AVI audio stutter on Sony Bravia KDL 46EX711
impee
Post Wed Feb 09, 2011 12:23 pm
First of all, i would like to express my appreciation for Serviio which is really a state-of-the-art software!
I've been using Serviio for some weeks now, and had only one problem: audio gets delayed, stuttered or even disappears with a particular avi (the video is allways ok). It happens always at the same places in the movie.
I'm using Serviio 0.5 out-of-the-box
TV: Sony KDL 46EX711
Transcoding: on (2 cores)
Profile: Sony Bravia
No problems with playing the particular avi with VLC on my laptop.
No problems with other avi's until now.
Tried to use the most recent ffmpeg: problem got even worse
Used wired connections to router/tv: problem remains
Any ideas to solve this problem?
Post Wed Feb 09, 2011 1:27 pm
Re: AVI audio stutter on Sony Bravia KDL 46EX711
Could you provide "ffmpeg -i" result of the file? see my signature.
Stuttering could be due to high bitrate variation, but I've seen this problem only on video.
Could you try this:
<Profile id="9" name="Sony Bravia TV" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <FriendlyName>BRAVIA.*</FriendlyName>
         </UPnPSearch>
      </Detection>
      <MediaFormatProfiles>
         <!-- rename native mpeg2ts with h264/ac3 ac3 formats to those supported by the tv -->
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3">AVC_TS_MP_HD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3">AVC_TS_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T">AVC_TS_MP_HD_AC3_T</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/vnd.dlna.mpeg-tts" name="AVC_TS_HD_50_AC3_T">AVC_TS_MP_SD_AC3_T</MediaFormatProfile>
         <!-- rename transcoded mpeg2ts with h264 to one of the TV's supported profiles -->
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO">AVC_TS_MP_HD_AC3_ISO</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/mpeg" name="AVC_TS_HD_50_AC3_ISO">AVC_TS_MP_SD_AC3_ISO</MediaFormatProfile>
      </MediaFormatProfiles>
         <!-- For dvr-ms files force mpeg2video transcoding to fix monotone timestamps problems-->
         <Video targetContainer="mpegts" targetACodec="ac3" forceVTranscoding="true">
            <Matches container="asf" vCodec="mpeg2video" />
            First remux all h264 video on MPEG-TS stream with ac3 audio transcoding, expected profile AVC_TS_MP_HD_AC3_ISO or
         <Video targetContainer="mpegts" targetACodec="ac3" aBitrate="192">
            <!-- if audio different to ac3, must be transcoded -->
            <Matches container="mpegts" aCodec="aac" />
            <Matches container="mpegts" aCodec="mp3" />
            <Matches container="mpegts" aCodec="dca" />
         <!-- All Others video/audio codec will be transcoded into mpeg2ts, mpeg2video and ac3 audio (MPEG_TS_SD_EU). -->
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="192">
            <Matches container="asf" />
            <Matches container="avi" />
            <Matches container="mp4" />
            <Matches container="flv" />
impee
Post Wed Feb 09, 2011 10:43 pm
Hi Illico,
The problem is solved after changing the profile with your alternative version. Do you advise me to always use the changed profile, or only when there are problems with the audio?
This was the output of ffmpeg.exe -i:
C:\Program Files\Serviio\lib>ffmpeg.exe -i "M:\Films\24\TV\24 S08 E01_arc.avi"
configuration: --enable-static --disable-shared --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --arch=x86 --enable-runtime-cpudetect --enable-w32thre
ads --target-os=mingw32 --cross-prefix=i686-mingw32-
libavutil 50.36. 0 / 50.36. 0
libavcore 0.16. 0 / 0.16. 0
libavfilter 1.72. 0 / 1.72. 0
libswscale 0.12. 0 / 0.12. 0
[mpeg4 @ 029c2190] Invalid and inefficient vfw-avi packed B frames detected
Seems stream 0 codec frame rate differs from container frame rate: 23.98 (65535/2733) -> 23.98 (24000/1001)
Input #0, avi, from 'M:\Films\24\TV\24 S08 E01_arc.avi':
encoder : VirtualDubMod 1.5.10.2 (build 2542/release)
Duration: 00:41:52.51, start: 0.000000, bitrate: 1168 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 624x352 [PAR 1:1 DAR 39:22], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 128 kb/s
And last but not least: thank you very much for your input. I appreciate it a lot!
Regards.
Post Thu Feb 10, 2011 8:18 am
impee wrote:...
So your AVI file with MPEG4 Video and MP3 audio matches with the latest <Video> section, so you could only change audio bitrate to 192 in this section
Check with that profile:
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
dougri
Post Fri Feb 11, 2011 7:26 am
Having similar problems on a Sony BDP-BX37 (U.S. S370). Would a similar change to the U.S. Sony BDP profile be recommended?
impee
Post Fri Feb 11, 2011 8:54 am
Hi Illico,
Changing only the last <video> works too! Thanks.
I guess i should keep it like that?
Just to be curious: what is the rootcause of this problem? A bug in the TV, Serviio or just an optimalisation of the configuration? And why didn't i had the problem with other movies?
Regards.
Post Fri Feb 11, 2011 9:24 am
impee wrote:...Changing only the last <video> works too! Thanks.
Yes
impee wrote:Just to be curious: what is the rootcause of this problem? A bug in the TV, Serviio or just an optimalisation of the configuration? And why didn't i had the problem with other movies?
Honestly I don't know
impee
Post Fri Feb 11, 2011 12:19 pm
Hi Illico,
Thank you for the feedback and solution.
As far as i'm concerned, this topic can be closed.
Regards.
