Jerky sound on SONY BRAVIA 2009 series (KDL-40W5500)
wdata
Post Sun Mar 20, 2011 12:52 pm
I'm not sure is this issue of the TV or ffmpeg, but it may help somebody.
Since v0.5 I've been noticing that the sound for most avi files I have is quite jerky, I mean sounds like being played through old-fashioned noise reduction system based on pumping down the amplification in silent places to decrease the noise and pumping it back up when the music starts. Only this one was broken, and had being restoring the volume very slowly.
Today at last I found some time to find out the reason. In fact the v0.4 works just file, and the only difference is the new keyword in the profile which sets the bitrate, namely "aBitrate=384" while transcoding the avi to mpegts. Surprisingly, when I removed it everything became just fine. The same effect was when I created personal transcoding profile where the audio codec was left intact.
As a bottom line, it not so unequivocally with this forced bitrate... But I don't know on which side.
Post Sun Mar 20, 2011 7:05 pm
Re: Jerky sound on SONY BRAVIA 2009 series (KDL-40W5500)
Well, in fact abitrate sometime is necessary (this is why this option was added in 0.4.2 or 0.5 version) and sometime not (your example).
I also know that zip had made change on abirate processing to a valid value (64k,128k,192k,etc), so abitrate option could probably be removed, to be confirmed.
Could you post ffmpeg -i result of your avi file?
wdata
Post Mon Mar 21, 2011 5:04 am
Sure, in fact it was just another file with mp3 sound, however most noticeable it was with the one below, having, surprise, mono sound:
FFmpeg version 0.6.1, Copyright (c) 2000-2010 the FFmpeg developers
  built on Nov 25 2010 19:03:37 with gcc 4.4.3
  configuration: --prefix=/usr --enable-shared --libdir=/usr/lib --shlibdir=/usr/lib --incdir=/usr/include --disable-stripping --enable-postproc --enable-gpl --enable-pthreads --enable-libtheora --enable-libvorbis --disable-encoder=vorbis --enable-x11grab --enable-runtime-cpudetect --enable-libdc1394 --enable-libschroedinger --enable-decoder=aac --enable-encoder=aac
  libavutil     50.15. 1 / 50.15. 1
  libavcodec    52.72. 2 / 52.72. 2
  libavformat   52.64. 2 / 52.64. 2
  libavdevice   52. 2. 0 / 52. 2. 0
  libswscale     0.11. 0 /  0.11. 0
  libpostproc   51. 2. 0 / 51. 2. 0
[mpeg4 @ 0x95fc670]Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'S03E02.avi':
    ISFT            : VirtualDubMod 1.5.10.2 (build 2540/release)
  Duration: 00:21:42.40, start: 0.000000, bitrate: 1187 kb/s
    Stream #0.0: Video: mpeg4, yuv420p, 640x480 [PAR 1:1 DAR 4:3], 25 tbr, 25 tbn, 25 tbc
    Stream #0.1: Audio: mp3, 44100 Hz, 1 channels, s16, 56 kb/s
    Stream #0.2: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
Btw, do I understand correctly that now when audio track change is not possible the first track is selected by default?
