Video not playing
BrightStar
Post Sat Oct 29, 2011 7:48 pm
Video not playing
Hiya
I have a Sony TV 40CX523 and I am using Serviio on my PC to watch videos on the TV.
Some Bluray rips play absolutely fine but some of them are not showing videos and jerky audios.
Here is info from one of the file
nfig
libavutil 51. 11. 0 / 51. 11. 0
libavcodec 53. 8. 0 / 53. 8. 0
libavformat 53. 6. 0 / 53. 6. 0
libavdevice 53. 2. 0 / 53. 2. 0
libavfilter 2. 25. 0 / 2. 25. 0
libswscale 2. 0. 0 / 2. 0. 0
Unique ID                        : 193647323474955218731462938667885254753 (0x91AF1E2E3DC3C0E89B9078E47DE3D861)
Complete name                    : X:\Videos\Video1.mkv
Format                           : Matroska
File size                        : 7.91 GiB
Duration                         : 2h 19mn
Overall bit rate                 : 8 123 Kbps
Encoded date                     : UTC 2011-10-22 19:17:55
Writing application              : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library                  : libebml v1.2.1 + libmatroska v1.1.1
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 3 frames
Format settings, GOP             : M=4, N=50
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 2h 19mn
Bit rate mode                    : Variable
Bit rate                         : 6 653 Kbps
Maximum bit rate                 : 40.0 Mbps
Width                            : 1 920 pixels
Height                           : 816 pixels
Display aspect ratio             : 2.35:1
Frame rate                       : 24.000 fps
Bits/(Pixel*Frame)               : 0.177
Stream size                      : 6.28 GiB (79%)
Writing library                  : x264 core 116 r2074 2641b9e
Encoding settings                : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=1 / weightp=0 / keyint=50 / keyint_min=5 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=6653 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=40000 / vbv_bufsize=30000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Language                         : English
Color primaries                  : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
Transfer characteristics         : BT.709-5, BT.1361
Matrix coefficients              : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
Format                           : DTS
Format/Info                      : Digital Theater Systems
Codec ID                         : A_DTS
Duration                         : 2h 19mn
Bit rate                         : 1 510 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 24 bits
Stream size                      : 1.47 GiB (19%)
Text
Format                           : UTF-8
Codec ID                         : S_TEXT/UTF8
Codec ID/Info                    : UTF-8 Plain Text
Language                         : English
Menu
00:00:00.000                     : en:00:00:00.000
00:08:14.917                     : en:00:08:14.917
00:12:49.292                     : en:00:12:49.292
00:19:28.375                     : en:00:19:28.375
00:25:41.583                     : en:00:25:41.583
00:30:05.208                     : en:00:30:05.208
00:37:33.625                     : en:00:37:33.625
00:42:07.292                     : en:00:42:07.292
00:50:31.375                     : en:00:50:31.375
00:55:00.625                     : en:00:55:00.625
01:03:07.667                     : en:01:03:07.667
01:10:26.375                     : en:01:10:26.375
01:13:53.167                     : en:01:13:53.167
01:23:07.167                     : en:01:23:07.167
01:25:49.375                     : en:01:25:49.375
01:30:50.625                     : en:01:30:50.625
01:43:46.292                     : en:01:43:46.292
01:49:19.917                     : en:01:49:19.917
01:56:12.792                     : en:01:56:12.792
02:01:32.708                     : en:02:01:32.708
02:09:22.125                     : en:02:09:22.125
02:16:08.208                     : en:02:16:08.208
Currently using Windows 7 x32.
Any help would be appreciated how to play this video smoothly on my TV.
Cheers
patters
Post Mon Oct 31, 2011 6:37 pm
Re: Video not playing
That doesn't look like the version of ffmpeg that Serviio normally uses. Are you on Linux. If so, try updating to the newest version that your distro's package manager offers or, if you are able, try compiling the version from the download page.
BrightStar
Post Mon Oct 31, 2011 9:09 pm
Thanks mate.
Would it be possible to guide me where to download the latest version of the ffmpeg? I have tried latest static build from here http://ffmpeg.zeranoe.com/builds/ but havent got a clue what to do with the download file.
It has to be compiled or I can download precompiled version from somewhere?
patters
Post Mon Oct 31, 2011 10:26 pm
It's a bit of a fiddle if you're not used to compiling software, on account of the various libraries involved. It's a good idea for a tutorial blog post, so I'll try to put something together soon.
Post Tue Nov 01, 2011 11:26 am
I think this is the FFmpeg distributed with the Windows version of Serviio.
Users browsing this forum: Google [Bot] and 5 guests
