.mkv file wont play. playstation.
oddi
Post Sat Oct 08, 2011 2:16 pm
I use the default playstation profile but this file won't play. Why?
Is it the mkv or the profile?
Unique ID                                : 0 (0x0)
Complete name                            : /Users/oddi/Movies/Serier/Game of Thrones/Sesong 1/Game.of.Thrones.S01E05.mkv
File size                                : 1.46 GiB
Duration                                 : 54mn 14s
Overall bit rate                         : 3 847 Kbps
Movie name                               : Game of Thrones - S01E05
Encoded date                             : UTC 2010-02-22 21:41:29
Writing application                      : no_variable_data
Writing library                          : no_variable_data
Format profile                           : High@L3.1
Format settings, ReFrames                : 3 frames
Duration                                 : 54mn 14s
Bit rate                                 : 3 454 Kbps
Bits/(Pixel*Frame)                       : 0.156
Stream size                              : 1.28 GiB (88%)
Writing library                          : x264 core 85 r1442tw
Encoding settings                        : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=30 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=6 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=0 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=3454 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Duration                                 : 54mn 14s
Bit rate                                 : 384 Kbps
Stream size                              : 149 MiB (10%)
Thanks for all help! :)
Post Sat Oct 08, 2011 6:24 pm
Re: .mkv file wont play. playstation.
Seems good, that could be "Encoding settings" or mkv container.
Try to remux into m2ts file woth TsMuxer tool.
