Another PS3 stuttering topic
hotbbq
Post Thu Jan 08, 2015 2:05 pm
Before I get started I'll mention that I have read through the following:
viewtopic.php?f=11&t=15459&p=85703
viewtopic.php?f=11&t=9852&p=67030
I'm having issues with a few files stuttering (my Star Wars rips!) on my PS3, but most files work perfectly fine. Serviio is running on my Synology DS211j and the PS3 is connected via a wired connection (via a 500 Mbps powerline adapter). I've also tried connecting to the PS3 via wireless, but it didn't make any difference in the stuttering. There doesn't seem to be any issue streaming these files to my Sony Blu-Ray player via wireless. As you can see, these are MP4 files with AVC High@L4.1 video (max of 4 ReFrames) and AAC audio. I've enabled debug logging, but I am not at home at the moment to test. Any ideas?
Lot's of stuttering in sections, but most of the movie plays fine (peak bitrate ~12Mbps)
Complete name                            : V:\Star Wars\Episode III - Revenge of the Sith.mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42
File size                                : 5.06 GiB
Duration                                 : 2h 20mn
Overall bit rate                         : 5 175 Kbps
Movie name                               : Revenge of the Sith
Writing application                      : HandBrake 6681svn 2015010301
Codec ID                                 : avc1
Codec ID/Info                            : Advanced Video Coding
Duration                                 : 2h 20mn
Bit rate                                 : 4 137 Kbps
Height                                   : 832 pixels
Display aspect ratio                     : 2.35:1
Original display aspect ratio            : 2.35:1
Frame rate mode                          : Variable
Minimum frame rate                       : 23.810 fps
Maximum frame rate                       : 24.390 fps
Bits/(Pixel*Frame)                       : 0.108
Stream size                              : 4.05 GiB (80%)
Writing library                          : x264 core 142 r2479 dd79a61
Encoding settings                        : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=21.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Color range                              : Limited
Audio #1
Codec ID                                 : 40
Duration                                 : 2h 20mn
Bit rate                                 : 768 Kbps
Channel(s)_Original                      : 6 channels
Stream size                              : 770 MiB (15%)
Title                                    : Surround / Surround
Audio #2
Codec ID                                 : 40
Duration                                 : 2h 20mn
Bit rate                                 : 256 Kbps
Stream size                              : 257 MiB (5%)
Title                                    : Stereo / Stereo
Text
Format                                   : Timed Text
Muxing mode                              : sbtl
Codec ID                                 : tx3g
Duration                                 : 2h 5mn
Bit rate                                 : 47 bps
Stream size                              : 43.4 KiB (0%)
Menu
Codec ID                                 : text
Duration                                 : 2h 20mn
00:00:00.000                             : Chapter 1
00:00:23.607                             : Chapter 2
00:01:50.694                             : Chapter 3
00:08:28.216                             : Chapter 4
00:11:23.391                             : Chapter 5
00:18:33.821                             : Chapter 6
00:23:40.544                             : Chapter 7
00:27:37.781                             : Chapter 8
00:29:13.126                             : Chapter 9
00:33:18.997                             : Chapter 10
00:35:45.560                             : Chapter 11
00:36:48.206                             : Chapter 12
00:38:21.632                             : Chapter 13
00:40:17.498                             : Chapter 14
00:41:18.726                             : Chapter 15
00:42:41.267                             : Chapter 16
00:48:01.795                             : Chapter 17
00:50:20.559                             : Chapter 18
00:52:24.850                             : Chapter 19
00:53:58.151                             : Chapter 20
00:56:26.633                             : Chapter 21
01:00:56.319                             : Chapter 22
01:01:56.754                             : Chapter 23
01:05:26.214                             : Chapter 24
01:07:40.723                             : Chapter 25
01:09:07.101                             : Chapter 26
01:10:53.082                             : Chapter 27
01:15:19.389                             : Chapter 28
01:19:15.292                             : Chapter 29
01:20:37.541                             : Chapter 30
01:24:20.764                             : Chapter 31
01:27:56.729                             : Chapter 32
01:29:57.558                             : Chapter 33
01:33:40.573                             : Chapter 34
01:36:39.502                             : Chapter 35
01:38:35.576                             : Chapter 36
01:41:24.453                             : Chapter 37
01:42:57.171                             : Chapter 38
01:48:19.201                             : Chapter 39
01:50:59.653                             : Chapter 40
01:52:44.215                             : Chapter 41
01:54:22.939                             : Chapter 42
01:56:55.008                             : Chapter 43
02:02:20.917                             : Chapter 44
02:03:32.947                             : Chapter 45
02:05:19.804                             : Chapter 46
02:07:37.191                             : Chapter 47
02:08:57.146                             : Chapter 48
02:12:05.042                             : Chapter 49
02:13:47.394                             : Chapter 50
Bit rate mode                            : VBR
No stuttering...
Complete name                            : V:\Animated\Frozen.mp4
Codec ID                                 : mp42
File size                                : 2.91 GiB
Duration                                 : 1h 42mn
Overall bit rate                         : 4 072 Kbps
Movie name                               : Frozen
Codec ID                                 : avc1
Duration                                 : 1h 42mn
Bit rate                                 : 3 038 Kbps
Height                                   : 864 pixels
Display aspect ratio                     : 2.25:1
Original display aspect ratio            : 2.25:1
Bits/(Pixel*Frame)                       : 0.076
Stream size                              : 2.17 GiB (75%)
Audio #1
Codec ID                                 : 40
Duration                                 : 1h 42mn
Bit rate                                 : 768 Kbps
Stream size                              : 561 MiB (19%)
Audio #2
Codec ID                                 : 40
Duration                                 : 1h 42mn
Bit rate                                 : 256 Kbps
Stream size                              : 187 MiB (6%)
Text
Format                                   : Timed Text
Muxing mode                              : sbtl
Codec ID                                 : tx3g
Duration                                 : 1h 41mn
Bit rate                                 : 81 bps
Stream size                              : 60.1 KiB (0%)
Menu
Codec ID                                 : text
Duration                                 : 1h 42mn
00:05:59.901                             : Chapter 2
00:11:38.155                             : Chapter 3
00:19:53.901                             : Chapter 4
00:31:03.278                             : Chapter 5
00:38:39.567                             : Chapter 6
00:44:21.367                             : Chapter 7
00:50:51.590                             : Chapter 8
00:57:48.465                             : Chapter 9
01:02:57.482                             : Chapter 10
01:09:36.130                             : Chapter 11
01:13:34.952                             : Chapter 12
01:18:07.683                             : Chapter 13
01:22:33.949                             : Chapter 14
01:27:10.892                             : Chapter 15
01:32:33.548                             : Chapter 16
Bit rate mode                            : VBR
Post Thu Jan 08, 2015 3:28 pm
Re: Another PS3 stuttering topic
Stuttering could be due to container "mp4" or video track encoding issue.
I suspect Handbrake container mux issue...
With Serviio WinHelper tool, could you remux your mp4 file viewtopic.php?f=17&t=12136 ?
Remux Tab -> action : remux to same container
Then add new file to serviio library and retry with your PS3.
If issue comes from video track, you have to change video encoding setting.
