New Router serviio gone
fidmas
Post Sun Jul 24, 2016 7:46 pm
i just had to install a new CenturyLink Gateway. Pointed the Sony TV at it. All works fine but it doesn't see Serviio no matter what I do. Ideas please?
fidmas
Post Thu Jul 28, 2016 3:32 pm
Re: New Router serviio gone
If anyone cares, I could never get the Actiontec PK5001A to stream to any DLNA device. I found an old 2WIRE that is working fine for now.
Brian Mendes
Post Sat Jun 03, 2017 12:34 pm
I suspect that this is my problem. The modem/router is a rental unit from my service provider. The same modem that was replaced is no longer available. The replacement one is a custom job made for the provider by Hitrontech.
fidmas
Post Sat Jun 03, 2017 2:07 pm
Yes, that was a long time ago. I found others on the net who had the same problem with Actiontec routers. They disabled IGMP to solve their problem. My Centurylink Actiontec model didn't let me do that. Eventually, I convinced them to send me a Technicolor router that worked right out of the box. I gave the Actioncec to a friend and sent Centurylink back an old broken 2Wire since all the want is to get "Something" back. Don't tell anyone! :-)
