incorrect display aspect on Sony Bravia
Post Sun Nov 20, 2011 1:56 pm
Re: incorrect display aspect on Sony Bravia
zip wrote:do you have any content that is more than 1280 wide? would the command still stand or would it actually downscale to 1280?
No 1280 samples with bad DAR value.
In fact the (1) command will downscale to 1280.
So the solution:
- (a) if resolution not HD (720), upscale to a HD resolution with the original source dar, otherwise no need to upscale keep the original source dar.
- (b) padding to the 16/9 display ratio
- (c) change the DAR=4/3
note: to limit the cpu overhead, (a) could be skipped (but some pixels will be lost on left and right side)
    H < 720 With DAR >= 16:9 ==> (a)+(b)+(c)
"-vf "scale=1280:1280/dar/sar","pad=1280:720:(ow-iw)/2:(oh-ih)/2:black","setdar=4:3"
    H < 720 With DAR < 16:9 and W < 720 ==> (a)+(b)+(c)
"-vf "scale=720*dar*sar:720","pad=1280:720:(ow-iw)/2:(oh-ih)/2:black","setdar=4:3"
    720 < H < 1080 With DAR > = 16:9 ==> (b)+(c)
-vf "pad=iw:iw/16*9:(ow-iw)/2:(oh-ih)/2:black","setdar=4:3"
    720 < H < 1080 With DAR < 16:9 ==> (b)+(c)
-vf "pad=ih*16/9:ih:(ow-iw)/2:(oh-ih)/2:black","setdar=4:3"
Post Sun Nov 20, 2011 9:36 pm
I don't understand the preconditions (W,H) in your examples, there are missing examples for height less than 720. I think we'll go with b+c only. Could you edit the post with some real resolution and DAR examples?
Thanks for this btw.
Post Mon Nov 21, 2011 5:21 pm
zip wrote:I don't understand the preconditions (W,H) in your examples, there are missing examples for height less than 720.
Oups make some mistakes...post edited.
zip wrote:I think we'll go with b+c only.
OK, this is the same option than PS3 Media Server with Mencoder ( We forget the 16 pixels missing at the moment).
zip wrote:Could you edit the post with some real resolution and DAR examples?
Sorry, I need time...I will see.
Post Wed Nov 23, 2011 8:58 pm
Look at this viewtopic.php?f=11&t=2956&p=27400#p27400
Previous
