Sony BD trouble with certain AVI files
jhebert
Post Wed Feb 20, 2013 4:15 am
I am running into a problem with certain .AVI files on my BD player coming up as invalid using the BD profile. The same files play well on my Samsung Galaxy Tab from the same Serviio server (v1.1) running the generic profile. Other files (including other .AVI files) play great on all devices. Here is the ffmpeg -i on one of the files:
D:\Files>ffmpeg -i testvid.avi
configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enable-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --pkg-config=pkg-config
[mpeg4 @ 0182D540] Invalid and inefficient vfw-avi packed B frames detected
Input #0, avi, from 'testvid.avi':
encoder : VirtualDubMod 1.5.10.2 (build 2540/release)
Duration: 00:20:09.65, start: 0.000000, bitrate: 1354 kb/s
Stream #0:0: Video: mpeg4 (DX50 / 0x30355844), yuv420p, 596x452 [SAR 1:1 DAR 149:113], 29.97 fps, 29.97 tbr, 29.97 tbn, 30k tbc
Stream #0:1: Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, stereo, s16, 80 kb/s
Stream #0:2: Audio: mp3 (U[0][0][0] / 0x0055), 44100 Hz, stereo, s16, 32 kb/s
Here is the MediaInfo on the same file:
Complete name : D:\Files\testvid.avi
Format : AVI
File size : 195 MiB
Duration : 20mn 9s
Overall bit rate : 1 355 Kbps
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Format : MPEG-4 Visual
Format settings, BVOP : 3
Format settings, QPel : No
Format settings, GMC : No warppoints
Muxing mode : Packed bitstream
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 20mn 9s
Bit rate : 1 074 Kbps
Width : 596 pixels
Height : 452 pixels
Display aspect ratio : 4:3
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.133
Stream size : 155 MiB (79%)
Writing library : DivX 6.8.3-6.8.4 (UTC 2008-06-07)
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 20mn 9s
Bit rate mode : Variable
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Stream size : 18.6 MiB (10%)
Alignment : Aligned on interleaves
Interleave, duration : 26 ms (0.78 video frame)
Interleave, preload duration : 505 ms
Writing library : LAME3.90.
Encoding settings : -m j -V 4 -q 2 -lowpass 17.6 --abr 128
Audio #2
Format : MPEG Audio
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 20mn 9s
Bit rate : 128 Kbps
Stream size : 18.9 MiB (10%)
Interleave, preload duration : 146 ms
I'm assuming I need to tweak the transcode settings for AVI in the BD profile, but I have been unsuccessful thus far and I don't want to accidentally break the .AVI files that are currently working correctly.
Thanks in advance.
J.B.
Post Wed Feb 20, 2013 8:11 am
Re: Sony BD trouble with certain AVI files
Try to change the FourCC to XVID:
http://wiki.serviio.org/doku.php?id=avi4cc
jhebert
Post Thu Feb 21, 2013 3:55 am
That did it. Would love a batch version of that utility so I could do several files in series, but otherwise it does exactly what I needed. Thanks!
