new router/modem now problems
• Page 1 of 1
Serviio worked great before my upgrade on router/modem.......... now it disconnects after about 5 mins of running right and I have to go back every 5 mins to reset everything. I tried reading the FAQs and the forums with similar problems but no answer solves my problem. Can someone help me?
Re: new router/modem now problems
Sorry, I can't help. I'm here looking for an answer myself.
I just got a new modem and now Serviio doesn't work at all. I know my computer is connecting to my Sony Media Player because the Microsoft server is working. I can navigate to folders and watch videos that are on my computer, but the Serviio icon doesn't light up. In the Serviio Console window I get a green light for the media player, but it doesn't work.
Any help would be appreciated.
UPnP enabled?
I re-installed Serviio and now it works again. I don't know what the problem was.
Now two icons for Serviio show up on my Sony Media Player menu. Only one works, but that's okay.
I suspect the problem was that the Sony is caching the old copy of Serviio - when you were having problems, its because the old copy was being referenced, which likely had the wrong IP address as that would have changed with the new router. Now that it has detected the new copy, you have two icons.
Look for a menu that item on your Sony that allows you to clear the Media server list or something like that.
• Page 1 of 1
