Can't select Contents Type
perfcomp
Post Sun Dec 25, 2016 8:20 pm
Long time Serviio user here, but haven't used it in a few months so some updates have occurred that might have caused my problem. Samsung smart TV (UN40EH5300), MacBook Pro, both with current level of softwares and operating systems. Selecting Allshare Serviio from Source menu is fine, next screen is select Contents Type (Videos, Photos, Music). I can't do anything on this screen. Can't arrow up or down, can't select the highlighted item (Videos is highlighted when the screen comes up). No button works, not the ok button, return button, and can't exit from the screen either (though of course the whole Source menu goes away on it's own in a minute).
I did do extensive searching online and on this forum.
Any ideas?
thank you,
Michael
Post Sun Dec 25, 2016 9:10 pm
Re: Can't select Contents Type
That really sounds like Samsung did something with a firmware update. I rarely use my Samsung to access Serviio, instead using either a Blu Ray player or a Roku. I recall using my Samsung with Serviio a couple of weeks ago with no issues. Of course, I have a different model Samsung than you.
perfcomp
Post Mon Dec 26, 2016 4:24 am
Re: Can't select Contents Type SOLVED
It took me a while to figure out, but I was using the nearly identical looking (to the TV) Blueray remote. Had to use the actual TV remote.
Michael
Post Mon Dec 26, 2016 11:36 pm
For me, that would be a senior moment. Don't know if you can blame that! :lol:
