Resume play not working on 2.2 Pro
eduardok
Post Fri Oct 15, 2021 10:38 am
I was using 1.8 free and video resume play worked fine on my Samsung H, J, and NU series TVs . I just upgraded to 2.2 Pro and now video resume play does not work. Each time I try to watch a video to resume where I left of it starts at the beginning. I searched through this Samsung Section of the forum but was unsuccessful at finding a solution. I used the same video files in 2.2 Pro that worked fine in 1.8 free. I did a fresh install when I upgraded to 2.2 Pro. Any help is greatly appreciated.
Post Fri Oct 15, 2021 4:54 pm
Re: Resume play not working on 2.2 Pro
You might check to see if the profiles assigned to your TVs changed when you updated Serviio. It shouldn't happen, but one can never tell.
eduardok
Post Sat Oct 16, 2021 9:24 pm
Thanks for tge reply. Profiles are correctly select for my Samsung “H”, “J”, and “NU” series tVs. This was a fresh install, uninstalled previous version. I seem to remember somewhere, somebody mentioned MTU size on the home router could have an impact on resuming video. Anybody else have any knowledge of this. Are others having any resume issues with Samsung Profiles with 2.2?
Post Sat Oct 16, 2021 11:48 pm
I've made no changes in my router, and in fact it has no ability to change the setting. My MTU is set to 1492. But there is a setting for uPNP in my router, and I have that enabled. The only two IP addresses that are listed are my two Serviio servers. You might ensure that is enabled on yours.
But it's also possible to change the MTU settings directly on your Serviio computer. For Windows that means making changes in the Registry, so I don't recommend doing so unless you really know what you're doing in there. :D
eduardok
Post Sun Jan 23, 2022 11:59 am
Interesting fact, when I do a clean install of an older free version resume works. When I install 2.2.1 Pro it does not. So, seems like there is something in the Pro that is the issue.
Post Sun Jan 23, 2022 9:34 pm
There is no "Pro" version. Pro simply has some features that are disabled when a license is not installed. When you do a clean install, you're using Pro for free for 15 days. So your clean install is working with "Pro".
