Sony kdl 40W5500
thorolason
Post Sun Jan 26, 2014 1:09 pm
Sony kdl 40W5500
Hi I'm using Sony kdl 40W5500 which is defaulting to the sony 2009 profile. Serviio is running on a ubuntu 13.10 and I have compiled ffmpeg and lame etc from the reconmended source.
i have problems with 2 type of files, some (not all) mkv files and then .mpg files from my sony DSC-H9 camera.
____________________________________________________________________________________________
First the mkv files, notice this is not all mkv file but some like this one plays on double or tripple speed on the TV
serviio@server:/tmp$ ffmpeg -i bla.mkv
ffmpeg version 1.1.git Copyright (c) 2000-2013 the FFmpeg developers
built on Jan 26 2014 10:38:05 with gcc 4.8 (Ubuntu/Linaro 4.8.1-10ubuntu9)
configuration: --prefix=/home/serviio/serviio-1.4/codecs/
Input #0, matroska,webm, from 'bla.mkv':
Duration: 00:23:55.07, start: 0.000000, bitrate: 839 kb/s
Stream #0:0(eng): Video: h264 (Main), yuv420p, 640x480, SAR 1:1 DAR 4:3, 29.97 fps, 29.97 tbr, 1k tbn, 180k tbc (default)
Stream #0:1: Audio: aac, 44100 Hz, stereo, fltp (default)
___________________________________________________________________________________--
The .mpg files from the sony camera "play" there is sound but no video.
serviio@server:/tmp$ ffmpeg -i bla.mpg
[mpeg @ 0x9126dc0] max_analyze_duration 5000000 reached at 5004000 microseconds
Input #0, mpeg, from 'bla.mpg':
Duration: 00:02:50.92, start: 0.110000, bitrate: 2913 kb/s
Stream #0:0[0x1c0]: Audio: mp2, 32000 Hz, mono, s16p, 64 kb/s
Stream #0:1[0x1e0]: Video: mpeg1video, yuv420p, 640x480 [SAR 1:1 DAR 4:3], 104857 kb/s, 25 fps, 25 tbr, 90k tbn, 25 tbc
any hints are welcome.
Cheers - Thor
Post Sun Jan 26, 2014 7:24 pm
Re: Sony kdl 40W5500
thorolason wrote:First the mkv files, notice this is not all mkv file but some like this one plays on double or tripple speed on the TV
This file should be remuxed into mpegts/h264/AAC without change video and audio track, so there were probably something on the h264 encoding or resolution that 2009 model does not support.
thorolason wrote:The .mpg files from the sony camera "play" there is sound but no video.
So it seems that 2009 model does not support MPEGPS/MPEG1/MP2
Could you edit the 2009 profile like this ?
   <Profile id="sony2009" name="Sony Bravia TV (2009)" extendsProfileId="sony2010">
      <!-- 2009 and earlier models need a separate profile -->
      <Detection>
         <UPnPSearch>
            <!-- 2009 models known to support UPnPSearch -->
            <FriendlyName>BRAVIA KDL-\d{2}(WE5|(E53|E55|V55|V56|W55|W57|Z55|Z57)\d0) *</FriendlyName>
         </UPnPSearch>
         <HttpHeaders>
            <!-- 2008 models, and possibly older or different region 2009 firmwares which may not support UPnPSearch -->
            <X-AV-Client-Info>.*BRAVIA KDL-\d{2}(([A-Z](1|5|E1|R1|BR45|BR9|[1357]0\d{2}|4\d{3}))|(S55|S57|W51|Z51|Z58)\d0).*</X-AV-Client-Info>
         </HttpHeaders>
      </Detection>
         <!-- Transcode baseline h264 in mp4/non-isom container -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="192" DAR="16:9">
            <Matches container="mp4" vCodec="h264" profile="baseline" ftypNotIn="isom" />
            <Matches container="mpeg" vCodec="mpeg1video" aCodec="mp2" />
         <Video targetContainer="mpeg" targetACodec="ac3">
            <Matches container="mpeg" vCodec="mpeg2video" aCodec="mp2" />
      <OnlineTranscoding>
      </OnlineTranscoding>
thorolason
Post Sun Jan 26, 2014 9:07 pm
Thanks, that fixed the more important one :-) the .mpg files are playing correctly now.
Any Idea how to get .mkv file to slow down.
Here is fx an mkv file that plays normally..
serviio@server:/tmp$ ffmpeg -i bla2.mkv
configuration: --prefix=/home/pc5dczcbl5yt/serviio-1.4/codecs/
Input #0, matroska,webm, from 'bla2.mkv':
creation_time : 2010-05-25 16:51:28
Duration: 00:07:00.08, start: 0.000000, bitrate: 3717 kb/s
Stream #0:0: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 25 fps, 25 tbr, 1k tbn, 50 tbc (default)
Stream #0:1: Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (default)
Post Mon Jan 27, 2014 8:02 am
thorolason wrote:Any Idea how to get .mkv file to slow down.
No...Could you provide MadiaInfo tool result (in text format) ?
thorolason
Post Mon Jan 27, 2014 7:54 pm
rigth here is the output.
serviio@server:/tmp$ mediainfo bla.mkv
Unique ID : 273270060647987510504588807547635344206 (0xCDB5E63676E554EE339A58D3C864DBAE)
Complete name : bla.mkv
Format : Matroska
Format version : Version 2
File size : 144 MiB
Duration : 23mn 55s
Overall bit rate : 839 Kbps
Writing application : HandBrake 0.9.8
Writing library : libmkv 0.6.5
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 23mn 55s
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=2 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=0 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=300 / keyint_min=30 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : Yes
Forced : No
Color primaries : BT.601 NTSC
Matrix coefficients : BT.601
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 23mn 55s
Channel count : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Default : Yes
Forced : No
