MP4 on PS3 not working
hasma
Post Tue Aug 21, 2012 3:01 pm
THe serviio server show on ps3 the mp4 with invalid format. But others DLNA server have not this problem. I use a Synology DS411. With the default Media Server ps3 has no problems. I changed the PS3 Profile to Gerneric DLNA Profile but the same results. The other Devices have no Problem with Serviio but we use the PS3 for the Main Screen and if it is not possible to work PS3 and MP4 so this is for us a nogo.
What can we do ? In 10 days the test license expires and if until then the problem is not solved we have to deinstall serviio.
greetings hasma
Post Tue Aug 21, 2012 6:22 pm
Re: MP4 on PS3 not working
Could you provide information about this mp4 file ? (see signature link : ffmpeg -i, MediaInfo tool result)
Could you enable detailed logging and found the ffmpeg command line used to transcode the file ? (see signature links)
hasma
Post Tue Aug 21, 2012 7:50 pm
The Device-Spy - Connect show this:
http-get:*:audio/mpeg:DLNA.ORG_PN=MP3;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:audio/L16;rate=44100;channels=1:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:audio/L16;rate=44100;channels=2:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:audio/L16;rate=48000;channels=1:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:audio/L16;rate=48000;channels=2:DLNA.ORG_PN=LPCM;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMA_BASE;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:audio/x-ms-wma:DLNA.ORG_PN=WMA_FULL;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:audio/mp4:DLNA.ORG_PN=AAC_ISO_320;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:audio/vnd.dlna.adts:DLNA.ORG_PN=AAC_ADTS_320;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:audio/flac:DLNA.ORG_PN=FLAC;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:audio/ogg:DLNA.ORG_PN=OGG;DLNA.ORG_OP=01;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_SM;DLNA.ORG_OP=00;DLNA.ORG_FLAGS=00D00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_MED;DLNA.ORG_OP=00;DLNA.ORG_FLAGS=00D00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_LRG;DLNA.ORG_OP=00;DLNA.ORG_FLAGS=00D00000000000000000000000000000,http-get:*:image/jpeg:DLNA.ORG_PN=JPEG_TN;DLNA.ORG_OP=00;DLNA.ORG_FLAGS=00D00000000000000000000000000000,http-get:*:image/png:DLNA.ORG_PN=PNG_LRG;DLNA.ORG_OP=00;DLNA.ORG_FLAGS=00D00000000000000000000000000000,http-get:*:image/png:DLNA.ORG_PN=PNG_TN;DLNA.ORG_OP=00;DLNA.ORG_FLAGS=00D00000000000000000000000000000,http-get:*:image/gif:DLNA.ORG_PN=GIF_LRG;DLNA.ORG_OP=00;DLNA.ORG_FLAGS=00D00000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG1;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_PAL;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_PS_NTSC;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_EU_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_EU_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_NA_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_NA_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_SD_KO_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG_TS_SD_KO_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG_TS_JP_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/x-msvideo:DLNA.ORG_PN=AVI;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/x-matroska:DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/x-flv:DLNA.ORG_PN=FLV;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/x-ms-dvr:DLNA.ORG_PN=DVR_MS;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/wtv:DLNA.ORG_PN=WTV;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/ogg:DLNA.ORG_PN=OGV;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AAC_MULT5;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_MPEG1_L3;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_SD_AC3;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_HD_720p_AAC;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_MP_HD_1080i_AAC;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_HP_HD_AAC;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=AVC_MP4_LPCM;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_ASP_AAC;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_SP_L6_AAC;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mp4:DLNA.ORG_PN=MPEG4_P2_MP4_NDSD;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AAC;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AAC_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AAC_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AC3;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AC3_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_ASP_AC3_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG1_L3;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG1_L3_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG2_L2_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG2_L2;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG2_L2_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=MPEG4_P2_TS_ASP_MPEG1_L3_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AAC_MULT5_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_MPEG1_L3_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_SD_AC3_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AAC_MULT5_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_MPEG1_L3_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_MP_HD_AC3_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_DTS_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HD_DTS_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HD_50_LPCM_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HP_SD_MPEG1_L2_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HP_SD_MPEG1_L2_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=AVC_TS_HP_HD_MPEG1_L2_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=AVC_TS_HP_HD_MPEG1_L2_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_BASE;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_FULL;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_FULL;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVMED_PRO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/x-ms-wmv:DLNA.ORG_PN=WMVHIGH_PRO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L1_WMA;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L2_WMA;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/x-ms-asf:DLNA.ORG_PN=VC1_ASF_AP_L3_WMA;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=VC1_TS_AP_L1_AC3_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=VC1_TS_AP_L2_AC3_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/mpeg:DLNA.ORG_PN=VC1_TS_HD_DTS_ISO;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/vnd.dlna.mpeg-tts:DLNA.ORG_PN=VC1_TS_HD_DTS_T;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AAC;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_P2_3GPP_SP_L0B_AMR;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=AVC_3GPP_BL_QCIF15_AAC;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_H263_3GPP_P0_L10_AMR;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000,http-get:*:video/3gpp:DLNA.ORG_PN=MPEG4_H263_MP4_P0_L10_AAC;DLNA.ORG_OP=11;DLNA.ORG_FLAGS=81500000000000000000000000000000
Only PS3 have problems,- handy, tablet and other device can play the mp4 files from serviio, with the default media server the PS3 can play the mp4 without problems. only ps3 and serviio ave troubles together - only mpeg can be seen.
