Problem with Serviio 1.7, mkv and samsung UE40F6500
Mass8
Post Thu Sep 29, 2016 4:39 pm
I have 2 problems with mkv.
The first is the FF/REW doesn't work (the name of mkv is "2x01 - Bang! (1).mkv") and the info of this file is not read correctly (it say 709 minues instead 49)
The second say me from TV "the audio is not supported". In the 1.6.1 the same mkv doesn't say the error. The name is "2x02 - Cani a una sparatoria.mkv"
How i can resolve this issue? I attach the log
log.7z
(155.25 KiB) Downloaded 856 times
Post Thu Sep 29, 2016 8:09 pm
Re: Problem with Serviio 1.7, mkv and samsung UE40F6500
The file is transcoded, that's why there is no FFWD/REW.
Can you post results of
 ffmpeg -i "2x01 - Bang! (1).mkv"
.. you might have to pass the whole path in the quotes
Mass8
Post Fri Sep 30, 2016 4:46 pm
The first mkv
"c:\Program Files\Serviio\lib\ffmpeg" -i "2x01 - Bang! (1).mkv"
ffmpeg version 3.0.2 Copyright (c) 2000-2016 the FFmpeg developers
  built with gcc 4.9.3 (GCC)
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-libass --enable-librtmp --enable-fontconfig --enable-libfreetype --enable-zlib --enable-libx264 --enable-libspeex --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm -lexpat -lfreetype -lfribidi -lz' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --enable-gpl --pkg-config=pkg-config --bindir='/jenkins/workspace/FFmpeg - Win32/target'
  libavutil      55. 17.103 / 55. 17.103
  libavcodec     57. 24.102 / 57. 24.102
  libavformat    57. 25.100 / 57. 25.100
  libavdevice    57.  0.101 / 57.  0.101
  libavfilter     6. 31.100 /  6. 31.100
  libswscale      4.  0.100 /  4.  0.100
  libswresample   2.  0.101 /  2.  0.101
  libpostproc    54.  0.100 / 54.  0.100
Input #0, matroska,webm, from '2x01 - Bang! (1).mkv':
    title           : Daredevil.2x01.Bang.ITA.ENG.720p.WEBMux.AAC.x265.R3P4CK-Pir8
    encoder         : libebml v1.3.4 + libmatroska v1.4.5
    creation_time   : 2016-09-29 16:18:46
  Duration: 00:48:05.13, start: 0.000000, bitrate: 1837 kb/s
    Chapter #0:0: start 0.059000, end 2885.129000
      title           : 00:00:00.059
    Stream #0:0: Video: hevc (Main), yuv420p(tv), 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 23.98 tbc (default)
      title           : HEVC
      BPS             : 1641853
      BPS-eng         : 1641853
      DURATION        : 00:48:05.091000000
      DURATION-eng    : 00:48:05.091000000
      NUMBER_OF_FRAMES: 69173
      NUMBER_OF_FRAMES-eng: 69173
      NUMBER_OF_BYTES : 592112178
      NUMBER_OF_BYTES-eng: 592112178
      _STATISTICS_WRITING_APP: mkvmerge v9.4.2 ('So High') 64bit
      _STATISTICS_WRITING_APP-eng: mkvmerge v9.4.2 ('So High') 64bit
      _STATISTICS_WRITING_DATE_UTC: 2016-09-29 16:18:46
      _STATISTICS_WRITING_DATE_UTC-eng: 2016-09-29 16:18:46
      _STATISTICS_TAGS: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
    Stream #0:1(ita): Audio: aac (LC), 44100 Hz, stereo, fltp (default) (forced)
      title           : AAC LLC
      BPS             : 96056
      BPS-eng         : 96056
      DURATION        : 00:48:05.079000000
      DURATION-eng    : 00:48:05.079000000
      NUMBER_OF_FRAMES: 124250
      NUMBER_OF_FRAMES-eng: 124250
      NUMBER_OF_BYTES : 34641238
      NUMBER_OF_BYTES-eng: 34641238
    Stream #0:2(eng): Audio: aac (LC), 48000 Hz, stereo, fltp
      title           : AAC LLC
      BPS             : 96042
      BPS-eng         : 96042
      DURATION        : 00:48:05.120000000
      DURATION-eng    : 00:48:05.120000000
      NUMBER_OF_FRAMES: 135240
      NUMBER_OF_FRAMES-eng: 135240
      NUMBER_OF_BYTES : 34636830
      NUMBER_OF_BYTES-eng: 34636830
    Stream #0:3(ita): Subtitle: subrip (default) (forced)
      title           : Sub Forced
      BPS             : 2
      BPS-eng         : 2
      DURATION        : 00:08:48.100000000
      DURATION-eng    : 00:08:48.100000000
      NUMBER_OF_FRAMES: 2
      NUMBER_OF_FRAMES-eng: 2
      NUMBER_OF_BYTES : 149
      NUMBER_OF_BYTES-eng: 149
    Stream #0:4(ita): Subtitle: subrip
      title           : Sub
      BPS             : 64
      BPS-eng         : 64
      DURATION        : 00:46:43.591000000
      DURATION-eng    : 00:46:43.591000000
      NUMBER_OF_FRAMES: 567
      NUMBER_OF_FRAMES-eng: 567
      NUMBER_OF_BYTES : 22604
      NUMBER_OF_BYTES-eng: 22604
    Stream #0:5(eng): Subtitle: subrip
      title           : Sub
      BPS             : 63
      BPS-eng         : 63
      DURATION        : 00:46:39.966000000
      DURATION-eng    : 00:46:39.966000000
      NUMBER_OF_FRAMES: 616
      NUMBER_OF_FRAMES-eng: 616
      NUMBER_OF_BYTES : 22281
      NUMBER_OF_BYTES-eng: 22281
The second mkv
"c:\Program Files\Serviio\lib\ffmpeg" -i "2x02 - Cani a una sparatoria.mkv"
Input #0, matroska,webm, from '2x02 - Cani a una sparatoria.mkv':
    title           : Daredevil.2x02.Cani.A.Una.Sparatoria.ITA.ENG.720p.WEBMux.AAC.x265-Pir8
    encoder         : libebml v1.3.3 + libmatroska v1.4.4
    creation_time   : 2016-03-20 22:48:59
  Duration: 00:49:36.84, start: 0.000000, bitrate: 1783 kb/s
    Chapter #0:0: start 0.054000, end 2976.841000
      title           : 00:00:00.054
      title           : HEVC
      BPS             : 1588732
      BPS-eng         : 1588732
      DURATION        : 00:49:36.807000000
      DURATION-eng    : 00:49:36.807000000
      NUMBER_OF_FRAMES: 71372
      NUMBER_OF_FRAMES-eng: 71372
      NUMBER_OF_BYTES : 591168935
      NUMBER_OF_BYTES-eng: 591168935
      _STATISTICS_WRITING_APP: mkvmerge v8.7.0 ('All of the above') 64bit
      _STATISTICS_WRITING_APP-eng: mkvmerge v8.7.0 ('All of the above') 64bit
      _STATISTICS_WRITING_DATE_UTC: 2016-03-20 22:48:59
      _STATISTICS_WRITING_DATE_UTC-eng: 2016-03-20 22:48:59
    Stream #0:1(ita): Audio: aac (LC), 48000 Hz, stereo, fltp (default) (forced)
      title           : AAC LLC
      BPS             : 95957
      BPS-eng         : 95957
      DURATION        : 00:49:36.789000000
      DURATION-eng    : 00:49:36.789000000
      NUMBER_OF_FRAMES: 139537
      NUMBER_OF_FRAMES-eng: 139537
      NUMBER_OF_BYTES : 35705711
      NUMBER_OF_BYTES-eng: 35705711
      title           : AAC LLC
      BPS             : 95904
      BPS-eng         : 95904
      DURATION        : 00:49:36.832000000
      DURATION-eng    : 00:49:36.832000000
      NUMBER_OF_FRAMES: 139539
      NUMBER_OF_FRAMES-eng: 139539
      NUMBER_OF_BYTES : 35686361
      NUMBER_OF_BYTES-eng: 35686361
      title           : Sub Forced
      BPS             : 0
      BPS-eng         : 0
      DURATION        : 00:21:29.622000000
      DURATION-eng    : 00:21:29.622000000
      NUMBER_OF_FRAMES: 2
      NUMBER_OF_BYTES : 134
      NUMBER_OF_BYTES-eng: 134
      title           : Sub
      BPS             : 62
      BPS-eng         : 62
      DURATION        : 00:47:57.213000000
      DURATION-eng    : 00:47:57.213000000
      NUMBER_OF_FRAMES: 611
      NUMBER_OF_FRAMES-eng: 611
      NUMBER_OF_BYTES : 22537
      NUMBER_OF_BYTES-eng: 22537
      title           : Sub
      BPS             : 72
      BPS-eng         : 72
      DURATION        : 00:48:11.055000000
      DURATION-eng    : 00:48:11.055000000
      NUMBER_OF_FRAMES: 756
      NUMBER_OF_FRAMES-eng: 756
      NUMBER_OF_BYTES : 26213
      NUMBER_OF_BYTES-eng: 26213
Post Fri Sep 30, 2016 6:38 pm
So it's transcoded because they are h265 videos.
For the audio problem, you might want to try the newest ffmpeg build from zeranoe.
Mass8
Post Sat Oct 01, 2016 7:43 am
Ok i want to try. Where i can find it?
I have klcodec installed, is possible use in serviio this codec?
Post Sat Oct 01, 2016 11:24 pm
Mass8 wrote:Ok i want to try. Where i can find it?
https://ffmpeg.zeranoe.com/builds/
Mass8
Post Sun Oct 02, 2016 8:12 am
Ok. Which version? Which file i must copy?
Post Mon Oct 03, 2016 7:03 pm
Mass8
Post Mon Oct 03, 2016 7:26 pm
ok thanks i try
I've tried it, and the sound problem is solved. Update information dell'mkv remain incorrect, but it is a minor problem (still it says that lasts 7 hours instead of 56 minutes)
