BluRay and MOV files
MacMatt
Post Mon Feb 28, 2011 5:37 am
Hello-
I just got around to trying some of my home movies that I edited and made into .mov files. They appear on the Blu-ray just fine, but then I play them, 1 doesn't play at all, and the 2nd one will play for about a minute and then a window will pop up saying, "Not Supported Video Codec". What does this mean? Is my router not able to handle sending .mov files to the Blu-ray player or does it need more time to load? Thanks for your help.
Matt
Post Mon Feb 28, 2011 6:08 am
Re: BluRay and MOV files
MacMatt wrote:Hello-
Matt
.mov file are not currently supported by serviio
Post Mon Feb 28, 2011 8:10 am
Cerberus wrote:.mov file are not currently supported by serviio
What... mov not supported !!!!!?
Of course, it supports mov
http://www.serviio.org/features
Post Mon Feb 28, 2011 10:18 am
yes, they are supported, it's just a flavour of mpeg4. Post ffmpeg -i of the mov file.
Post Mon Feb 28, 2011 6:00 pm
i stand corrected.
MacMatt
Post Tue Mar 01, 2011 4:50 pm
zip wrote:yes, they are supported, it's just a flavour of mpeg4. Post ffmpeg -i of the mov file.
Petr - how do I post ffmeg -i ? Is it a conversion? Or an option within Serviio?
Post Tue Mar 01, 2011 5:05 pm
Users browsing this forum: Bing [Bot] and 28 guests
