Audio but no video? On a 32" Sony.
ytrebil
Post Sat May 10, 2014 9:57 am
Hi guys, all my other video files seem to stream fine to my Sony via Serviio but having issues with this one. Can anyone help me out on what might be wrong?
BTW, getting audio, just no video.
Format : Matroska
Format version : Version 2
File size : 729 MiB
Duration : 1h 59mn
Overall bit rate : 855 Kbps
Encoded date : UTC 2012-05-16 16:11:09
Writing application : mkvmerge v5.5.0 ('Healer') built on Apr 6 2012 21:43:24
Writing library : libebml v1.2.3 + libmatroska v1.3.0
Format : AVC
Format profile : High@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 6 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Nominal bit rate : 770 Kbps
Width : 1 280 pixels
Height : 688 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Variable
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 120
Encoding settings : cabac=1 / ref=6 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=5 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=1 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=10 / rc=abr / mbtree=1 / bitrate=770 / ratetol=1.0 / qcomp=0.60 / qpmin=3 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
Default : Yes
Forced : No
Color primaries : BT.709
Matrix coefficients : BT.709
Format : AAC
Format profile : LC
Codec ID : A_AAC
Duration : 1h 59mn
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Language : English
Default : Yes
Forced : No
Post Sat May 10, 2014 10:10 am
Re: Audio but no video? On a 32" Sony.
This file has header compression (header stripping) which is likely not supported by your TV. To remove it see http://wiki.serviio.org/doku.php?id=header_com.
Users browsing this forum: Baidu [Spider] and 5 guests
