Sony NX713 ok but PS3 connection problems
ady
Post Wed Jul 13, 2011 6:10 pm
Hi, new around here and pretty new to DLNA and servers etc so please be gentle with me :) :?
I have a wireless n Netgear 834B router, and everything is connected via a wireless network.
I have a Sony Vaio laptop running Serviio and connection to my Sony NX713 is absolutely brilliant, I can stream movies (Divx file extension but shown as MPEG 2?), MP3's and look at all my photos no problem.
I also have a Sony PS3, it can be seen in the Serviio status tab, although the indicator is amber, and the Serviio icon can be accessed on the PS3. I can access all the files as per the TV but keep losing connection or have a DLNA problem with the message DLNA protcol error 2104.
Any ideas what could be wrong and how I can fix it?
Post Wed Jul 13, 2011 6:43 pm
Re: Sony NX713 ok but PS3 connection problems
Did you select the PS3 profile for the PS3?
ady wrote:Hi, new around here and pretty new to DLNA and servers etc so please be gentle with me :) :?
What profile do you have selected for your Sony TV?
ady wrote:I also have a Sony PS3, it can be seen in the Serviio status tab, although the indicator is amber, and the Serviio icon can be accessed on the PS3. I can access all the files as per the TV but keep losing connection or have a DLNA problem with the message DLNA protcol error 2104.
Can you post your serviio log? It can be found in the directory that you installed Serviio in under the log Folder.
ady
Post Wed Jul 13, 2011 7:08 pm
Serviio correctly recognised both the PS3 and the NX713 and assigned them the right profile.
Attached the log, have edited out the enourmous list of media it found:
2011-07-13 09:23:33,384 INFO [MediaServer] ------------------------------------------------------------------------
2011-07-13 09:23:33,385 INFO [MediaServer] Serviio DLNA media streaming server v 0.5.2 (rev. 4e3210bd9ff3)
2011-07-13 09:23:33,386 INFO [MediaServer] Petr Nejedly 2009-2011
2011-07-13 09:23:33,386 INFO [MediaServer] http://www.serviio.org
2011-07-13 09:23:33,386 INFO [MediaServer] Java 1.6.0_26-Sun Microsystems Inc.
2011-07-13 09:23:33,386 INFO [MediaServer] OS Windows Vista x86 6.0
2011-07-13 09:23:33,386 INFO [MediaServer] File encoding: windows-1252
2011-07-13 09:23:33,386 INFO [MediaServer] ------------------------------------------------------------------------
2011-07-13 09:23:33,542 INFO [RestletServer] Starting Restlet server exposed on localhost:23423
2011-07-13 09:23:33,705 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2011-07-13 09:23:49,055 INFO [ServiioConsole] Starting Serviio Console
2011-07-13 09:23:49,137 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2011-07-13 09:23:51,088 INFO [Messages] Loaded console message bundle for locale: en
2011-07-13 09:23:53,990 INFO [DBSchemaUpdateExecutor] Updating DB schema
2011-07-13 09:24:13,844 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2011-07-13 09:24:14,299 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2011-07-13 09:24:14,511 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2011-07-13 09:24:14,629 INFO [ProfilesDefinitionParser] Added profile 'XBox 360' (id=3)
2011-07-13 09:24:14,716 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2011-07-13 09:24:14,836 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2011-07-13 09:24:14,907 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2011-07-13 09:24:15,093 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2011-07-13 09:24:15,142 INFO [ProfilesDefinitionParser] Added profile 'LG BD player' (id=8)
2011-07-13 09:24:15,425 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV' (id=9)
2011-07-13 09:24:15,887 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player' (id=10)
2011-07-13 09:24:16,012 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera' (id=12)
2011-07-13 09:24:16,101 INFO [ProfilesDefinitionParser] Added profile 'Toshiba Rezga' (id=13)
2011-07-13 09:24:17,148 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2011-07-13 09:24:17,179 INFO [WebServer] Socket buffer set to 65535 bytes
2011-07-13 09:24:17,241 INFO [WebServer] WebServer starting on port 8895
2011-07-13 09:24:20,891 INFO [Device] Created UPnP Device with UUID: 81f02b02-9ef6-3ce6-abcd-30578ac46920, bound address: 192.168.1.8
2011-07-13 09:24:20,937 INFO [CompositeCacheManager] Creating cache manager from config file: /cache.ccf
2011-07-13 09:24:20,947 INFO [ThreadPoolManager] thread_pool.default PoolConfiguration = useBoundary = [true] boundarySize = [2000] maximumPoolSize = [150] minimumPoolSize = [4] keepAliveTime = [300000] whenBlockedPolicy = [RUN] startUpSize = [4]
2011-07-13 09:24:20,952 INFO [CompositeCacheConfigurator] Setting default auxiliaries to null
2011-07-13 09:24:20,952 INFO [CompositeCacheConfigurator] No special CompositeCacheAttributes class defined for key [jcs.default.cacheattributes], using default class.
2011-07-13 09:24:20,954 INFO [CompositeCacheConfigurator] setting defaultCompositeCacheAttributes to [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 100, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-13 09:24:20,954 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.default.elementattributes], using default class.
2011-07-13 09:24:20,955 INFO [CompositeCacheConfigurator] setting defaultElementAttributes to [ IS_LATERAL = true, IS_SPOOL = true, IS_REMOTE = true, IS_ETERNAL = true, MaxLifeSeconds = -1, IdleTime = -1, CreateTime = 1310545460954, LastAccessTime = 1310545460954, getTimeToLiveSeconds() = -1, createTime = 1310545460954 ]
2011-07-13 09:24:20,957 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_resetafterplay.elementattributes], using default class.
2011-07-13 09:24:20,976 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_resetafterplay
2011-07-13 09:24:20,976 INFO [CompositeCache] Constructed cache with name [local_resetafterplay] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-13 09:24:20,976 INFO [CompositeCacheConfigurator] No special ElementAttribute class defined for key [jcs.region.local_default.elementattributes], using default class.
2011-07-13 09:24:20,976 INFO [LRUMemoryCache] initialized LRUMemoryCache for local_default
2011-07-13 09:24:20,976 INFO [CompositeCache] Constructed cache with name [local_default] and cache attributes [ useLateral = true, useRemote = true, useDisk = true, maxObjs = 1000, maxSpoolPerRun = -1, diskUsagePattern = 0 ]
2011-07-13 09:24:20,976 INFO [CompositeCacheConfigurator] Parsed regions [local_resetafterplay, local_default]
2011-07-13 09:24:20,977 INFO [CompositeCacheConfigurator] Finished configuration in 26 ms.
2011-07-13 09:24:20,980 INFO [EventDispatcher] Starting EventDispatcher
2011-07-13 09:24:20,982 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2011-07-13 09:24:20,983 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2011-07-13 09:24:20,991 INFO [RendererSearchSender] Searching for Renderer devices
2011-07-13 09:24:20,991 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2011-07-13 09:24:21,083 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net2 (LAN-Express AS IEEE 802.11g PCI-E Adapter) and address 192.168.1.8, timeout = 0
2011-07-13 09:24:25,252 INFO [RendererManager] Stored a new renderer: uuid='32cd0934-d1cb-48e0-881e-a3a2760f1d85', name = 'Unrecognized device', ipAddress='192.168.1.8', profile = '1'
2011-07-13 09:24:25,783 INFO [RendererManager] Stored a new renderer: uuid='f69f7249-255d-445d-adde-de148e60ab5f', name = 'Unrecognized device', ipAddress='192.168.1.3', profile = '1'
2011-07-13 09:24:26,240 INFO [RendererManager] Stored a new renderer: uuid='00000000-0000-1010-8000-00a096594a3c', name = 'KDL-40NX713', ipAddress='192.168.1.3', profile = '9'
2011-07-13 09:24:26,692 INFO [RendererManager] Stored a new renderer: uuid='62a91074-a36a-4474-86ba-a7f06c42db3b', name = 'Playstation 3', ipAddress='192.168.1.7', profile = '4'
2011-07-13 09:24:30,004 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2011-07-13 09:24:30,681 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2011-07-13 09:24:32,564 INFO [Messages] Loaded console message bundle for locale: en
2011-07-13 09:24:32,682 INFO [UpdateChecker] Checking if a new version is available
2011-07-13 09:24:51,300 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-07-13 09:24:51,302 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-07-13 09:35:28,060 INFO [LibraryAdditionsCheckerThread] Finished looking for newly added files
2011-07-13 09:35:28,300 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2011-07-13 09:35:28,305 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2011-07-13 09:35:29,437 INFO [LibraryAdditionsCheckerThread] Added file '01052009020.jpg' (title: 01052009020) to Library
2011-07-13 09:35:29,830 INFO [LibraryAdditionsCheckerThread] Added file '02052009021.jpg' (title: 02052009021) to Library
2011-07-13 09:35:30,194 INFO [LibraryAdditionsCheckerThread] Added file '02052009023.jpg' (title: 02052009023) to Library
2011-07-13 09:35:30,415 INFO [LibraryAdditionsCheckerThread] Added file '02052009025.jpg' (title: 02052009025) to Library
etc................
Post Wed Jul 13, 2011 7:15 pm
How is your network configured? Are you trying to stream HD or SD? If you are connected wirelessly you could have alot of problems streaming HD.
If you are connecting via wireless, you might be able to increase your connection and let your network better by looking at this thread.
http://forum.serviio.org/viewtopic.php?f=17&t=2439
ady
Post Wed Jul 13, 2011 7:56 pm
I'm not even trying to stream I was just trying to copy some images over to the PS3.
I have in the past, on a free trial :), wirelessly streamed films to my TV from lovefilms.com without any problems, even HD content with maybe the odd little stutter.
I have run the software you have suggested and have a very good connection and have channels 6 + 10 all to myself, my one neighbour using channel one. The only thing it has thrown up which I'm not familiar with is the privacy type being RSNA-CCMP, will have to look that one up.
edit: ignore this comment:
I have however just had a message pop up on my TV:
' Access to the media server is not allowed. It is possible that the system name for this PS3 system, "PS3-153" has not been registered.
Check the settings for the media server. '
This may be because I stopped and restarted Serviio even though I had waited to make sure it was running on my TV.
Having been scouring the internet, I'm wondering whether this may be a PS3 connection issue. Not found any answers or fixes though.
