MPEG-TS + H.264 not visible on Sony Bravia
kobski
Post Thu Jan 27, 2011 4:04 pm
I am running 0.5. Lot of MPEG-2 files are visible on the TV and play just fine. I have some H.264 files, which are not visible on the TV (Sony 40EX500).
All are recorded DVB. Duration is definitely not 16 hours - but these files seem to have some really strange timestamps. Mediainfo seems to get the duration right.
File is visible with Intel uPnP tools:
URI
http://192.168.211.12:8895/resource/360 ... EG1_L2_ISO
Bitrate
219875
Duration
16:00:32
ProtocolInfo
http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HP_HD_MPEG1_L2_ISO;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000
Resolution
1280x720
Size
12672294536
ffmpeg -i:
Input #0, mpegts, from '2009-12-23, 21.21.mpg':
Duration: 16:00:32.43, start: 28792.732200, bitrate: 1759 kb/s
Program 1
Stream #0.0[0x764](dan): Subtitle: 0x0006
Stream #0.1[0xdac]: Video: h264, yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 50 fps, 50 tbr, 90k tbn, 100 tbc
Stream #0.2[0xdad](dan): Audio: mp2, 48000 Hz, 2 channels, s16, 384 kb/s
mediainfo:
Complete name : 2009-12-23, 21.21.mpg
Format : MPEG-TS
File size : 11.8 GiB
Duration : 2h 23mn
Overall bit rate : 11.7 Mbps
Menu ID : 1 (0x1)
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=4, N=24
Codec ID : 27
Duration : 2h 23mn
Bit rate mode : Variable
Bit rate : 10.8 Mbps
Maximum bit rate : 10.8 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 50.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.234
Stream size : 10.8 GiB (92%)
Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Menu ID : 1 (0x1)
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 3
Duration : 2h 23mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : -1s 106ms
Stream size : 395 MiB (3%)
Language : Danish
Text
ID : 1892 (0x764)-107
Menu ID : 1 (0x1)
Format : Teletext
Language : Danish
What could be the problem?
- Jacob
Post Thu Jan 27, 2011 5:21 pm
Re: MPEG-TS + H.264 not visible on Sony Bravia
Could you enable serviio detailed logging and post the ffmpeg command line (on log file) when you start reading this file? see my signature...
kobski
Post Fri Jan 28, 2011 9:22 am
I am not sure what you mean by "when you start reading this file".
Here is the log when file is added to library:
2011-01-28 07:55:09,887 DEBUG [LibraryAdditionsCheckerThread] Found file 'zorro_3.mpg', checking if it's already in the Library
2011-01-28 07:55:09,887 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item zorro_3.mpg
2011-01-28 07:55:09,893 DEBUG [MediaItemDAOImpl] Media item zorro_3.mpg doesn't exist in DB yet
2011-01-28 07:55:09,893 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2011-01-28 07:55:09,894 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: /../var/lib/mythtv/pretty/by_title/Legenden om Zorro/zorro_3.mpg
2011-01-28 07:55:09,894 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: /../var/lib/mythtv/pretty/by_title/Legenden om Zorro/zorro_3.mpg
2011-01-28 07:55:09,894 DEBUG [ProcessExecutor] Starting ffmpeg -i /../var/lib/mythtv/pretty/by_title/Legenden om Zorro/zorro_3.mpg
2011-01-28 07:55:09,923 DEBUG [MediaItemDAOImpl] Getting file of media item 342
2011-01-28 07:55:09,926 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 342) and extractor EMBEDDED
2011-01-28 07:55:09,929 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 342) and extractor COVER_IMAGE_IN_FOLDER
2011-01-28 07:55:10,030 DEBUG [MediaItemDAOImpl] Getting file of media item 343
2011-01-28 07:55:10,032 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 343) and extractor EMBEDDED
2011-01-28 07:55:10,033 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 343) and extractor COVER_IMAGE_IN_FOLDER
2011-01-28 07:55:10,097 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve thumbnail for file: /../var/lib/mythtv/pretty/by_title/Legenden om Zorro/zorro_3.mpg
2011-01-28 07:55:10,097 DEBUG [ProcessExecutor] Starting ffmpeg -i /../var/lib/mythtv/pretty/by_title/Legenden om Zorro/zorro_3.mpg -an -ss 120 -vframes 1 -f image2 pipe:
2011-01-28 07:55:10,134 DEBUG [MediaItemDAOImpl] Getting file of media item 344
2011-01-28 07:55:10,136 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 344) and extractor EMBEDDED
2011-01-28 07:55:10,137 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 344) and extractor COVER_IMAGE_IN_FOLDER
2011-01-28 07:55:10,238 DEBUG [MediaItemDAOImpl] Getting file of media item 345
2011-01-28 07:55:10,240 DEBUG [MetadataDescriptorDAOImpl] Reading MetadataDescriptor for MediaItem (id = 345) and extractor EMBEDDED
And here is the log when I navigate to the file on the TV:
2011-01-28 07:59:27,064 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 947 and profile Sony Bravia TV
2011-01-28 07:59:27,065 DEBUG [FolderDAOImpl] Getting number of VIDEO sub-folders and media items in folder 28
2011-01-28 07:59:27,067 DEBUG [LocalContentCacheDecorator] Stored entry in the cache (local_default), returning it
2011-01-28 07:59:27,082 DEBUG [ServiceControlRequestHandler] Returning OK SOAP message
But the TV does not display any files inside the folder.
kobski
Post Wed Feb 02, 2011 9:42 am
Any suggestions on how I can move on with this problem?
Can I make some changes to the Bravia profile?
Thanks,
Jacob
Post Mon Jul 25, 2011 9:39 am
Do you still have problems with these files?
AVC_TS_HP_HD_MPEG1_L2_T
It seems that 2010 model didn't support MP2 audio with h264 video under mpeg2ts stream.
Could you remove lines with AVC_TS_HP_HD_MPEG1_L2_T under Sony Bravia profile and add this line
<Matches container="mpegts" vCodec="h264" aCodec="mp2" /> into the proper <video> section ?
             <!-- Remux all other h264 video on MPEG-TS stream with ac3 audio transcoding -->
             <!--  expected profile AVC_TS_MP_HD_AC3_ISO -->
                <!-- if audio different to ac3, must be transcoded -->
                <Matches container="mpegts" aCodec="aac" />
                <Matches container="mpegts" aCodec="mp3" />
                <Matches container="mpegts" aCodec="dca" />
                <Matches container="mpegts" aCodec="lpcm" />
                <Matches container="mpeg" aCodec="dca" />
