zip wrote:Back then LG didn't work well with transcoding, that might have changed... no idea.
Do you have a
detailed log of playing the file via transcoding?
2016-01-25 00:09:19,677 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2016-01-25 00:27:25,907 WARN [IndexedDiskCache] Region [thumbnails] Disk cache not shutdown properly, shutting down now.
2016-01-25 00:27:25,911 WARN [IndexedDiskCache] Region [tokens] Disk cache not shutdown properly, shutting down now.
2016-01-25 00:27:25,911 WARN [IndexedDiskCache] Region [online_technical_metadata] Disk cache not shutdown properly, shutting down now.
2016-01-25 00:27:26,116 INFO [LibraryOneTimeScanner] Interrupting library scan
2016-01-25 00:27:26,116 INFO [LibraryDeltaScanner] Stopping the library delta scan
2016-01-25 00:27:26,118 INFO [PlaylistMaintainerWorker] Finished looking for playlist changes
2016-01-25 00:27:26,223 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Finished checking repositories status
2016-01-25 00:27:26,223 INFO [FeedUpdaterWorker] Finished looking for online resources information
2016-01-25 00:27:26,328 INFO [PluginCompilerThread] Finished looking for plugins
2016-01-25 00:27:26,435 INFO [SearchIndexer] Closing search index writer
2016-01-25 00:27:26,438 INFO [SearchIndexer] Closing search index writer
2016-01-25 00:27:26,441 INFO [WebServer] WebServer shutting down
2016-01-25 00:27:26,441 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2016-01-25 00:27:26,441 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2016-01-25 00:27:26,441 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2016-01-25 00:27:26,441 INFO [EventDispatcher] Leaving EventDispatcher
2016-01-25 00:27:26,443 INFO [DatabaseManager] Shutting down database
2016-01-25 00:27:27,130 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2016-01-25 00:28:22,135 INFO [MediaServer] ------------------------------------------------------------------------
2016-01-25 00:28:22,261 INFO [MediaServer] Serviio DLNA media streaming server v 1.6 (rev. 9a1458ed77db)
2016-01-25 00:28:22,261 INFO [MediaServer] Petr Nejedly 2009-2015
http://www.serviio.org2016-01-25 00:28:22,261 INFO [MediaServer]
2016-01-25 00:28:22,262 INFO [MediaServer] Java 1.8.0_40-Oracle Corporation x86_64
2016-01-25 00:28:22,262 INFO [MediaServer] OS Mac OS X 10.10.5
2016-01-25 00:28:22,262 INFO [MediaServer] File encoding: UTF-8
2016-01-25 00:28:22,262 INFO [MediaServer] Headless mode enabled: true
2016-01-25 00:28:22,262 INFO [MediaServer] User: root
2016-01-25 00:28:22,262 INFO [MediaServer] User home dir: /var/root
2016-01-25 00:28:22,262 INFO [MediaServer] Temp dir: /var/folders/zz/zyxvpxvq6csfxvn_n0000000000000/T/
2016-01-25 00:28:22,262 INFO [MediaServer] ------------------------------------------------------------------------
2016-01-25 00:28:22,447 INFO [WebServer] Socket buffer set to 65535 bytes
2016-01-25 00:28:22,448 INFO [RestletServer] Starting Restlet server (/console) exposed on port 23423
2016-01-25 00:28:22,457 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2016-01-25 00:28:22,564 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2016-01-25 00:28:22,565 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2016-01-25 00:28:22,605 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2016-01-25 00:28:22,614 INFO [DatabaseManager] Using DERBY database language
2016-01-25 00:28:23,605 INFO [MediaServer] ------------------------------------------------------------------------
2016-01-25 00:28:23,605 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2016-01-25 00:28:23,612 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 9 times
2016-01-25 00:28:28,617 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 8 times
2016-01-25 00:28:33,618 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 7 times
2016-01-25 00:28:38,620 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 6 times
2016-01-25 00:28:43,622 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 5 times
2016-01-25 00:28:48,623 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 4 times
2016-01-25 00:28:53,628 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 3 times
2016-01-25 00:28:58,633 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 2 times
2016-01-25 00:29:03,639 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 1 times
2016-01-25 00:29:08,642 INFO [Device] Created UPnP Device with UUID: 12486d15-079e-3f2f-932c-6be88964d93a, bound address: 127.0.0.1
2016-01-25 00:29:08,781 INFO [FileDeltaWatcher] Using 'sun.nio.fs.PollingWatchService' for delta scan
2016-01-25 00:29:09,313 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2016-01-25 00:29:09,380 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2016-01-25 00:29:09,402 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2016-01-25 00:29:09,408 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2016-01-25 00:29:09,409 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2016-01-25 00:29:09,410 INFO [ProfilesDefinitionParser] Added profile 'Playstation 4' (id=ps4)
2016-01-25 00:29:09,410 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2016-01-25 00:29:09,412 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2016-01-25 00:29:09,413 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (H-series)' (id=sam_h)
2016-01-25 00:29:09,415 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (J-series)' (id=sam_j)
2016-01-25 00:29:09,416 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (E/F-series)' (id=sam_ef)
2016-01-25 00:29:09,417 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D-series)' (id=7)
2016-01-25 00:29:09,417 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2016-01-25 00:29:09,429 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2016-01-25 00:29:09,434 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2013/14)' (id=sony2013)
2016-01-25 00:29:09,435 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx100 (2013)' (id=bdp2013)
2016-01-25 00:29:09,435 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx90 (2012)' (id=bdp2012)
2016-01-25 00:29:09,438 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010)' (id=bdp2010)
2016-01-25 00:29:09,439 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx70/SMP-N100 (2010) - US' (id=bdp2010us)
2016-01-25 00:29:09,439 INFO [ProfilesDefinitionParser] Added profile 'Sony BDP-Sx80/SMP-N200 (2011)' (id=bdp2011)
2016-01-25 00:29:09,439 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2016-01-25 00:29:09,440 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA 2012-' (id=tosh2012)
2016-01-25 00:29:09,442 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2016-01-25 00:29:09,442 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2016-01-25 00:29:09,442 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2016-01-25 00:29:09,443 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2016-01-25 00:29:09,443 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2016-01-25 00:29:09,443 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2016-01-25 00:29:09,444 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2016-01-25 00:29:09,444 INFO [ProfilesDefinitionParser] Added profile 'Philips (2010-)' (id=plps2010)
2016-01-25 00:29:09,445 INFO [ProfilesDefinitionParser] Added profile 'Philips (2009)' (id=20)
2016-01-25 00:29:09,445 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2016-01-25 00:29:09,446 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2016-01-25 00:29:09,447 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2013)' (id=viera2013)
2016-01-25 00:29:09,447 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2016-01-25 00:29:09,447 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2016-01-25 00:29:09,448 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2016-01-25 00:29:09,448 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2016-01-25 00:29:09,448 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2016-01-25 00:29:09,449 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2016-01-25 00:29:09,449 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2016-01-25 00:29:09,449 INFO [ProfilesDefinitionParser] Added profile 'Vizio TV' (id=viziotv)
2016-01-25 00:29:09,450 INFO [ProfilesDefinitionParser] Added profile 'Windows 8/RT' (id=win8metro)
2016-01-25 00:29:09,451 INFO [ProfilesDefinitionParser] Added profile 'Panasonic BD player' (id=panasonicBDT220)
2016-01-25 00:29:09,451 INFO [ProfilesDefinitionParser] Added profile 'Philips NP Streamium' (id=philips_streamium)
2016-01-25 00:29:09,451 INFO [ProfilesDefinitionParser] Added profile 'Chaneru' (id=roku)
2016-01-25 00:29:09,452 INFO [ProfilesDefinitionParser] Added profile 'Roku Media Player' (id=RokuMPApp)
2016-01-25 00:29:09,453 INFO [ProfilesDefinitionParser] Added profile 'Yamaha BD-A1020/BD-A1010' (id=YamBD)
2016-01-25 00:29:09,453 INFO [ProfilesDefinitionParser] Added profile 'Telenet Yelo TV' (id=TNDC)
2016-01-25 00:29:09,454 INFO [ProfilesDefinitionParser] Added profile 'Xbox One' (id=xbox_one)
2016-01-25 00:29:09,455 INFO [ProfilesDefinitionParser] Added profile 'Raumfeld' (id=raumfeld)
2016-01-25 00:29:09,514 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2016-01-25 00:29:09,515 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2016-01-25 00:29:09,516 INFO [ProfilesDefinitionParser] Added profile 'iOS' (id=ios)
2016-01-25 00:29:09,516 INFO [ProfilesDefinitionParser] Added profile 'HTML5' (id=html5)
2016-01-25 00:29:09,517 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Standard)' (id=serviigo_standard)
2016-01-25 00:29:09,517 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Legacy Devices)' (id=serviigo)
2016-01-25 00:29:09,518 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (HLS)' (id=serviigo_hls)
2016-01-25 00:29:09,518 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo (Google TV)' (id=serviigo_gtv)
2016-01-25 00:29:09,519 INFO [ProfilesDefinitionParser] Added profile 'Google Cast' (id=googlecast)
2016-01-25 00:29:09,519 INFO [ProfilesDefinitionParser] Added profile 'Chromecast' (id=chromecast)
2016-01-25 00:29:09,520 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2016-01-25 00:29:09,559 INFO [PluginCompilerThread] Looking for plugins at /Library/Application Support/Serviio/plugins
2016-01-25 00:29:09,560 INFO [PluginCompilerThread] Started looking for plugins
2016-01-25 00:29:09,562 INFO [UpdateChecker] Checking if a new version is available
2016-01-25 00:29:09,658 INFO [FFMPEGWrapper] Found FFmpeg: ffmpeg version 2.4.git Copyright (c) 2000-2014 the FFmpeg developers
2016-01-25 00:29:09,682 INFO [AbstractAVTranscodingDeliveryEngine] Cleaning transcode engine and its data
2016-01-25 00:29:09,710 INFO [WebServer] WebServer starting on port 8895
2016-01-25 00:29:09,714 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 9 times
2016-01-25 00:29:14,720 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 8 times
2016-01-25 00:29:19,724 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 7 times
2016-01-25 00:29:24,726 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 6 times
2016-01-25 00:29:29,730 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 5 times
2016-01-25 00:29:34,733 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 4 times
2016-01-25 00:29:39,739 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 3 times
2016-01-25 00:29:44,745 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 2 times
2016-01-25 00:29:49,750 WARN [LocalAddressResolverStrategy] Haven't found any suitable local IP address, will try again 1 times
2016-01-25 00:29:54,756 INFO [Device] Updated bound IP address of Device with UUID: 12486d15-079e-3f2f-932c-6be88964d93a, bound address: 192.168.2.227
2016-01-25 00:29:54,768 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface en1 (en1) and address 192.168.2.227, timeout = 0
2016-01-25 00:29:54,770 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2016-01-25 00:29:54,771 INFO [EventDispatcher] Starting EventDispatcher
2016-01-25 00:29:54,772 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2016-01-25 00:29:54,776 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2016-01-25 00:29:54,777 INFO [RendererSearchSender] Searching for Renderer devices
2016-01-25 00:30:20,804 INFO [FeedUpdaterWorker] Started looking for information about online resources
2016-01-25 00:30:20,804 INFO [RepositoriesStatusCoordinator$RepositoriesStatusThread] Started checking repositories status
2016-01-25 00:30:20,843 INFO [LocalLibraryManager] Starting automatic library scan
2016-01-25 00:30:48,016 INFO [LibraryDeltaScanner] Added repository '/Volumes/UPnP1/Movies' to delta scanner (POLLER)
2016-01-25 00:30:48,209 INFO [LibraryDeltaScanner] Added repository '/Volumes/UPnP1/AnimeCartoons ' to delta scanner (POLLER)
2016-01-25 00:31:50,693 INFO [LibraryDeltaScanner] Added repository '/Volumes/UPnP1/TV Series' to delta scanner (POLLER)
2016-01-25 00:31:50,698 INFO [LibraryDeltaScanner] Added repository '/Volumes/UPnP0/DONE' to delta scanner (POLLER)
2016-01-25 00:31:50,880 INFO [LibraryDeltaScanner] Added repository '/Volumes/SuziMac/Users/SuziMac/Desktop/My Documents/PICTURES/WEDDING' to delta scanner (POLLER)
2016-01-25 00:31:50,881 INFO [LibraryDeltaScanner] Starting the library delta scan
2016-01-25 00:31:51,192 INFO [PlaylistMaintainerWorker] Started looking for playlist changes
2016-01-25 00:31:51,890 WARN [MetadataExtractionCoordinator] Skipping processing metadata for an unsupported file (/Volumes/UPnP1/Movies/Showgirls 1995/Audio 2 Ch/Showgirls - 2 Channel.mp4). Message: Unknown video codec.
2016-01-25 00:32:01,497 WARN [MetadataExtractionCoordinator] Extractor ONLINE_VIDEO_SOURCES failed to connect to metadata source for file /Volumes/UPnP1/TV Series/Once/Once.Upon.A.Time.S05E01.HDTV.x264-KILLERS[eztv].mp4, will try again later: Error connecting to thetvdb.com: URL 'http://thetvdb.com/api/235C8CA4529142E9/series/83882/dvd/5/1/en.xml' returned status code '404'
2016-01-25 00:32:02,668 INFO [SearchManager] Starting up search engine
2016-01-25 00:32:03,048 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2016-01-25 00:32:04,024 INFO [MediaFileIndexer] Updated 'Once.Upon.A.Time.S05E01.HDTV.x264-KILLERS[eztv]' (/Volumes/UPnP1/TV Series/Once/Once.Upon.A.Time.S05E01.HDTV.x264-KILLERS[eztv].mp4) in Library
2016-01-25 00:32:06,874 WARN [MetadataExtractionCoordinator] Extractor ONLINE_VIDEO_SOURCES failed to connect to metadata source for file /Volumes/UPnP1/TV Series/Once/Once.Upon.A.Time.S05E02.HDTV.x264-FLEET[eztv].mp4, will try again later: Error connecting to thetvdb.com: URL 'http://thetvdb.com/api/235C8CA4529142E9/series/83882/dvd/5/2/en.xml' returned status code '404'
2016-01-25 00:32:06,948 INFO [MediaFileIndexer] Updated 'Once.Upon.A.Time.S05E02.HDTV.x264-FLEET[eztv]' (/Volumes/UPnP1/TV Series/Once/Once.Upon.A.Time.S05E02.HDTV.x264-FLEET[eztv].mp4) in Library
2016-01-25 00:32:10,200 WARN [MetadataExtractionCoordinator] Extractor ONLINE_VIDEO_SOURCES failed to connect to metadata source for file /Volumes/UPnP1/TV Series/Once/Once.Upon.A.Time.S05E03.HDTV.x264-KILLERS[eztv].mp4, will try again later: Error connecting to thetvdb.com: URL 'http://thetvdb.com/api/235C8CA4529142E9/series/83882/dvd/5/3/en.xml' returned status code '404'
2016-01-25 00:32:10,267 INFO [MediaFileIndexer] Updated 'Once.Upon.A.Time.S05E03.HDTV.x264-KILLERS[eztv]' (/Volumes/UPnP1/TV Series/Once/Once.Upon.A.Time.S05E03.HDTV.x264-KILLERS[eztv].mp4) in Library
2016-01-25 00:32:12,248 WARN [MetadataExtractionCoordinator] Extractor ONLINE_VIDEO_SOURCES failed to connect to metadata source for file /Volumes/UPnP1/TV Series/Once/Once.Upon.A.Time.S05E04.INTERNAL.HDTV.x264-BATV[eztv].mp4, will try again later: Error connecting to thetvdb.com: URL 'http://thetvdb.com/api/235C8CA4529142E9/series/83882/dvd/5/4/en.xml' returned status code '404'
2016-01-25 00:32:12,311 INFO [MediaFileIndexer] Updated 'Once.Upon.A.Time.S05E04.INTERNAL.HDTV.x264-BATV[eztv]' (/Volumes/UPnP1/TV Series/Once/Once.Upon.A.Time.S05E04.INTERNAL.HDTV.x264-BATV[eztv].mp4) in Library
2016-01-25 00:32:14,552 WARN [MetadataExtractionCoordinator] Extractor ONLINE_VIDEO_SOURCES failed to connect to metadata source for file /Volumes/UPnP1/TV Series/Once/Once.Upon.A.Time.S05E05.HDTV.x264-KILLERS[eztv].mp4, will try again later: Error connecting to thetvdb.com: URL 'http://thetvdb.com/api/235C8CA4529142E9/series/83882/dvd/5/5/en.xml' returned status code '404'
2016-01-25 00:32:14,603 INFO [MediaFileIndexer] Updated 'Once.Upon.A.Time.S05E05.HDTV.x264-KILLERS[eztv]' (/Volumes/UPnP1/TV Series/Once/Once.Upon.A.Time.S05E05.HDTV.x264-KILLERS[eztv].mp4) in Library
2016-01-25 00:32:18,395 WARN [MetadataExtractionCoordinator] Extractor ONLINE_VIDEO_SOURCES failed to connect to metadata source for file /Volumes/UPnP1/TV Series/Once/Once.Upon.A.Time.S05E06.HDTV.x264-FLEET[eztv].mp4, will try again later: Error connecting to thetvdb.com: URL 'http://thetvdb.com/api/235C8CA4529142E9/series/83882/dvd/5/6/en.xml' returned status code '404'
2016-01-25 00:32:18,473 INFO [MediaFileIndexer] Updated 'Once.Upon.A.Time.S05E06.HDTV.x264-FLEET[eztv]' (/Volumes/UPnP1/TV Series/Once/Once.Upon.A.Time.S05E06.HDTV.x264-FLEET[eztv].mp4) in Library
2016-01-25 00:32:21,468 WARN [MetadataExtractionCoordinator] Extractor ONLINE_VIDEO_SOURCES failed to connect to metadata source for file /Volumes/UPnP1/TV Series/Once/Once.Upon.A.Time.S05E07.HDTV.x264-FLEET[eztv].mp4, will try again later: Error connecting to thetvdb.com: URL 'http://thetvdb.com/api/235C8CA4529142E9/series/83882/dvd/5/7/en.xml' returned status code '404'
2016-01-25 00:32:21,566 INFO [MediaFileIndexer] Updated 'Once.Upon.A.Time.S05E07.HDTV.x264-FLEET[eztv]' (/Volumes/UPnP1/TV Series/Once/Once.Upon.A.Time.S05E07.HDTV.x264-FLEET[eztv].mp4) in Library
2016-01-25 00:32:25,560 WARN [MetadataExtractionCoordinator] Extractor ONLINE_VIDEO_SOURCES failed to connect to metadata source for file /Volumes/UPnP1/TV Series/Once/Once.Upon.a.Time.S05E08.HDTV.x264-KILLERS[eztv].mp4, will try again later: Error connecting to thetvdb.com: URL 'http://thetvdb.com/api/235C8CA4529142E9/series/83882/dvd/5/8/en.xml' returned status code '404'
2016-01-25 00:32:25,623 INFO [MediaFileIndexer] Updated 'Once.Upon.a.Time.S05E08.HDTV.x264-KILLERS[eztv]' (/Volumes/UPnP1/TV Series/Once/Once.Upon.a.Time.S05E08.HDTV.x264-KILLERS[eztv].mp4) in Library
2016-01-25 00:32:28,077 WARN [MetadataExtractionCoordinator] Extractor ONLINE_VIDEO_SOURCES failed to connect to metadata source for file /Volumes/UPnP1/TV Series/Once/Once.Upon.a.Time.S05E09.HDTV.x264-KILLERS[eztv].mp4, will try again later: Error connecting to thetvdb.com: URL 'http://thetvdb.com/api/235C8CA4529142E9/series/83882/dvd/5/9/en.xml' returned status code '404'
2016-01-25 00:32:28,123 INFO [MediaFileIndexer] Updated 'Once.Upon.a.Time.S05E09.HDTV.x264-KILLERS[eztv]' (/Volumes/UPnP1/TV Series/Once/Once.Upon.a.Time.S05E09.HDTV.x264-KILLERS[eztv].mp4) in Library
2016-01-25 00:32:30,246 WARN [MetadataExtractionCoordinator] Extractor ONLINE_VIDEO_SOURCES failed to connect to metadata source for file /Volumes/UPnP1/TV Series/Once/Once.Upon.a.Time.S05E10.HDTV.x264-KILLERS[eztv].mp4, will try again later: Error connecting to thetvdb.com: URL 'http://thetvdb.com/api/235C8CA4529142E9/series/83882/dvd/5/10/en.xml' returned status code '404'
2016-01-25 00:32:30,308 INFO [MediaFileIndexer] Updated 'Once.Upon.a.Time.S05E10.HDTV.x264-KILLERS[eztv]' (/Volumes/UPnP1/TV Series/Once/Once.Upon.a.Time.S05E10.HDTV.x264-KILLERS[eztv].mp4) in Library
2016-01-25 00:32:34,520 WARN [MetadataExtractionCoordinator] Extractor ONLINE_VIDEO_SOURCES failed to connect to metadata source for file /Volumes/UPnP1/TV Series/Once/Once.Upon.a.Time.S05E11.HDTV.x264-KILLERS[eztv].mp4, will try again later: Error connecting to thetvdb.com: URL 'http://thetvdb.com/api/235C8CA4529142E9/series/83882/dvd/5/11/en.xml' returned status code '404'
2016-01-25 00:32:34,576 INFO [MediaFileIndexer] Updated 'Once.Upon.a.Time.S05E11.HDTV.x264-KILLERS[eztv]' (/Volumes/UPnP1/TV Series/Once/Once.Upon.a.Time.S05E11.HDTV.x264-KILLERS[eztv].mp4) in Library
2016-01-25 00:51:08,930 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2016-01-25 00:54:13,345 WARN [EventDispatcher] Couldn't send event message for subscription 91d52b36-30f1-4115-ab10-0d45133c6d51, will keep trying until subscription expires
2016-01-25 00:54:13,370 WARN [EventDispatcher] Couldn't send event message for subscription fb170c3a-5ee5-4e1a-a6f0-6e56204f45f4, will keep trying until subscription expires
2016-01-25 00:56:44,211 WARN [EventDispatcher] Couldn't send event message for subscription bb913e7b-cbb3-4b84-b6e0-fb72756a5795, will keep trying until subscription expires
2016-01-25 00:57:07,363 WARN [EventDispatcher] Couldn't send event message for subscription bb913e7b-cbb3-4b84-b6e0-fb72756a5795, will keep trying until subscription expires
2016-01-25 00:57:07,366 WARN [EventDispatcher] Couldn't send event message for subscription 27421a14-53ed-44df-8041-5d1d065a6230, will keep trying until subscription expires
2016-01-25 01:04:17,632 WARN [EventDispatcher] Couldn't send event message for subscription 4f0c931f-fa3b-45b5-87bc-2fc38b5c604a, will keep trying until subscription expires
2016-01-25 01:04:17,664 WARN [EventDispatcher] Couldn't send event message for subscription 31024bfe-0eb8-4135-8af5-7c0ba9d09ffc, will keep trying until subscription expires
2016-01-25 01:11:08,412 WARN [EventDispatcher] Couldn't send event message for subscription d2095302-ba0d-4d5c-8723-5f3656462e34, will keep trying until subscription expires
2016-01-25 01:11:34,616 WARN [EventDispatcher] Couldn't send event message for subscription d2095302-ba0d-4d5c-8723-5f3656462e34, will keep trying until subscription expires
2016-01-25 01:11:34,656 WARN [EventDispatcher] Couldn't send event message for subscription d4894bca-7867-46a1-92d5-f8ca71eb74ca, will keep trying until subscription expires
2016-01-25 01:13:46,821 WARN [EventDispatcher] Couldn't send event message for subscription 1c4403fc-dbb3-4a1f-8bb7-ab8e2c074114, will keep trying until subscription expires
2016-01-25 01:14:00,548 WARN [EventDispatcher] Couldn't send event message for subscription 2046cb65-b7f5-46a7-99b5-4df3fd20aa35, will keep trying until subscription expires
2016-01-25 01:14:03,585 WARN [EventDispatcher] Couldn't send event message for subscription 2046cb65-b7f5-46a7-99b5-4df3fd20aa35, will keep trying until subscription expires
2016-01-25 01:14:03,655 WARN [EventDispatcher] Couldn't send event message for subscription 20ad1270-7f89-48cb-9edd-634d6155ea80, will keep trying until subscription expires
2016-01-25 01:34:00,845 INFO [RepositoriesStatus] Repository '/Volumes/UPnP1/Movies' is not currently available. Deferring all operations for later.
2016-01-25 01:34:00,855 INFO [RepositoriesStatus] Repository '/Volumes/UPnP1/AnimeCartoons ' is not currently available. Deferring all operations for later.
2016-01-25 01:34:00,855 INFO [RepositoriesStatus] Repository '/Volumes/UPnP1/TV Series' is not currently available. Deferring all operations for later.
2016-01-25 01:34:00,855 INFO [RepositoriesStatus] Repository '/Volumes/UPnP0/DONE' is not currently available. Deferring all operations for later.
2016-01-25 01:34:12,178 INFO [LibraryDeltaScanner] Added repository '/Volumes/UPnP1/Movies' to delta scanner (POLLER)
2016-01-25 01:34:12,344 INFO [LibraryDeltaScanner] Added repository '/Volumes/UPnP1/AnimeCartoons ' to delta scanner (POLLER)
2016-01-25 01:34:12,463 INFO [LibraryDeltaScanner] Added repository '/Volumes/UPnP1/TV Series' to delta scanner (POLLER)
2016-01-25 01:34:12,487 INFO [LibraryDeltaScanner] Added repository '/Volumes/UPnP0/DONE' to delta scanner (POLLER)
