Sony kdl-42w705b - Serviio Server shows but don´t list libra
NunoDelgado
Post Sun Feb 22, 2015 11:58 am
Hi there,
I have a imac with yosemite and i'm trying to connect my bravia kdl-42w705b to reproduce my media.
The server appears on my tv , on media servers, i select it but it dosen´t list any folders.
Can anyone help?
Post Mon Feb 23, 2015 12:12 am
Re: Sony kdl-42w705b - Serviio Server shows but don´t list l
Please forgive the obvious question: have you added the necessary media folders in the console?
See this page (http://www.serviio.org/index.php?option ... ticle&id=5) in the section labeled "Adding content to Serviio's media library".
NunoDelgado
Post Mon Feb 23, 2015 7:27 am
Yes i did.
And the strange part is that when i press films on the top menu of my tv it appears a resume of the server, and it shows some of the films with covers and all, when i press to show all, it dosen´t show nothing.
Post Mon Feb 23, 2015 8:21 am
If you have a pro version or trial version, do you try with Mediabrowser ?
What are film formats?
What is the serviio version ?
Do you store media on external drive?
Could you enable detailed logging and check log file when you start a movie?
NunoDelgado
Post Mon Feb 23, 2015 6:07 pm
if you have a pro version or trial version, do you try with Mediabrowser ?
R: Trial version (14 days for free version), media browser works perfect localy.
R: I have various, MKV, MPeg, AVI
R: 1.5 mac
R: Yes it's all stored in a WD 1 Ter
015-02-23 18:08:05,865 INFO [PortMappingChecker] Running a check for external mapping of port 23424 on '89.114.155.75'
2015-02-23 18:08:06,730 INFO [PortMappingChecker] Port 23424 is open
2015-02-23 18:14:18,727 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2015-02-23 18:14:18,727 WARN [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2015-02-23 18:14:18,728 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2015-02-23 18:14:18,936 INFO [LibraryOneTimeScanner] Interrupting library scan
2015-02-23 18:14:18,936 INFO [LibraryDeltaScanner] Stopping the library delta scan
2015-02-23 18:14:18,937 INFO [PlaylistMaintainerWorker] Finished looking for playlist changes
2015-02-23 18:14:19,039 INFO [FeedUpdaterWorker] Finished looking for online resources information
2015-02-23 18:14:19,039 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Finished checking repositories status
2015-02-23 18:14:19,142 INFO [PluginCompilerThread] Finished looking for plugins
2015-02-23 18:14:19,330 INFO [PortMapper] Stopping port mapping scheduler
2015-02-23 18:14:19,350 INFO [SearchIndexer] Closing search index writer
2015-02-23 18:14:19,373 INFO [SearchIndexer] Closing search index writer
2015-02-23 18:14:19,374 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2015-02-23 18:14:19,374 INFO [WebServer] WebServer shutting down
2015-02-23 18:14:19,374 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2015-02-23 18:14:19,374 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2015-02-23 18:14:19,374 INFO [EventDispatcher] Leaving EventDispatcher
2015-02-23 18:14:19,375 INFO [DatabaseManager] Shutting down database
2015-02-23 18:14:19,930 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
Mon Feb 23 18:21:14 WET 2015:
Booting Derby version The Apache Software Foundation - Apache Derby - 10.11.1.1 - (1616546): instance a816c00e-014b-b7ab-ef21-fffff4a463b2
on database directory /Library/Application Support/Serviio/library/db with class loader sun.misc.Launcher$AppClassLoader@3f99bd52
Loaded from file:/Library/Application%20Support/Serviio/lib/derby.jar
java.vendor=Oracle Corporation
java.runtime.version=1.8.0_20-b26
user.dir=/
os.name=Mac OS X
os.arch=x86_64
os.version=10.10.2
derby.system.home=/Library/Application Support/Serviio/library
derby.stream.error.file=../log/derby.log
Database Class Loader started - derby.database.classpath=''
Post Mon Feb 23, 2015 7:37 pm
NunoDelgado wrote:if you have a pro version or trial version, do you try with Mediabrowser ?
So if it's OK with media browser that should be fine too with Sony device (your external drive has been scanned and library populated...).
Could you check on serviio console that good profile was selected for your device - should be "Sony Bravia 2013" profile (right click on profile colomn) ?
On the previous post, this is not a detailed logging. You have to restart serviio service or restart the PC for changes to be applied.(you should see some DEBUG lines).
You confirm that you can see folders on your sony device, and folder are populated with items, but when you press an item you see an animated icon on rigth top of the screen but nothing start (no video, no audio, black screen - and return to menu folders) ?
NunoDelgado
Post Mon Feb 23, 2015 10:11 pm
R: Yes, i've selected sony bravia TV 2013/2014
R: Should appear where?
I've put in file log4j.xml this:
<category name="org.serviio">
<priority value=“DEBUG”/>
</category>
where should appear the debug?
R: Do you know this model menu?
When i press Home i have 4 options on the left top corner : films, Albuns, Music or Apps. When i press Films appears 2 zones: technicolor TG784Gn an Serviio. Here appears 12 thumnails with films. I push tem and it plays the film, (no subtitles, but it start). Under this 12 thumbnail i have a more button. when i push it goes to tv media player , but it says that it's not possible to recieve list .
Post Tue Feb 24, 2015 7:48 am
</category>
OK, you have to restart serviio service or PC now. Then look at ./serviio/log/serviio.log file. You'll have detailed log with some INFO and DEBUG lines...
In fact, No, I don't have such model and never see menu.
I suppose you try Film menu like this ... check USB/Home Network
Do you try on Apps menu, do see Serviio logo (same than on top left of this forum) ?
Is there a Sony Bravia 2014 user that could help NunoDelgado here ?
