Unable to play file
theoneofgod
Post Tue Jul 26, 2011 10:40 am
Unable to play file
When trying to play this file over my network, i get something like "unable to connect to server, try again"
Is there anything i can do to make it play?
Dead Mans Shoes.mkv.txt
MediaInfo
(7.97 KiB) Downloaded 849 times
Post Tue Jul 26, 2011 12:15 pm
Re: Unable to play file
Thanks, but what is your DLNA renderer model, what is the profile used?
Could you enable detailed logging (see signature) and post the log file when you start to play this file?
Also post "ffmpeg -i" of this file.
theoneofgod
Post Tue Jul 26, 2011 12:17 pm
I'm not able to run the file atm, but i'm using Sony Bravia profile unmodified.
Post Tue Jul 26, 2011 12:24 pm
theoneofgod wrote:... but i'm using Sony Bravia profile unmodified.
So this file must be remuxed into mpeg2ts and DTS audio transcoded into AC3...check log file to know if ffmpeg crashed.
theoneofgod
Post Tue Jul 26, 2011 3:11 pm
How do you suggest i do that?
Post Tue Jul 26, 2011 3:20 pm
Nothing to do, I simply said that according to the profile selected (Sony Bravia), servio/ffmpeg will transcode this file into MPEG2TS/ac3.
And I suggest you to enable detailed logging and check the log file to found when ffmpeg start transcoding and check if it crashed.
theoneofgod
Post Tue Jul 26, 2011 3:58 pm
Here you go.
log.txt
log
(126.78 KiB) Downloaded 783 times
Post Tue Jul 26, 2011 6:50 pm
Could you execute locally this command line and post here the ffmpeg log ouput:
ffmpeg.exe -i "C:\Documents and Settings\Administrator\My Documents\My Videos\720p\Dead Mans Shoes.wmv" -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 0 -map 0:0 -map 0:1 -sn -f mpegts TEST.ts
EDIT: This is not the same file you provided MediaInfo at the first post, mkv or wmv ?!
theoneofgod
Post Tue Jul 26, 2011 7:31 pm
The file is mkv, i renamed to wmv for another purpose. I ran the command, it says "unable to find suitable output format for ffmpeg.exe"
Post Wed Jul 27, 2011 7:27 am
theoneofgod wrote:The file is mkv, i renamed to wmv for another purpose. I ran the command, it says "unable to find suitable output format for ffmpeg.exe"
The output is not correct, you're probably missing quotes behind the output file names.
Try this
ffmpeg.exe -i "C:\Documents and Settings\Administrator\My Documents\My Videos\720p\Dead Mans Shoes.wmv" -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 0 -map 0:0 -map 0:1 -sn -f mpegts "C:\Documents and Settings\Administrator\My Documents\My Videos\720p\Dead Mans Shoes.ts"
Could you also post ffmpeg.exe -i "C:\Documents and Settings\Administrator\My Documents\My Videos\720p\Dead Mans Shoes.wmv" result
theoneofgod
Post Wed Jul 27, 2011 11:57 am
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "C:\Documents and Settings\Admi
ans Shoes.ts"
686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[matroska,webm @ 013ed530] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1)
-> 500.00 (500/1)
Input #0, matroska,webm, from 'C:\Documents and Settings\Administrator\My Docume
nts\My Videos\720p\Dead Mans Shoes.wmv':
  Duration: 01:26:29.99, start: 0.000000, bitrate: N/A
    Stream #0.0(eng): Video: h264, yuv420p, 1268x720, PAR 1:1 DAR 317:180, 25 fp
s, 500 tbr, 1k tbn, 50 tbc
    Stream #0.1(eng): Audio: dca, 48000 Hz, 0 channels, s16
    Stream #0.2(eng): Audio: vorbis, 48000 Hz, stereo, s16
      title           : Commentary
    Stream #0.3(eng): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.4(eng): Subtitle: [0][0][0][0] / 0x0000
      title           : HOH
[ac3 @ 040a0820] No channel layout specified. The encoder will guess the layout,
 but it might be incorrect.
[ac3 @ 040a0820] invalid channel layout
Output #0, mpegts, to 'C:\Documents and Settings\Administrator\My Documents\My V
ideos\720p\Dead Mans Shoes.ts':
    Stream #0.0(eng): Video: [0][0][0][0] / 0x0000, yuv420p, 1268x720 [PAR 1:1 D
AR 317:180], q=2-31, 90k tbn, 25 tbc
    Stream #0.1(eng): Audio: ac3, 48000 Hz, 0 channels, flt, 384 kb/s
Stream mapping:
  Stream #0.0 -> #0.0
  Stream #0.1 -> #0.1
Error while opening encoder for output stream #0.1 - maybe incorrect parameters
such as bit_rate, rate, width or height
686-mingw32-
[matroska,webm @ 013ed500] Estimating duration from bitrate, this may be inaccur
ate
-> 500.00 (500/1)
      title           : Commentary
      title           : HOH
nistrator\My Documents\My Videos\720p\Dead Mans Shoes.mkv"
686-mingw32-
ate
-> 500.00 (500/1)
nts\My Videos\720p\Dead Mans Shoes.mkv':
      title           : Commentary
      title           : HOH
Post Wed Jul 27, 2011 12:40 pm
There were something strange with the dts audio track--> 0 channels:
Could you download the latest ffmpeg windows build here, replace the ffmpeg.exe in the "./serviio/lib" folder, (make a backup), and retry the same command line "ffmpeg -i"
theoneofgod
Post Wed Jul 27, 2011 1:29 pm
Using latest ffmpeg.exe
ffmpeg version N-31627-g9c2651a, Copyright (c) 2000-2011 the FFmpeg developers
  built on Jul 23 2011 15:02:13 with gcc 4.6.1
  configuration: --enable-gpl --enable-version3 --enable-memalign-hack --enable-
runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libo
pencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --
enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger
 --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enabl
e-libx264 --enable-libxavs --enable-libxvid --enable-zlib
  libavcodec   53.  9. 0 / 53.  9. 0
  libavfilter   2. 27. 3 /  2. 27. 3
  libpostproc  51.  2. 0 / 51.  2. 0
[matroska,webm @ 01C8B480] max_analyze_duration 5000000 reached at 5000000
[matroska,webm @ 01C8B480] Estimating duration from bitrate, this may be inaccur
ate
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1268x720, PAR 1:1 DAR 317:180
, 25 fps, 25 tbr, 1k tbn, 50 tbc (default)
    Stream #0.1(eng): Audio: dca, 48000 Hz, 6 channels, s16 (default)
      title           : Commentary
      title           : HOH
Edit:
This is working with the latest ffmpeg.exe ffmpeg.exe -i "C:\Documents and Settings\Administrator\My Documents\My Videos\720p\Dead Mans Shoes.wmv" -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec ac3 -ab 384k -ac 0 -map 0:0 -map 0:1 -sn -f mpegts "C:\Documents and Settings\Administrator\My Documents\My Videos\720p\Dead Mans Shoes.ts"
Post Wed Jul 27, 2011 1:34 pm
theoneofgod wrote:Using latest ffmpeg.exe
Ok its better : Stream #0.1(eng): Audio: dca, 48000 Hz, 6 channels, s16 (default)
So could you retry the same command line with the latest ffmpeg.exe ?
Could you try with serviio?
Post Wed Jul 27, 2011 1:35 pm
theoneofgod wrote:This is working with the latest ffmpeg.exe ...
So retry with serviio...
theoneofgod
Post Wed Jul 27, 2011 2:22 pm
Yeah it works now, but more problems occured. I can't pause and play, forward, etc, it says playback unavailable.
Thanks btw, great support.
