Nothing to display when accessing serviio via Favorites
mrecio
Post Thu Apr 07, 2011 11:01 pm
I have a Sony 32EX308 TV and just started using serviio. after setting Serviio to use the Bravia Profile everything works flawlessly except for one thing. When I added serviio to my favorites and access it through my favorites it says there is nothing to display, no folders or files of any kind. when I access it through the video menu it shows me the full folder structure and everything is playable.
this is probably a problem with the TV and not serviio but is there anything I can do to make the file structure show when accessing via favorites?
Post Mon Apr 18, 2011 7:42 pm
Re: Nothing to display when accessing serviio via Favorites
mrecio wrote: when I access it through the video menu it shows me the full folder structure and everything is playable.
You are right.
You could not add directly serviio root on favorite,
But you could also not add Serviio --> Video --> Last Added folder too...
..this is probably a Sony limitation or bug.
