sony KDL 48W 605 B (2014) & Dolby Digital Plus E-AC3
pitalugue
Post Thu Nov 07, 2019 4:02 pm
hello
serviio is working fine with my Sony KDL48W605B but when it comes to ear files with dolby digital Plus // E-AC3 // AC3+ = NO SOUND = message on screen = can't be played.
these files are often H 264 videos
any idea please?
merci d'avance.
Post Fri Nov 08, 2019 3:46 pm
Re: sony KDL 48W 605 B (2014) & Dolby Digital Plus E-AC3
pitalugue wrote:hello
any idea please?
merci d'avance.
I am assuming you are using the Sony Bravia TV (2012) or the Sony Bravia TV (2013/14) profile. If you are using a different profile, please let me know.
That profile does have matches lines for EAC3 audio, but only for H.264 video in the MKV/AVI/FLV/WTV containers. If your videos use a different video codec or if they are in a different container, that explains the lack of playback. Please confirm the video codec and container used for any videos that don't play.
pitalugue
Post Fri Nov 08, 2019 8:54 pm
thanks for answering
i can't play ffmpeg
i don't know why
i didn't understand how to find logs in serviio that could help
sorry
this is what i found on VLC
the movie is an .mkv
flux 0
Codec h264 mpeg4 AVC (part 10) (avc1)
video
resolution 1920x1080
debit 23.976215
flux 1
codec A/52 B Audio (aka E-AC3) (eac3)
langue = francais
type audio
canaux 3F2M/LFE
freqence echantillonage 48000 Hz
bits par échantillon 32
and i checked all my other files with this combination h 264 + E ac3 = no sound for all
merci
Post Fri Nov 08, 2019 10:07 pm
OK, if you're using one of the two profiles I mentioned in the previous post, they should be transcoded into standard AC3. Check your assigned profile in the Serviio console and if it's one of the mentioned ones please change it and try playback again. If it's still not working, we'll need to enable detailed logging to see what Serviio is doing.
Users browsing this forum: Baidu [Spider] and 3 guests
