Sharing Iphoto
vjk
Post Wed Apr 06, 2011 9:13 pm
Sharing Iphoto
I searched the forum and can't see a similar post - so apologies if it has been posted before.
Just installed Serviio, very easy and quick, worked 1st time connecting a BDP-S760 wirelessly. The problem is at the Mac end as I'm trying to view Iphoto albums. When i go through the console, I cannot select the Iphoto album files as it is 'greyed out', despite allowing sharing in the Iphoto preferences.
I'm sure it something simple which is escaping me. Any ideas? ta
Post Thu Apr 07, 2011 7:02 am
Re: Sharing Iphoto
Serviio has no concept of iPhoto library, it just indexes every .jpg if finds in a folder (and subfolders).
Zip don't have iMac, so it's difficult for him to support iPhoto library
vjk
Post Thu Apr 07, 2011 10:32 am
Re: Sharing Iphoto
Ahhh, I see.
That said, would it not just see all the jpg files within Iphoto, or would I have to save to a seperate folder?
ta
Post Thu Apr 07, 2011 11:45 am
Re: Sharing Iphoto
Yes, just point it to the iPhoto folder. You can also check the log for a list of added files.
doninla
Post Sun Jun 21, 2015 11:59 pm
Re: Sharing Iphoto
Did anyone ever get this to work? I've been unsuccessful. I'm using the Photos app on Mac Yosemite. Pointed Serviio to my "Photos Library" folder, which contains the .jpg files, but no luck.
Users browsing this forum: Google [Bot] and 10 guests
