PS3 Format Not Supported?
mrforsythexeter
Post Fri Oct 28, 2011 7:38 pm
This is not even listed as a movie. It was shown under folders but when asked to be played reported that it couldnt!
Format : AVI
File size : 1.37 GiB
Duration : 1h 59mn
Overall bit rate : 1 636 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
==Video
Format : MPEG-4 Visual
Format profile : Advanced Simple@L5
Format settings, BVOP : 3
Format settings, QPel : Yes
Format settings, GMC : 3 warppoints
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 59mn
Bit rate : 1 243 Kbps
Width : 720 pixels
Height : 304 pixels
Display aspect ratio : 2.35:1
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.227
Stream size : 1.04 GiB (76%)
Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01)
==Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 2000
Duration : 1h 59mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 329 MiB (23%)
Alignment : Split accross interleaves
Interleave, duration : 40 ms (1.00 video frame)
Interleave, preload duration : 500 ms
WildRushSykes
Post Fri Oct 28, 2011 10:26 pm
Re: PS3 Format Not Supported?
This maybe your problem as my PS3 hates format settings like that everything else looks fine
mrforsythexeter
Post Sat Oct 29, 2011 8:07 am
Is there something I can add to the profile to sort this?
Post Wed Nov 02, 2011 10:26 am
I think Format settings, QPel : Yes not supported.
mrforsythexeter wrote:Is there something I can add to the profile to sort this?
Only force to transcoding all AVI files with MPEG4 video into meg2video:
Add this line in the first <video> section of the PS3 profile (id=4")
<Matches container="avi" vCodec="mpeg4" />
Topic moved to Sony section...
