Samsung D & F Series no resume
ritch450
Post Sun Mar 06, 2016 11:49 pm
I know there is a lot about this topic on this forum but I have not found and answer to my problem either here or anywhere else...
I swapped from All share to Serviio. I like it much better apart from the playback does not resuming to where the video was last watched after it's stopped. this used to work on Allsahre. I think I have the profiles for the two TVs I use set correctly and everything else works fine. I'm on Windows 10.
Any help appreciated.
Post Mon Mar 07, 2016 8:45 pm
Re: Samsung D & F Series no resume
Works for me. Make sure the profiles are right. Also it might not work on all file types.
ritch450
Post Wed Mar 09, 2016 10:44 pm
Thanks for the reply Petr much appreciated. I'm using mp4 and mkv files. Do you have any suggestions that may help?
Best, Ritch
Post Thu Mar 10, 2016 9:13 pm
post detailed log of playing a file.
Normally on my C series it tells me to press D button (I think) to resume.
ritch450
Post Sat Mar 12, 2016 8:37 pm
I've seen that on other posts but my TV never give prompts like this!
ritch450
Post Sun Mar 13, 2016 4:58 pm
Hi Zip
So I have been playing around with my two TVs:
Samsung UE40D5000
Tried all Samsung profiles and the Generic TV profile - Folders and thumbnails all display perfectly but there is no resume memory with any file type.
Samsung UE55F6600
Only profile where play resume works is C/D but there are no folders just a flat list of thumbnail and most entries there are 2 or 3 phantom copies of each video thumbnail. This problem also occurs with the H profile but resume also doesn't work.
I never get the option to resume or play from the beginning.
Tries press the D key - does nothing.
Firmware up to date on both TVs
These are both very popular TVs in the UK.
I love your product other than these problems and would be happy to pay if this can be resolved.
Best, Ritch
