Support for Sony BDP-S4100?
• Page 1 of 1
Is this Sony Blu-ray player supported by serviio, and does the rewind and forward work?
Re: Support for Sony BDP-S4100?
Could you provide format supported by this device ? see my signature link...
Found here :
You can try to select one Sony BDP profile in serviio console.
or
You can try with Bravia 2013 profile : viewtopic.php?f=11&t=11147
Found here :
What are the files playable on DLNA server?
[Video]
. MPEG-1 PS (.mpg, .mpeg)
. MPEG-2 PS (.mpg, .mpeg)
. MPEG-2 TS (.m2ts, .mts)
. Xvid (.avi)
. MPEG4/AVC (.mkv)
. MPEG-4/AVC MP4 (.mp4, .m4v)
. MPEG-4/AVC TS (.m2ts, .mts)
. WMV (.wmv, .asf)
[Music]
. MP3 (.mp3)
. AAC (.m4a)
. WMA9 (.wma)
. LPCM (.wav)
. DTS (.wav)
[Image]
. JPEG (.jpeg, .jpg, .jpe)
. PNG (.png)
. GIF (.gif)
or
I have not got it yet, and would like to know this beforehand, before buying. Does Rewind and forward work with other Bravia-devices or BDP-profile machines, does anyone know?
I bought this unit, and at least mkv-videos seems to be working with "Sony BDP-Sx90"-profile. Rewind, forward works quite fine
Does this player support same files as Sony BDP-S4100? If not i would like to do something about that, so I can get all available files playing
For some reason I can not get multichannel audio to work. Player recognizes that audio stream is 5.1 DTS, but it outputs only stereo. Blu-ray disk outputs multichannel, and there seems to be no setting to set output to DTS or Dolby Digital. Any ideas?
With my samsung player audio is fine and multichannel works.
EDIT: Updated the player firmware and now multichannel sound works
This player is just SO good <3
EDIT #2: It seems that these (BDP-S4100 and for example BDP-S790) have identical fileformat support. So the profile is perfect for this player, and this name could be added to that profile name
There's one important difference however in the x100 (e.g. S5100) series and the older x90 series (e.g. S790)
MPEG2 and VC-1 is supported in MKV containers on the x100 series.
apw2607 wrote:MPEG2 and VC-1 is supported in MKV containers on the x100 series.
How do you test this ? Do you try with generic profile ?
• Page 1 of 1
Users browsing this forum: Google [Bot] and 2 guests
