2 sony s580 1 says no playable file
rgsurplus
Post Mon Feb 09, 2015 12:30 am
I have 2 sony s580's one is used all the time and has always played all avi's and divx files
the other was not used for about 6 months ,last week we had guests over and we let them use the room the player was in.
when I went to freshen up the system it would not show the serviio server at first,, I got this fixed and other stuff,,
I can go to netflex and amazon accounts but when I open serviio it shows the folders ,then when I go to these it says
"no playable file" as I go through the diff. layout its all the same
this unit is config'd just like the one that plays all the movies
the only diff is in router (verizon fios 35-35) the one that works is set on dmz
I never had to set that up on the 2nd one and the other diff is the 2nd one was playing using serviio version 3 ***
both sonys have the latest firmware both are static ip's what am I missing :cry: :cry:
PS
serviio is the best
Post Mon Feb 09, 2015 8:05 am
Re: 2 sony s580 1 says no playable file
Check on serviio console check that same profile was selected for your devices.
rgsurplus
Post Tue Feb 10, 2015 11:24 pm
All same,, router says remote access enabled on one that works nothing on one that does not
on broken one I can't drill down into folders at all
fios router ,,don't know what settings needed to fix ,,did not need setting before
stumped :?:
Post Wed Feb 11, 2015 7:48 am
rgsurplus wrote:...I never had to set that up on the 2nd one and the other diff is the 2nd one was playing using serviio version 3 ***
Serviio supports multiple players...why did you used an old serviio version for the second one ?
rgsurplus
Post Thu Feb 12, 2015 1:27 am
I mean the last time it was used was with version 3** and version 4 0 did not work for me
the new version is a peach
