MKV file with ogg/vorbis audio not displayed on Sony BDPS470
Koekebeest
Post Sat Dec 03, 2011 9:09 pm
I have a mkv video in my library, but it does not get listed on my SONY BDPS470 bluray player.
The file plays fine on my sony tv which is a KDL32ex700.
The log reports the following:
2011-12-03 19:59:25,184 WARN [VideoDeliveryEngine] Cannot get media info for transcoded file House S02 E21 Euphoria (pt2) 720p x264 .mkv: MPEG2TS video file House S02 E21 Euphoria (pt2) 720p x264 .mkv does not match any supported DLNA profile
This is the output from mediainfo:
Unique ID : 13130188128795605691642046919267451383 (0x9E0C8417CF1A42F8A726123661E01F7)
Complete name : Z:\Recorded TV\House\Season 2\House S02 E21 Euphoria (pt2) 720p x264.mkv
Format : Matroska
File size : 1.45 GiB
Duration : 43mn 7s
Overall bit rate : 4 818 Kbps
Writing application : AVI-Mux GUI 1.17.5, Apr 5 2006 18:41:17
Writing library : matroska muxer by Alexander Noe, build date Apr 5 2006
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 7 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 43mn 7s
Nominal bit rate : 4 500 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.204
Writing library : x264 core 44 svn-438
Encoding settings : cabac=1 / ref=4 / deblock=1:-4:-4 / analyse=0x3:0x133 / me=hex / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / chroma_qp_offset=0 / slices=2 / nr=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40 / rc=2pass / bitrate=4500 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30
Language : English
Format : Vorbis
Codec ID : A_VORBIS
Duration : 43mn 7s
Bit rate mode : Variable
Channel(s) : 6 channels
Sampling rate : 48.0 KHz
Compression mode : Lossy
Guess it is related to the audio being Vorbis, since that's the difference between my other files, but it should be supported.
Does anyone have an idea what the problem is?
Thanks!
patters
Post Sun Dec 11, 2011 11:35 pm
Re: MKV file with ogg/vorbis audio not displayed on Sony BDP
[topic moved to the Sony support folder]
Can you try stopping Serviio, editing config/profiles.xml to change the Sony BDP's transcoding section, making the following addition (in italics):
<Video targetContainer="mpegts" targetACodec="ac3" aBitrate="320">
<!-- FFmpeg cannot currently remux dts audio properly so it must be transcoded, but all other audio is left alone -->
<Matches container="matroska" aCodec="vorbis" />
<Matches container="ogg" vCodec="mpeg4" />
<Matches container="mp4" aCodec="lpcm" />
Then start Serviio again.
Post Mon Dec 12, 2011 12:53 pm
Natively not supported by Sony BDP
DigitalHEAD
Post Mon Jan 23, 2012 7:47 pm
Vorbis Audio Codec playback is not supported too.
To solve the format profile issue, use this. http://www.videohelp.com/tools/H264-AVC-Level-Editor No need for file conversion.
Now the Vorbis issue, you'll have to convert files. It only takes less than ten minutes with MediaCoder
Post Mon Jan 23, 2012 8:28 pm
DigitalHEAD wrote:Now the Vorbis issue, you'll have to convert files. It only takes less than ten minutes with MediaCoder
no you dont have to convert them you can just add the line that patter suggested above to sony profile. ;)
eclp
Post Mon Jan 23, 2012 8:41 pm
Can you please answer my question too?
I want to see wmv files natively (Some will play, others do not. Some others are not displayed).
What I have to enter where profiles.xml in?
Post Mon Jan 23, 2012 9:08 pm
eclp wrote:Can you please answer my question too?
bro start your own topic don't hijack.
AdamP
Post Thu Mar 21, 2013 8:08 pm
I have a Sony 590 with the same vorbis issue. Is there a similar line of code I can add to my profile? Thank you.
Post Thu Mar 21, 2013 10:47 pm
It's already included in the profile. Post detailed log of playing the file to confirm it's being transcoded.
