Serviio 0.6.2 don't see my BDP-S186 or the other way around
Rico1975
Post Sat Jun 02, 2012 7:10 am
In serviio i can't find my sony blueray S-186 My pc is wired to router and so is the blueray and both with a reserved ip. I can ping my blueray from the pc, and the blueray shows no network errors, and connects to the internet based stuff with no problems.
Serviio runs fine too, can find it on all other pc's and on my HTC smartphone when it connects via wlan to my router. But the blueray can't find any mediaserver on the local network at all, have tried on all pc's and htc with DLNA servers.
All devices has the latest firmware/drivers
Any ideas what is wrong? I'm all out of good ideas
insane822
Post Sun Jun 03, 2012 1:39 am
Re: Serviio 0.6.2 don't see my BDP-S186 or the other way aro
I could be wrong, but what I found online says this model does not support DLNA. :(
http://www.digitalversus.com/blu-ray-pl ... /test.html
Rico1975
Post Mon Jun 04, 2012 2:39 pm
insane822 wrote:I could be wrong, but what I found online says this model does not support DLNA. :(
According to the usermanual, it should be possible after FW upgrade, and the supporter at Sony I'm emailing with too to solve this problem has not mentioned it is not possible at this state, so believe it should be possible.
Post Mon Jun 04, 2012 3:53 pm
Confirm DLNA is not supported on S186/S185 devices.
http://www.sony.co.uk/product/blu-ray-d ... nicalSpecs
Rico1975
Post Thu Jun 07, 2012 3:05 am
http://www.sony.dk/product/blu-ray-disc ... nicalSpecs
This is my model from sony's danish site, confirming it does via update
