Firmwareupdate ES6200 Series to version 002004
IronGibbet
Post Thu Mar 05, 2015 8:23 pm
yesterday I installed that firmware since then lots of my videos would stop mid playing and cause the TV to reboot.
It seems, that the problem is with the "Codec ID: V_MPEG4/ISO/AVC" and AVC is not officially supported (was told that by the support).
Has anyone here by coincidence the previous firmware version or at least the the name of it? "T-MST10PDEUC_2004.1" is the current one.
Thanks in advance.
IG
Steve124
Post Sat Mar 28, 2015 11:25 am
Re: Firmwareupdate ES6200 Series to version 002004
I have exactly the same problem and more... I updated to version 002004 and now almost all mkv, especially the fullhd ones stop after a few minutes or don't play at all.
Those videos played just fine before the update.
Has anyone managed to find a fix to this problem as it seems it isn't singular?
