Sony KDL-32EX525 can't see Serviio
amonite
Post Tue Oct 11, 2011 1:29 am
I have a D-link router which is wired to the TV's ethernet. The TV connects to the internet without problems.
Serviio is on my PC which connects wirelessly. I can ping the TV. Serviio finds it well. But the TV doesn't see it...
Networking is not my forte, so bear with me...
Router IP: 192.168.0.1
PC running XP, IP: 192.168.0.102
TV IP: 192.168.0.100
Running netstat -an |find /i "listening", this is line is in the output among others:
TCP 0.0.0.0:8895 0.0.0.0:0 LISTENING
On Serviio console, I entered the PC's IP in Network Settings.
The server is running, I don't know where else to look!
Any help?
Thanks!
Post Tue Oct 11, 2011 3:42 am
Re: Sony KDL-32EX525 can't see Serviio
are the correct ports open in your firewall?
My device doesn't see Serviio
This could be caused by you having multiple IP addresses on the machine and Serviio binding to a wrong one. Insert IP address of the machine running Serviio into 'Bound IP address' field in Network Settings section in the console or pass system variable serviio.boundAddr including the IP address when starting the server.
Also make sure that TCP port 8895 and UDP 1900 are open in your firewall.
If you are on a Linux based OS, make sure you set up multicast routes properly.
If on Windows, you can push Serviio service down in starting order.
Post Tue Oct 11, 2011 7:29 am
did you restart the serviio service after adding the bound IP address ?
Post Tue Oct 11, 2011 7:41 am
On Serviio console:
- Clear the device list by removing each devices --> Save
- Stop Serviio service (exit serviio console)
On Sony TV menu:
- Clear all server list :Home -> Network -> Server Display Settings (options -> delete)
- Restart serviio service.
- Check on serviio console (refresh)
- Check on Sony Menu TV.
amonite
Post Tue Oct 11, 2011 11:59 am
Illico wrote:On Serviio console:
On Sony TV menu:
Thanks! Doing this step by step worked like a charm. :)
Now, one more thing: I don't see AVI files - what could I be missing regarding transcoding?
Thanks everyone
Post Tue Oct 11, 2011 2:42 pm
amonite wrote:Now, one more thing: I don't see AVI files - what could I be missing regarding transcoding?
Check on Serviio console Which profile is selected? "Sony Bravia TV" or "Sony Bravia TV 2011" ?
amonite
Post Tue Oct 11, 2011 3:19 pm
Sony Bravia TV 2011, auto detected.
