584 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-02-16 19:28:44,584 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP byebye using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:28:46,534 DEBUG [ActionsServerResource] Action with name 'startServer' was requested
2015-02-16 19:28:46,535 DEBUG [LocalAddressResolverStrategy] Resolving host IP address automatically
2015-02-16 19:28:46,535 INFO [WebServer] WebServer starting on port 8895
2015-02-16 19:28:46,535 INFO [Device] Updated bound IP address of Device with UUID: a5817be9-7c16-30f5-844c-2cf722d2a8cb, bound address: 192.168.1.74
2015-02-16 19:28:46,535 DEBUG [DiscoveryManager] UPNP device a5817be9-7c16-30f5-844c-2cf722d2a8cb (192.168.1.74) is available
2015-02-16 19:28:46,535 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2015-02-16 19:28:46,535 INFO [EventDispatcher] Starting EventDispatcher
2015-02-16 19:28:46,535 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:28:46,535 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2015-02-16 19:28:46,535 INFO [RendererSearchSender] Searching for Renderer devices
2015-02-16 19:28:46,536 DEBUG [RendererSearchSender$RendererSearchWorker] Multicasting SSDP M-SEARCH using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:28:46,536 DEBUG [RendererSearchSender$RendererSearchWorker] Sending 1 'm-search' messages
2015-02-16 19:28:46,536 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.74:60930s
2015-02-16 19:28:46,537 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:device:MediaRenderer:1 from address /192.168.1.74:60930s
2015-02-16 19:28:46,622 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:28:46,622 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:28:48,455 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2015-02-16 19:28:49,177 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2015-02-16 19:28:52,541 DEBUG [RendererSearchSender] Finished searching for Renderer devices
2015-02-16 19:28:54,728 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2015-02-16 19:28:54,728 DEBUG [RendererDAOImpl] Deleting a Renderer (uuid = 5d1e2393-46ce-4426-b93d-aef362e9fbc5)
2015-02-16 19:28:54,777 DEBUG [StatusServerResource] Storing bound NIC: null
2015-02-16 19:28:54,777 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = bound_nic_name)
2015-02-16 19:28:54,781 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = bound_nic_name, value = )
2015-02-16 19:28:54,791 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = renderer_enabled_default)
2015-02-16 19:28:54,791 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = renderer_enabled_default, value = true)
2015-02-16 19:28:54,793 DEBUG [ConfigEntryDAOImpl] Reading a ConfigEntry (name = renderer_default_access_group_id)
2015-02-16 19:28:54,793 DEBUG [ConfigEntryDAOImpl] Updating ConfigEntry (name = renderer_default_access_group_id, value = 1)
2015-02-16 19:28:56,625 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:28:56,626 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:28:58,471 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:08 (advertisement duration is 1800 sec.)
2015-02-16 19:28:58,497 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2015-02-16 19:28:59,075 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2015-02-16 19:28:59,449 DEBUG [RendererDAOImpl] Retrieving list of all stored renderers
2015-02-16 19:29:06,630 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:29:06,630 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:29:08,493 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:10 (advertisement duration is 1800 sec.)
2015-02-16 19:29:31,848 DEBUG [ActionsServerResource] Action with name 'forceLibraryRefresh' was requested
2015-02-16 19:29:31,849 INFO [LocalLibraryManager] Starting manual library scan
2015-02-16 19:29:32,037 INFO [PlaylistMaintainerWorker] Finished looking for playlist changes
2015-02-16 19:29:32,140 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2015-02-16 19:33:19,126 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:33:19,126 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:33:20,969 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:07 (advertisement duration is 1800 sec.)
2015-02-16 19:37:28,796 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:37:28,796 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:37:30,651 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:04 (advertisement duration is 1800 sec.)
2015-02-16 19:40:35,200 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:40:35,201 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:40:37,055 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:00 (advertisement duration is 1800 sec.)
2015-02-16 19:40:41,926 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.74:65427s
2015-02-16 19:40:41,926 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.74:65427s
2015-02-16 19:44:38,000 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:44:38,001 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:44:39,845 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:35 (advertisement duration is 1800 sec.)
2015-02-16 19:48:15,141 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:48:15,141 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:48:16,994 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:42 (advertisement duration is 1800 sec.)
2015-02-16 19:51:59,857 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:51:59,858 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:52:01,738 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:47 (advertisement duration is 1800 sec.)
2015-02-16 19:55:42,016 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.74:65427s
2015-02-16 19:55:42,016 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.74:65427s
2015-02-16 19:55:48,801 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:55:48,801 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:55:50,639 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:48 (advertisement duration is 1800 sec.)
2015-02-16 19:59:39,193 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 19:59:39,193 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 19:59:41,078 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:43 (advertisement duration is 1800 sec.)
2015-02-16 20:03:24,128 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:03:24,128 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:03:25,998 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:38 (advertisement duration is 1800 sec.)
2015-02-16 20:07:04,325 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:07:04,325 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:07:06,184 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:34 (advertisement duration is 1800 sec.)
2015-02-16 20:10:40,237 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:10:40,238 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:10:42,120 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:41 (advertisement duration is 1800 sec.)
2015-02-16 20:10:42,136 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.74:65427s
2015-02-16 20:10:42,136 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.74:65427s
2015-02-16 20:14:23,427 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:14:23,427 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:14:25,298 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:57 (advertisement duration is 1800 sec.)
2015-02-16 20:18:22,940 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:18:22,940 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:18:24,844 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:00 (advertisement duration is 1800 sec.)
2015-02-16 20:21:25,143 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:21:25,143 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:21:26,970 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:09 (advertisement duration is 1800 sec.)
2015-02-16 20:25:35,976 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:25:35,976 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:25:37,847 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:07 (advertisement duration is 1800 sec.)
2015-02-16 20:25:42,248 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.74:65427s
2015-02-16 20:25:42,248 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.74:65427s
2015-02-16 20:29:45,099 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:29:45,099 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:29:46,921 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:39 (advertisement duration is 1800 sec.)
2015-02-16 20:33:26,296 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:33:26,296 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:33:28,156 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:09 (advertisement duration is 1800 sec.)
2015-02-16 20:36:37,920 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:36:37,920 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:36:39,735 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:36 (advertisement duration is 1800 sec.)
2015-02-16 20:40:16,320 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:40:16,320 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:40:18,223 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:00 (advertisement duration is 1800 sec.)
2015-02-16 20:40:42,356 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.74:65427s
2015-02-16 20:40:42,357 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.74:65427s
2015-02-16 20:44:18,757 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:44:18,758 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:44:20,595 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:37 (advertisement duration is 1800 sec.)
2015-02-16 20:47:58,297 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:47:58,298 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:48:00,138 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:09 (advertisement duration is 1800 sec.)
2015-02-16 20:52:09,518 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:52:09,519 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:52:11,349 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:02:58 (advertisement duration is 1800 sec.)
2015-02-16 20:55:09,597 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:55:09,598 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:55:11,436 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:55 (advertisement duration is 1800 sec.)
2015-02-16 20:55:42,470 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.74:65427s
2015-02-16 20:55:42,470 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.74:65427s
2015-02-16 20:59:06,621 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 20:59:06,621 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 20:59:08,493 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:07 (advertisement duration is 1800 sec.)
2015-02-16 21:03:16,105 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 21:03:16,105 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 21:03:17,966 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:27 (advertisement duration is 1800 sec.)
2015-02-16 21:06:45,477 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 21:06:45,477 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 21:06:47,332 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:02:59 (advertisement duration is 1800 sec.)
2015-02-16 21:09:46,535 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 21:09:46,536 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 21:09:48,404 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:13 (advertisement duration is 1800 sec.)
2015-02-16 21:10:42,572 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.74:65427s
2015-02-16 21:10:42,572 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.74:65427s
2015-02-16 21:13:02,156 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 21:13:02,157 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 21:13:04,032 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:07 (advertisement duration is 1800 sec.)
2015-02-16 21:16:11,334 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 21:16:11,334 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 21:16:13,177 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:52 (advertisement duration is 1800 sec.)
2015-02-16 21:20:05,804 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 21:20:05,804 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 21:20:07,660 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:42 (advertisement duration is 1800 sec.)
2015-02-16 21:23:49,994 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 21:23:49,994 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 21:23:51,882 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:05 (advertisement duration is 1800 sec.)
2015-02-16 21:25:42,681 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANIPConnection:1 from address /192.168.1.74:65427s
2015-02-16 21:25:42,681 DEBUG [DiscoverySSDPMessageListener] Received a valid M-SEARCH message for search target urn:schemas-upnp-org:service:WANPPPConnection:1 from address /192.168.1.74:65427s
2015-02-16 21:27:57,347 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 21:27:57,347 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 21:27:59,186 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:03 (advertisement duration is 1800 sec.)
2015-02-16 21:32:02,836 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 21:32:02,836 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 21:32:04,696 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:03:10 (advertisement duration is 1800 sec.)
2015-02-16 21:35:15,220 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface en1 (en1) and address 192.168.1.74, timeout = 0
2015-02-16 21:35:15,220 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device a5817be9-7c16-30f5-844c-2cf722d2a8cb
2015-02-16 21:35:17,062 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:04:01 (advertisement duration is 1800 sec.)
Post Mon Feb 16, 2015 10:18 pm
OK, I see a possible problem. In the earlier post you said the IP address was in the 192.168.0.x subnet. The log shows a bound IP address of 192.168.1.74. These two subnets can't talk with each other.
Still suspicious of the Wi-Fi being in some sort of guest mode, which is prohibiting devices from seeing anything else on the Wi-Fi. Check your Wi-Fi settings closely in your router. Look for anything that talks about different IP address ranges or allowing Wi-Fi clients to see each other.
You should have a screen on the TV showing its assigned IP address. You should be able to ping the TV from the computer. If you can't, there's nothing Serviio can do to solve that. You have a networking issue that has nothing to do with the way Serviio works.
sven
Post Tue Feb 17, 2015 7:29 pm
I read about a DNS error in Samsungs TVs and updated the TV setting with Google DNS 8.8.8.8. I also made a hard reset of the router. Now serviio finds the TV. :D
Read more about the DNS error: http://www.tomshardware.co.uk/forum/432 ... g-internet
Thanks for your support! :)
Post Tue Feb 17, 2015 9:21 pm
Glad you resolved it, but it's a weird one. DNS shouldn't affect Serviio discovery. Maybe fixing the DNS issues also fixes other problems in the Samsung. Or it could have been the hard reset of the router that did the trick.
Anyway, good to see it resolved. Should help others that come across the problem.
Post Wed Feb 18, 2015 1:20 am
OK, one more thing to add to the tool box. Definitely a weird one! :shock:
Like DenyAll said, in theory it shouldn't have had an effect on Serviio, but as a side note I did try using a Belkin router that had DNS issues. It assigned itself as the DNS server for my network (as it should) but nothing on my network could reach the Internet. I had to manually assign a different DNS (such as Google) on every device before things would work. I should have known better as I had issues with another Belkin router, but was sucked in by the low price. Never again...
Users browsing this forum: Baidu [Spider] and 30 guests
