Stuck and loading with my Samsung TV
Oink BaconBuster
Post Thu Jun 02, 2016 9:27 am
Hi there
I habe the same problem like many ohter useres here. I installed Serviio and tried to stream my movies to my Samsung TV UE55ES6880.
But it is alwasy loading after a few seconds and the picture get stuck.
Unfortunately no other thread had a solution that worked for me.
Do I have some settings to do in my router? The TV is connected with my network through cable, not WiFi. But I had to connect the cable with a plug socket since the router is located upstairs and the tv stands in the living room :(
I would be really gread if somebody can help me.
Thanks in advance
Post Thu Jun 02, 2016 12:55 pm
Re: Stuck and loading with my Samsung TV
what do you mean by plug socket? Are you referring to an Ethernet powerline adapter? If so, that shouldn't be an issue. But to be sure, you could switch to WiFi and try it that way.
Oink BaconBuster
Post Mon Jun 06, 2016 6:16 am
Yes, I mean a powerline adapter :)
Wifi works not better, its rahter worse.
