Can't play a file
egomezpe
Post Sun Sep 25, 2011 8:15 am
Can't play a file
edit: the TV doesn't play the file from a USB, so the problem is not form Serviio. How can I make that Serviio transcode the file?
HI, I can't play a file. I'm using Serviio 6.0 in Windows 7 32 bits in a Sony KDL-26EX320.
The information from ffmpeg is:
nfig
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
Input #0, avi, from 'e:\video\peliculas\A.Todo.Gas.5.DVDrip.Castellano.avi':
encoder : VirtualDubMod 1.5.4.1 (build 2178/release)
IAS1 : Espanol
Duration: 02:05:00.04, start: 0.000000, bitrate: 1902 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 720x304 [PAR 1:1 DAR 45:19], 25 tbr, 25
tbn, 25 tbc
Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s
and from mediainfo:
Complete name : E:\Video\Peliculas\A.Todo.Gas.5.DVDrip.Castellano.avi
Format : AVI
File size : 1,66GIB
Duration : 2h 5min.
Overall bit rate : 1 902Kbps
Writing application : VirtualDubMod 1.5.4.1 (build 2178/release)
Writing library : VirtualDubMod build 2178/release
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 1
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Personlizado
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 2h 5min.
Bit rate : 1 511Kbps
Width : 720pixeles
Height : 304pixeles
Display aspect ratio : 2,35:1
Frame rate : 25,000fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8bits
Scan type : Progresivo
Bits/(Pixel*Frame) : 0.276
Stream size : 1,32GIB (79%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 2h 5min.
Bit rate mode : Constante
Bit rate : 384Kbps
Channel(s) : 6canales
Sampling rate : 48,0KHz
Bit depth : 16bits
Stream size : 343MB (20%)
Alignment : Dividir a través entrelazado
Interleave, duration : 96 ms (2,40fotogramas de video)
Interleave, preload duration : 96 ms
Language : Español
NX3
Post Sun Sep 25, 2011 10:06 am
Re: Can't play a file
If you manually set the profile from Sony Bravia 2011 to Sony Bravia it would be transcoded but then all AVI's would be transcoded. If the file doesn't play via USB as you pointed out its a limitation of the set so to leave the correct profile set on serviio you could convert it to a format the set will play.
