disconnection issue with sony s570
Post Fri Jul 15, 2011 12:48 pm
Re: disconnection issue with sony s570
Sorry your s570 Blu-ray player. I am in the process of looking for a TV / Monitor to use in a couple different applications, and put TV here instead of BD player.
Castiel
Post Fri Jul 15, 2011 1:06 pm
moltra wrote:Sorry your s570 Blu-ray player. I am in the process of looking for a TV / Monitor to use in a couple different applications, and put TV here instead of BD player.
No worries. I don't think there is any way to change the s570's ability to receive a stream, I am not aware of any time limitations on it anyway.
Post Fri Jul 15, 2011 1:17 pm
You might want to see if you have the most recent revision of the firmware for it. Might also want to see if there is a support forum or contact email that you can let them know there is a problem, so they can work on it.
Castiel
Post Fri Jul 15, 2011 3:46 pm
firmware is up to date. I don't understand what could be the issue as the connect to the bluray player itself is uninterrupted and it only happens after about an hour of playback.
I can only think it has something to do with the length of the playback, but what I have no idea.
Post Fri Jul 15, 2011 4:00 pm
Maybe post on a sony blu-ray forum and see if other people are having the same problem.
Castiel
Post Fri Jul 15, 2011 4:33 pm
moltra wrote:Maybe post on a sony blu-ray forum and see if other people are having the same problem.
Yeah, I'll give it a go.
Castiel
Post Sat Jul 16, 2011 5:14 pm
bit of an update.
I had to remux a film due to multi-languages interfering with playback, used tsMuxeR and found that the remuxed .ts file plays right through, no interruptions at all. So I can only surmise that it is an issue with .mkv files for some reason and not the actual connection.
Post Sun Jul 17, 2011 11:28 am
Thanks for letting us know.
Previous
