DLNA problem: playback jumps to the next video
EvSasha
Post Sun May 31, 2015 7:49 am
I have a problem with the DLNA server. From time to time when playing video on the TV LG, playback jumps to the next video.
I tried to enable and disable transcoding, tried to disable IGMP proxy on the router, tried to connect the TV on WI-FI.
Nothing helps.
I use a router Zyxel Keenetic Ultra, TV LG 47LA660V-ZA + SmartShare app, NAS Thekus n2310 + Serviio 1.4.1.2 for PPC.
I tried set debug log by this this instruction, and now my Serviio don't write log at all.
I post the last working log.
Upd.:
Configure a log, I will soon lay out. Built-in file manager messed up the configuration file for editing.
Please tell me where to find the cause of this problem. Sorry for my English.
12.24.55_serviio.log
(Filtered log) Playback jumps to the next video ~12:24:55
(485.92 KiB) Downloaded 969 times
11.47.40_serviio.log
Playback jumps to the next video ~11:47:40
(495.88 KiB) Downloaded 974 times
Normal serviio log
(255.68 KiB) Downloaded 992 times
EvSasha
Post Fri Jun 05, 2015 6:50 pm
Re: DLNA problem: playback jumps to the next video
Resolved.
The problem has been very low performance CPU (Thecus n2310). Update Plex library or other server CPU load of 95%, sometimes Plex Media Server CPU load of 99%. UPNP service also could load the processor by 99% (developers, i pay your attention to it!). When several of these events coincided case of disconnection and playback to jump to the next video file.
Serviio too hard for this CPU.
Solution.
1- disable UPNP
2- disable Plex. It is interesting that by simply disable from the menu application process remains hanging, had to be removed entirely.
3 - now i use Minidlna media server, it does not load the processor when upgrading a library of over 90%. The library is updated more quickly because it does not load covers and other media information. Media server CPU load never something more than 1-2%.
CPU utilization was looking through the "top". A mistake by losing the connection debugger log.
Return to LG
