PS3 getting Unsupported Data message for some videos
cmrs2k
Post Tue Sep 25, 2012 3:57 am
I am having success with quite a bit of my library, but a handful of my more recently downloaded videos are showing up with a thumbnail on my PS3 but will not play.
I get an "Unsupported Data" message after some time, and the detailed log shows an I/O error but that ffmpeg is working...
2012-09-24 22:34:14,834 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /data/movies/Game.of.Thrones/Season.2/Game.of.Thrones.S02E02.HDTV.x264-ASAP.The.Night.Lands.mp4
2012-09-24 22:34:14,835 DEBUG [ProcessExecutor] Starting ffmpeg -i /data/movies/Game.of.Thrones/Season.2/Game.of.Thrones.S02E02.HDTV.x264-ASAP.The.Night.Lands.mp4 -y -threads 3 -copyts -c:v mpeg2video -b:v 8192k -maxrate:v 8192k -bufsize:v 8192k -r 24000/1001 -g 15 -c:a mp2 -b:a 128k -ac 2 -map 0:0 -map 0:1 -sn -f vob /tmp/Serviio/transcoding-temp-2216-6-ORIGINAL.stf
2012-09-24 22:34:15,335 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2012-09-24 22:34:15,336 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Game.of.Thrones.S02E02.HDTV.x264-ASAP.The.Night.Lands.mp4: MPEG_PS_PAL
2012-09-24 22:34:15,336 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file Game.of.Thrones.S02E02.HDTV.x264-ASAP.The.Night.Lands.mp4: MPEG_PS_NTSC
2012-09-24 22:34:15,337 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 2216) as read
2012-09-24 22:34:15,358 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-09-24 22:34:15,358 DEBUG [ResourceDeliveryProcessor] Stream entity has length: 50000000000
2012-09-24 22:34:15,358 DEBUG [ResourceDeliveryProcessor] Sending file back
2012-09-24 22:34:15,358 DEBUG [ResourceTransportRequestHandler] Creating entity with chunked transfer
2012-09-24 22:34:15,358 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,TimeSeekRange.dlna.org: npt=0.0-3297.0/3297,Date: Tue, 25 Sep 2012 03:34:15 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.0.1,Cache-control: no-cache,transferMode.dlna.org: Streaming]]
2012-09-24 22:34:15,964 DEBUG [WebServer] I/O error: Broken pipe
The same videos will play fine through the mediabrowser.
Any thoughts?
Post Tue Sep 25, 2012 3:54 pm
Re: PS3 getting Unsupported Data message for some videos
Could you try the same ffmpeg command line locally and check ffmpeg log ?
ffmpeg -i "/data/movies/Game.of.Thrones/Season.2/Game.of.Thrones.S02E02.HDTV.x264-ASAP.The.Night.Lands.mp4" -y -threads 3 -copyts -c:v mpeg2video -b:v 8192k -maxrate:v 8192k -bufsize:v 8192k -r 24000/1001 -g 15 -c:a mp2 -b:a 128k -ac 2 -map 0:0 -map 0:1 -sn -f vob /tmp/Serviio/TEST.ts
cmrs2k
Post Tue Sep 25, 2012 9:52 pm
I had tried this initially, but guess I didn't let it run long enough... I get the following after a short amount of time:
[vob @ 0xd29f00] buffer underflow i=0 bufi=55953 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=57977 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=60001 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=62025 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=64049 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=66073 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=68097 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=70121 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=72145 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=74169 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=76193 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=78217 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=80241 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=82265 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=84289 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=86313 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=88337 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=90361 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=92385 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=94409 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=96433 size=97565
[vob @ 0xd29f00] buffer underflow i=0 bufi=882 size=57348
[vob @ 0xd29f00] buffer underflow i=0 bufi=2906 size=57348
[vob @ 0xd29f00] buffer underflow i=0 bufi=4930 size=57348
[vob @ 0xd29f00] buffer underflow i=0 bufi=6954 size=57348
[vob @ 0xd29f00] buffer underflow i=0 bufi=8978 size=57348
[vob @ 0xd29f00] buffer underflow i=0 bufi=11002 size=57348
[vob @ 0xd29f00] buffer underflow i=0 bufi=13026 size=57348
[vob @ 0xd29f00] buffer underflow i=0 bufi=15032 size=57348
[vob @ 0xd29f00] buffer underflow i=0 bufi=17056 size=57348
[vob @ 0xd29f00] buffer underflow i=0 bufi=19080 size=57348
Any tips?
Post Wed Sep 26, 2012 6:53 am
cmrs2k wrote:Any tips?
No.
Its not the complete ffmpeg log ?!
cmrs2k
Post Wed Sep 26, 2012 9:33 pm
ffmpeg version 0.10.4-6:0.10.4-0ubuntu0jon2~natty1 Copyright (c) 2000-2012 the FFmpeg developers
  built on Jun 15 2012 13:53:04 with gcc 4.5.2
  configuration: --extra-version='6:0.10.4-0ubuntu0jon2~natty1' --arch=amd64 --prefix=/usr --disable-stripping --enable-vaapi --enable-vdpau --enable-bzlib --enable-gnutls --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-libfreetype --enable-libpulse --enable-vaapi --enable-gpl --enable-postproc --enable-x11grab --enable-libcdio --enable-version3 --enable-libdc1394 --enable-shared --disable-static
  avutil      configuration: --extra-version='6:0.10.4.0ubuntu0jon2~natty1' --arch=amd64 --prefix=/usr --disable-stripping --enable-vaapi --enable-vdpau --enable-bzlib --enable-gnutls --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-libfreetype --enable-libpulse --enable-vaapi --enable-libopenjpeg --enable-libmp3lame --enable-librtmp --enable-frei0r --enable-gpl --enable-postproc --enable-x11grab --enable-libcdio --enable-libx264 --enable-version3 --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libdc1394 --enable-shared --disable-static
  avcodec     configuration: --extra-version='6:0.10.4.0ubuntu0jon2~natty1' --arch=amd64 --prefix=/usr --disable-stripping --enable-vaapi --enable-vdpau --enable-bzlib --enable-gnutls --enable-libgsm --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --enable-libvpx --enable-runtime-cpudetect --enable-libfreetype --enable-libpulse --enable-vaapi --enable-libopenjpeg --enable-libmp3lame --enable-librtmp --enable-frei0r --enable-gpl --enable-postproc --enable-x11grab --enable-libcdio --enable-libx264 --enable-version3 --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libdc1394 --enable-shared --disable-static
  libavutil      51. 35.100 / 51. 35.100
  libavcodec     53. 61.100 / 53. 61.100
  libavformat    53. 32.100 / 53. 32.100
  libavdevice    53.  4.100 / 53.  4.100
  libavfilter     2. 61.100 /  2. 61.100
  libswresample   0.  6.100 /  0.  6.100
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/data/movies/Game.of.Thrones/Season.2/Game.of.Thrones.S02E02.HDTV.x264-ASAP.The.Night.Lands.mp4':
    major_brand     : isom
    minor_version   : 1
    compatible_brands: isom
    creation_time   : 2011-09-08 11:43:25
  Duration: 00:54:57.75, start: 0.000000, bitrate: 932 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p, 720x404 [SAR 404:405 DAR 16:9], 803 kb/s, 23.98 fps, 23.98 tbr, 24k tbn, 47.95 tbc
      handler_name    :
    Stream #0:1(und): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 123 kb/s
      handler_name    :
[buffer @ 0x1494980] w:720 h:404 pixfmt:yuv420p tb:1/1000000 sar:404/405 sws_param:
[mpeg2video @ 0x14956c0] impossible bitrate constraints, this will fail
Output #0, vob, to '/tmp/Serviio/TEST.ts':
    major_brand     : isom
    minor_version   : 1
    encoder         : Lavf53.32.100
    Stream #0:0(und): Video: mpeg2video, yuv420p, 720x404 [SAR 404:405 DAR 16:9], q=2-31, 8192 kb/s, 90k tbn, 23.98 tbc
      handler_name    :
    Stream #0:1(und): Audio: mp2, 48000 Hz, 2 channels, s16, 128 kb/s
      handler_name    :
Stream mapping:
  Stream #0:0 -> #0:0 (h264 -> mpeg2video)
  Stream #0:1 -> #0:1 (aac -> mp2)
buffer underflow i=0 bufi=51905 size=97565time=00:01:29.38 bitrate=1995.8kbits/s
[vob @ 0x1494f00] buffer underflow i=0 bufi=53929 size=97565
    Last message repeated 1 times
[vob @ 0x1494f00] buffer underflow i=0 bufi=55953 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=57977 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=60001 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=62025 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=64049 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=66073 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=68097 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=70121 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=72145 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=74169 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=76193 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=78217 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=80241 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=82265 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=84289 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=86313 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=88337 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=90361 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=92385 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=94409 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=96433 size=97565
[vob @ 0x1494f00] buffer underflow i=0 bufi=882 size=57348
[vob @ 0x1494f00] buffer underflow i=0 bufi=2906 size=57348
[vob @ 0x1494f00] buffer underflow i=0 bufi=4930 size=57348
[vob @ 0x1494f00] buffer underflow i=0 bufi=6954 size=57348
video:828122kB audio:51528kB global headers:0kB muxing overhead 1.309660%
I cut out a ton of the "[vob @ 0x1494f00] buffer underflow i=0 bufi=6954 size=57348" messages because the log file would have been 273926 characters long otherwise....
