[SOLVED] Sony BDP-480 and Nikon D7000 videos
gromitcalimero
Post Tue Sep 27, 2011 8:25 pm
Hi all !
I have some videos from my nikon D7000 camera and I would like transcode them in order to see these files with my Sony Blu-ray player (BDP-S480). I tried to see my videos with serviio version 0.6.0.1 but without success. I had a warning trace in log file and my TV displayed nothing (black screen with wait logo) without error message.
Content of my serviio.log :
2011-09-26 22:07:46,406 WARN  [VideoExtractionStrategy] Couldn't resolve H264 profile/level/ref_frames for file '_DSC0873.MOV' because Sequence parameter set header was not recognized
ffmpeg -i _DSC0873.MOV command line result :
nfig
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'c:\temp\serviio\_DSC0873.MOV':
    major_brand     : qt
    minor_version   : 537331968
    compatible_brands: qt  niko
    creation_time   : 2011-06-26 18:01:59
  Duration: 00:00:59.26, start: 0.000000, bitrate: 20585 kb/s
    Stream #0.0(eng): Video: h264 (High), yuvj420p, 1920x1080 [PAR 1:1 DAR 16:9]
, 19039 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
    Stream #0.1(eng): Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
Any idea?
Thanks in advance for your help !
Post Tue Sep 27, 2011 10:26 pm
Re: Sony BDP-480 and Nikon D7000 videos
This means the H264 level/profile could not be read as the header seems to be dodgy. It should still add the file to the library though and not to try adding it again. Is that what you're seeing?
Post Wed Sep 28, 2011 7:22 am
Could you enable detailed logging (see signature link) and post here the the log file section when your start this file?
Could you also provide MediaInfo result of this file?
gromitcalimero
Post Thu Sep 29, 2011 8:59 pm
Thanks for replies,
log file (DEBUG level) with first occurence of "_DSC0873.MOV" :
2011-09-29 22:45:57,031 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file _DSC0873.MOV
2011-09-29 22:45:57,031 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file _DSC0873.MOV: AVC_TS_HD_50_LPCM_T
2011-09-29 22:45:57,031 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2011-09-29 22:45:57,031 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/vnd.dlna.mpeg-tts,Date: Thu, 29 Sep 2011 20:45:57 GMT,Server: Windows XP, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.0.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_OP=10;DLNA.ORG_CI=1;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2011-09-29 22:45:57,062 DEBUG [ResourceTransportRequestHandler] GET /resource/598/MEDIA_ITEM/AVC_TS_HD_50_LPCM_T$1 HTTP/1.1, headers = [User-Agent: UPnP/1.0 DLNADOC/1.50,Host: 192.168.1.10:8895,Accept: */*,TimeSeekRange.dlna.org: npt=0-,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0",getcontentFeatures.dlna.org: 1,Pragma: getIfoFileURI.dlna.org,transferMode.dlna.org: Streaming]]
2011-09-29 22:45:57,062 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.6
2011-09-29 22:45:57,062 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.1.6, Profile=Sony BD Player'
2011-09-29 22:45:57,062 DEBUG [ResourceTransportRequestHandler] Request for resource 598 and type 'MEDIA_ITEM' received
2011-09-29 22:45:57,062 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 598 (local)
2011-09-29 22:45:57,062 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 598)
2011-09-29 22:45:57,062 DEBUG [VideoDAOImpl] Reading a Video (id = 598)
2011-09-29 22:45:57,062 DEBUG [VideoDeliveryEngine] Delivering item '598' for client 'IPAddress=/192.168.1.6, Profile=Sony BD Player'
2011-09-29 22:45:57,062 DEBUG [VideoDeliveryEngine] Delivering file '_DSC0873.MOV' using transcoding
2011-09-29 22:45:57,062 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.6, Profile=Sony BD Player'
2011-09-29 22:45:57,078 DEBUG [MediaItemDAOImpl] Getting file of media item 598
2011-09-29 22:45:57,078 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: C:\Temp\serviio\_DSC0873.MOV
2011-09-29 22:45:57,078 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i C:\Temp\serviio\_DSC0873.MOV -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec copy -map 0:0 -map 0:1 -sn -f mpegts C:\WINDOWS\TEMP\Serviio\transcoding-temp-598-MPEG2TS.stf
2011-09-29 22:45:57,093 DEBUG [WebServer] Incoming connection from /192.168.1.6:57742
2011-09-29 22:45:57,093 WARN  [DiscoverySSDPMessageListener] Problem during DiscoverySSDPMessageListener, will try again
java.net.SocketException: socket closed
   at java.net.PlainDatagramSocketImpl.receive0(Native Method)
   at java.net.PlainDatagramSocketImpl.receive(Unknown Source)
   at java.net.DatagramSocket.receive(Unknown Source)
   at org.serviio.util.MultiCastUtils.receive(MultiCastUtils.java:91)
   at org.serviio.upnp.discovery.DiscoverySSDPMessageListener.listenForMulticastMessages(DiscoverySSDPMessageListener.java:120)
   at org.serviio.upnp.discovery.DiscoverySSDPMessageListener.run(DiscoverySSDPMessageListener.java:94)
   at java.lang.Thread.run(Unknown Source)
MediaInfo result :
Complete name                    : C:\Temp\serviio\_DSC0873.MOV
Format                           : MPEG-4
Format profile                   : QuickTime
Codec ID                         : qt
File size                        : 145 MiB
Duration                         : 59s 184ms
Overall bit rate                 : 20.6 Mbps
Encoded date                     : UTC 2011-06-26 18:01:59
Tagged date                      : UTC 2011-06-26 18:01:59
NCDT                             : NCTG
Format profile                   : High@L4.0
Format settings, CABAC           : Yes
Format settings, ReFrames        : 2 frames
Format settings, GOP             : M=3, N=10
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Bit rate mode                    : Variable
Bit rate                         : 19.0 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Frame rate mode                  : Constant
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.383
Stream size                      : 134 MiB (92%)
Language                         : English
Transfer characteristics         : BT.470-6 System M, NTSC, FTC 73.682, BT.1700 625 PAL, BT.1700 625 SECAM
Matrix coefficients              : BT.470-6 System B, BT.470-6 System G, BT.601-6 625, BT.1358 625, BT.1700 625 PAL, BT.1700 625 SECAM, IEC 61966-2-4 601
Format                           : PCM
Format settings, Endianness      : Little
Format settings, Sign            : Signed
Codec ID                         : sowt
Bit rate                         : 1 536 Kbps
Channel(s)                       : 2 channels
Bit depth                        : 16 bits
Stream size                      : 10.8 MiB (7%)
Language                         : English
Post Fri Sep 30, 2011 7:28 am
gromitcalimero wrote:[ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i C:\Temp\serviio\_DSC0873.MOV -y -vcodec copy -vbsf h264_mp4toannexb -copyts -acodec copy -map 0:0 -map 0:1 -sn -f mpegts C:\WINDOWS\TEMP\Serviio\transcoding-temp-598-MPEG2TS.stf
Format : AVC
Format : PCM
OK thanks,
So this is a high video bitrate stream, with high audio bitrate audio stream too: MP4 / HS264 / LPCM : you might have stuttering problems.
Audio must be transcoded, because Sony BDP doesn't support that audio format into MP4 container.
So Audio must be transcoded into AC3 and video copied into MPEG2TS container:
Could you edit the profiles.xml file, "Sony BD Player" Profile section, an modify the first <Video> element like this:
         <Video targetContainer="mpegts" targetACodec="ac3" aBitrate="320">
            <!-- FFmpeg cannot currently remux dts audio properly so it must be transcoded, but all other audio is left alone -->
            <Matches container="ogg" vCodec="mpeg4" />
            <Matches container="mp4" aCodec="lpcm" />
gromitcalimero
Post Tue Oct 04, 2011 9:24 pm
Thanks a lot, it works :D
Post Sun Oct 09, 2011 5:05 pm
Re: [SOLVED] Sony BDP-480 and Nikon D7000 videos
added to the code base, ta
Users browsing this forum: Baidu [Spider] and 1 guest
