Can't Play TrueHD thru Sony BDP570
nestorquay
Post Fri Nov 22, 2013 7:55 am
Can't figure out how to get my BDP 570 to play TrueHD. I have created an MKV file that according to MediaInfo contains a 1920 x 1080 AVC video stream and a 6 channel TrueHD audio stream. This file was created using HandBrake and MKVMerge. In it's current configuration, the MKV file refuses to appear on the Sony menu even though the Show Status button shows Serviio has found the file after a Force Refresh. What is my next step?
Thanks to all.
Windows 7 Ultimate
Post Fri Nov 22, 2013 8:40 am
Re: Can't Play TrueHD thru Sony BDP570
Could you provide information about your mkv file (ffmpeg -i) ? see my signature links.
nestorquay
Post Sat Nov 23, 2013 9:54 am
Thanks for your help
Here is the ffmeg output:
D:\Program Files\Serviio\lib>ffmpeg.exe -i "D:\01Media\Movies\DexterS7D1\test.mk
v"
Input #0, matroska,webm, from 'D:\01Media\Movies\DexterS7D1\test.mkv':
creation_time : 2013-11-21 22:09:33
TITLE : Dexter - Season 7, Disc 1
Duration: 00:55:11.31, start: 0.000000, bitrate: 23122 kb/s
Chapter #0.0: start 0.000000, end 249.582667
title : Chapter 1
Chapter #0.1: start 249.582667, end 851.350500
title : Chapter 2
Chapter #0.2: start 851.350500, end 1637.135500
title : Chapter 3
Chapter #0.3: start 1637.135500, end 2185.933744
title : Chapter 4
Chapter #0.4: start 2185.933744, end 2780.778000
title : Chapter 5
Chapter #0.5: start 2780.778000, end 3251.289700
title : Chapter 6
Chapter #0.6: start 3251.289700, end 3311.309000
title : Chapter 7
Stream #0:0(eng): Video: h264 (Main), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9],
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(eng): Audio: truehd, 48000 Hz, 5.1(side), s32 (default)
title : 5.1
Post Sun Nov 24, 2013 8:45 pm
I don't know how similar the BDP570 is to my SMP-N200, but mine do stream TrueHD from my MKV or M2TS files.
