[SOLVED].mkv not working on PS3 after upgrade to 1.0.1
xs2inattar
Post Sun Aug 12, 2012 11:30 pm
None of my mkv files are working on PS3 after upgrade 1.0.1.
mkv files that were working fine on PS3 with 1.0 stopped working on 1.0.1.
log is as follows.
2012-08-12 19:19:27,047 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-08-12 19:19:27,049 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:19:27,078 DEBUG [ResourceDeliveryProcessor] Request for resource 2356 and type 'MEDIA_ITEM' received
2012-08-12 19:19:27,110 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2356 (local)
2012-08-12 19:19:27,110 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2356)
2012-08-12 19:19:27,112 DEBUG [VideoDAOImpl] Reading a Video (id = 2356)
2012-08-12 19:19:27,115 DEBUG [VideoDeliveryEngine] Delivering item '2356' for client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:19:27,116 DEBUG [VideoDeliveryEngine] Delivering file 'Awara Paagal Deewana (2002).mkv' using transcoding
2012-08-12 19:19:27,117 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:19:27,120 DEBUG [MediaItemDAOImpl] Getting file of media item 2356
2012-08-12 19:19:27,123 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /volume1/video/Movies/Awara Paagal Deewana (2002)/Awara Paagal Deewana (2002).mkv
2012-08-12 19:19:27,124 DEBUG [ProcessExecutor] Starting /volume1/@appstore/Serviio/bin/ffmpeg -fflags +genpts -i /volume1/video/Movies/Awara Paagal Deewana (2002)/Awara Paagal Deewana (2002).mkv -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a ac3_fixed -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /.tmp/Serviio/transcoding-temp-2356-4-ORIGINAL.stf
2012-08-12 19:19:27,250 WARN  [ProcessExecutor] Process /volume1/@appstore/Serviio/bin/ffmpeg has a return code of 1! This is a possible error.
2012-08-12 19:19:27,251 DEBUG [TranscodingJobListener] Transcoding finished; successful: false
2012-08-12 19:19:34,767 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/.tmp/Serviio/transcoding-temp-2356-4-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/.tmp/Serviio/transcoding-temp-2356-4-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
   at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:45)
   at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:125)
   at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:95)
   at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:120)
   at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:84)
   at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:79)
   at org.serviio.upnp.webserver.WebServer$WorkerThread.run(WebServer.java:191)
2012-08-12 19:19:34,775 DEBUG [WebServer] Incoming connection from /192.168.1.8:53050
2012-08-12 19:19:34,775 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-08-12 19:19:34,777 DEBUG [ResourceTransportRequestHandler] GET /resource/2356/MEDIA_ITEM/AVC_TS_MP_SD_AC3_ISO-0/ORIGINAL HTTP/1.1, headers = [Host: 192.168.1.11:8895,User-Agent: PLAYSTATION 3,Connection: Keep-Alive,Accept-Encoding: identity,transferMode.dlna.org: Streaming,X-AV-Client-Info: av=5.0; cn="Sony Computer Entertainment"; mn="PLAYSTATION 3"; mv="1.0";,TimeSeekRange.dlna.org: npt=0.000-]]
2012-08-12 19:19:34,778 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.1.8
2012-08-12 19:19:34,779 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:19:34,783 DEBUG [ResourceDeliveryProcessor] Request for resource 2356 and type 'MEDIA_ITEM' received
2012-08-12 19:19:34,783 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 2356 (local)
2012-08-12 19:19:34,783 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 2356)
2012-08-12 19:19:34,785 DEBUG [VideoDAOImpl] Reading a Video (id = 2356)
2012-08-12 19:19:34,788 DEBUG [VideoDeliveryEngine] Delivering item '2356' for client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:19:34,789 DEBUG [VideoDeliveryEngine] Delivering file 'Awara Paagal Deewana (2002).mkv' using transcoding
2012-08-12 19:19:34,790 DEBUG [AbstractTranscodingDeliveryEngine] A suitable transcoding job already exists, re-use it for client 'IPAddress=/192.168.1.8, Profile=Playstation 3'
2012-08-12 19:19:34,790 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/.tmp/Serviio/transcoding-temp-2356-4-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
Running ffmpeg command from the log also fails.
RR-DS212plus> /volume1/@appstore/Serviio/bin/ffmpeg -fflags +genpts -i /volume1/video/Movies/Awara Paagal Deewana (2002)/Awara Paagal Deewana (2002).mkv -y -
-ash: syntax error: unexpected "("
But when i put the input file name in quotes ffmepg works fine.
RR-DS212plus> /volume1/@appstore/Serviio/bin/ffmpeg -fflags +genpts -i "/volume1/video/Movies/Awara Paagal Deewana (2002)/Awara Paagal Deewana (2002).mkv" -y
ffmpeg version N-42368-gbf53863-Serviio Copyright (c) 2000-2012 the FFmpeg developers
  built on Jul 11 2012 01:45:53 with gcc 4.2.3
  configuration: --arch=arm --enable-armv5te --prefix=/opt --extra-cflags=-I/opt/include --extra-ldflags=-L/tmp/lib --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-pthreads --enable-libmp3lame --enable-librtmp --extra-version=Serviio
Input #0, matroska,webm, from '/volume1/video/Movies/Awara Paagal Deewana (2002)/Awara Paagal Deewana (2002).mkv':
    creation_time   : 2009-07-24 14:28:51
  Duration: 02:44:02.83, start: 0.000000, bitrate: 761 kb/s
    Chapter #0.0: start 0.097000, end 9842.832000
      title           : 00:00:00.097
    Stream #0:0(eng): Video: h264 (Main), yuv420p, 608x256 [SAR 1:1 DAR 19:8], 29.97 fps, 29.97 tbr, 1k tbn, 59.94 tbc (default)
    Stream #0:1(hin): Audio: aac, 48000 Hz, stereo, s16 (default)
    Stream #0:2(eng): Subtitle: text (default)
[graph 0 input from stream 0:1 @ 0xf90140] tb:1/48000 samplefmt:s16 samplerate:48000 chlayout:0x3
[mpegts @ 0xfaeda0] muxrate VBR, pcr every 2 pkts, sdt every 200, pat/pmt every 40 pkts
Output #0, mpegts, to '/.tmp/Serviio/transcoding-temp-2356-4-ORIGINAL.stf':
    encoder         : Lavf54.15.102
    Stream #0:0(eng): Video: h264, yuv420p, 608x256 [SAR 1:1 DAR 19:8], q=2-31, 29.97 fps, 90k tbn, 29.97 tbc (default)
    Stream #0:1(hin): Audio: ac3, 48000 Hz, stereo, s16, 384 kb/s (default)
Stream mapping:
  Stream #0:0 -> #0:0 (copy)
  Stream #0:1 -> #0:1 (aac -> ac3_fixed)
frame=  321 fps= 65 q=-1.0 Lsize=    1540kB time=00:00:10.71 bitrate=1178.2kbits/s
video:845kB audio:507kB subtitle:0 global headers:0kB muxing overhead 13.907222%
Received signal 2: terminating.
Please take a look at this as for now i am unable to play any mkv file on PS3
Post Mon Aug 13, 2012 6:29 pm
Re: .mkv not working on PS3 after upgrade to 1.0.1
run this
ffmpeg -fflags +genpts -i "/volume1/video/Movies/Awara Paagal Deewana (2002)/Awara Paagal Deewana (2002).mkv" -y -copyts -c:v copy -vbsf h264_mp4toannexb -c:a ac3_fixed -b:a 384k -ac 2 -map 0:0 -map 0:1 -sn -f mpegts /.tmp/Serviio/transcoding-temp-2356-4-ORIGINAL.stf
I don't see any change there from what was in 1.0 and FFmpeg is the same. Are you using Synology build?
xs2inattar
Post Mon Aug 13, 2012 6:56 pm
Yes I am using the synology build.
ffmpeg output is as follows.
RR-DS212plus> ffmpeg -fflags +genpts -i "/volume1/video/Movies/Awara Paagal Deewana (2002)/Awara Paagal Deewana (2002).mkv" -y -copyts -c:v copy -vbsf h264_m
Stream mapping:
frame=  251 fps= 74 q=-1.0 Lsize=    1209kB time=00:00:08.37 bitrate=1182.5kbits/s
video:656kB audio:405kB subtitle:0 global headers:0kB muxing overhead 13.964253%
Post Mon Aug 13, 2012 7:00 pm
weird, manually works but via Serviio fails? Are you sure it uses the same FFmpeg?
Post Mon Aug 13, 2012 7:05 pm
Check that serviio service have permission access to the tmp folder.
xs2inattar
Post Mon Aug 13, 2012 7:41 pm
[SOLVED] .mkv not working on PS3 after upgrade to 1.0.1
Cant believe this happened again.
I ran into the same problem when upgraded to 1.0. The problem was fixed when I deleted the tmp directory and let the new version create the directory.
Samething happened with 1.0.1 as well. after the tmp directory was deleted. 1.0.1 created the new directory and everything started working fine.
patters
Post Mon Aug 13, 2012 11:18 pm
Re: [SOLVED].mkv not working on PS3 after upgrade to 1.0.1
By default, the Synology package uses /volume1/@tmp as the transcoding temp location. This is DSM's own temp folder, and it's only limited in size by your disk. The syno will purge this every time it boots too. Don't use /tmp because this seems to be a very small partition.
xs2inattar
Post Tue Aug 14, 2012 12:56 am
patters wrote:By default, the Synology package uses /volume1/@tmp as the transcoding temp location. This is DSM's own temp folder, and it's only limited in size by your disk. The syno will purge this every time it boots too. Don't use /tmp because this seems to be a very small partition.
I am using /.tmp as my temp folder. It is a folder that i created myself just to be used by serviio.
jamitupya
Post Fri Aug 24, 2012 10:09 am
i seem to be having the same issue however
i have attached the 2 log files incase this helps.... i also deleted the old logs and re-started so its a bit simpler to see.....
any thoughts?
(75.32 KiB) Downloaded 592 times
Post Fri Aug 24, 2012 10:31 am
jamitupya wrote:i seem to be having the same issue however?
This is not the same issue:
In the log there are some Broken pipe errors, that basically meant the renderer/TV closes the connection for whatever reason. That might be that your lan/wi-fi connection failed or the file is corrupted or unplayable by the renderer/tv.
jamitupya
Post Fri Aug 24, 2012 11:56 pm
thanks,
im connected via wired lan into a cisco 3851 so im guessing its a renderer issue. the only issue i have with this is these same files worked last week prior to the 1.0.1 patch.
oh well, thanks anyway
