UE40D6500 | Transcoding audio only on mkv
drgz
Post Fri Jul 20, 2012 8:21 pm
Is this possible? I got an mkv with the following audio codec which the TV obviously doesn't support:
VLC gives the following information about the codec:
Stream 1:
Type: Audio
Codec TrueHD Audio
Channels: 3F2M/LFE
48kHz/32bits
Stream 2:
Type: Audio
Codec: A/52 B Audio (aka E-AC3)
Channels: 2
48kHz/32bits
Is there any way to only transcode the audio to some format the TV supports (i.e. A52 Audio (aka AC3) (a52))?
Post Mon Jul 23, 2012 7:42 pm
Re: UE40D6500 | Transcoding audio only on mkv
It should do it already. post the whole ffmpeg -i for the file.
drgz
Post Sun Jul 29, 2012 1:12 pm
Sorry for the late answer, been away for a couple of days. Here is the ffmpeg -i data I got
ffmpeg version N-38622-g1eabd71 Copyright (c) 2000-2012 the FFmpeg developers
built on Mar 7 2012 00:21:47 with gcc 4.6.2
configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-ru
ntime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libope
ncore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger -
-enable-libspeex --enable-libtheora --enable-libvo-aacenc --enable-libvo-amrwben
c --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-
libxvid --enable-zlib
libavutil 51. 42.100 / 51. 42.100
libavcodec 54. 10.100 / 54. 10.100
libavformat 54. 2.100 / 54. 2.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 63.100 / 2. 63.100
libswresample 0. 7.100 / 0. 7.100
Input #0, matroska,webm, from 'D:\torrent\Batman.Begins.2005.1080p.TrueHD.dxva.x
264-FLAWL3SS\SAMPLE.mkv':
creation_time : 2011-01-28 19:29:49
Duration: 00:01:08.14, start: 0.000000, bitrate: 12666 kb/s
Chapter #0.0: start 0.000000, end 68.140000
title : 00:49:43.981
Stream #0:0(eng): Video: h264 (High), yuvj420p, 1920x800 [SAR 1:1 DAR 12:5],
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
Stream #0:1(eng): Audio: truehd, 48000 Hz, 5.1(side), s32 (default)
Stream #0:2(eng): Audio: eac3, 48000 Hz, stereo, s16, 192 kb/s
Stream #0:3(eng): Subtitle: dvd_subtitle (default)
Stream #0:4(fre): Subtitle: dvd_subtitle
Stream #0:5(spa): Subtitle: dvd_subtitle
Stream #0:6(por): Subtitle: dvd_subtitle
Post Sun Jul 29, 2012 8:18 pm
can you try 1.0 and if it fails post detailed log of the playback?
Users browsing this forum: Baidu [Spider] and 15 guests
