Sony 2014 50W805B freezes with MKV
jerome
Post Sun Oct 12, 2014 9:19 am
Most often than not, using Serviio for streaming an MKV from my QNAP TS112 NAS to my Sony 2014 50W805B TV results in some freezes at some time while reading.
To workaround this, I need to use fast foward on my TV remote control a few seconds further, and then the playing generally resumes.
Irritating in the long run...
I noticed that this seems to happen only at some identified moments of the movies being streamed: e.g. I know some scenes in #Chef will cause the freeze to happen.
I already use "Sony Bravia TV (2013)" profile, and tested "Enable transcoding" ON or OFF with the same results.
Does anyone have an idea of what can be done to fix this?
Post Sun Oct 12, 2014 1:45 pm
Re: Sony 2014 50W805B freezes with MKV
Probably due to high video bitrate and limited bandwidth.
Check with this tool : viewtopic.php?f=17&t=2133
Could you provide file information ? see signature links
jerome
Post Sun Oct 12, 2014 5:03 pm
I'm on OSX, so can't use Video Bitrate Viewer for Windows.
Here's what I get from ffmpeg on the NAS:
[/share/HDA_DATA/.qpkg/Serviio] # ./opt/bin/ffmpeg -i /share/HDA_DATA/chef.1080p.bluray.x264.mkv
ffmpeg version 2.1-Qnap_csholmq Copyright (c) 2000-2013 the FFmpeg developers
built on Dec 10 2013 08:54:51 with gcc 4.2.3 (GCC)
configuration: --arch=arm --disable-armv6 --disable-armv6t2 --disable-neon --disable-vfp --prefix=/opt --extra-libs=-ldl --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-pthreads --enable-libmp3lame --enable-librtmp --enable-libshine --enable-libfdk-aac --extra-version=Qnap_csholmq
libavutil 52. 48.100 / 52. 48.100
libavcodec 55. 39.100 / 55. 39.100
libavformat 55. 19.104 / 55. 19.104
libavdevice 55. 5.100 / 55. 5.100
libavfilter 3. 90.100 / 3. 90.100
libswscale 2. 5.101 / 2. 5.101
libswresample 0. 17.104 / 0. 17.104
Input #0, matroska,webm, from '/share/HDA_DATA/chef.1080p.bluray.x264.mkv':
Duration: 01:54:27.74, start: 0.000000, bitrate: 9941 kb/s
Chapter #0.0: start 0.000000, end 950.241000
title : 00:00:00.000
Chapter #0.1: start 950.241000, end 1609.149000
title : 00:15:50.241
Chapter #0.2: start 1609.149000, end 2479.727000
title : 00:26:49.149
Chapter #0.3: start 2479.727000, end 3089.503000
title : 00:41:19.727
Chapter #0.4: start 3089.503000, end 3841.379000
title : 00:51:29.503
Chapter #0.5: start 3841.379000, end 4767.388000
title : 01:04:01.379
Chapter #0.6: start 4767.388000, end 5231.726000
title : 01:19:27.388
Chapter #0.7: start 5231.726000, end 6001.329000
title : 01:27:11.726
Chapter #0.8: start 6001.329000, end 6512.589000
title : 01:40:01.329
Chapter #0.9: start 6512.589000, end 6867.735000
title : 01:48:32.589
Stream #0:0(eng): Video: h264 (High), yuv420p, 1920x800, SAR 1:1 DAR 12:5, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
Stream #0:1(fre): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default)
Stream #0:2(eng): Audio: ac3, 48000 Hz, 5.1(side), fltp, 640 kb/s (default)
Stream #0:3(fre): Subtitle: subrip
Stream #0:4(fre): Subtitle: subrip
title : SDH
jerome
Post Wed Oct 15, 2014 3:03 pm
Do you think the NAS may be the culprit, or should I suspect the TV, or the WIFI network?
