LG 47LA6608-ZA "File Type is not supported"
gattomatto
Post Mon Mar 13, 2017 11:13 pm
I cannot reproduce Audio Files (xxx.m4a) and I get the message: "File type is not supported".
Similar behaviour with xxx.jpeg photos, but in that case the TV does not react at all.
Notice that the same TV works perfectly with TVMOBiLi if I force the transcoding (but no problem anyway on photos).
I have no problem with most of the videos.
Server is running on Mac OS 10.12.03
The log file is in attachment. I also tried to load the profile which forces transcoding (LG Android... found on this forum), but without any result.
(446.79 KiB) Downloaded 1087 times
gattomatto
Post Mon Mar 13, 2017 11:40 pm
Re: LG 47LA6608-ZA "File Type is not supported"
It works with mp3 files.
As already mentioned I tried also to use the profile indicated here: viewtopic.php?f=10&t=15978 but Im not sure this was intended to forse transcoding also for audio files.
Anyway for photos it is even more strange, since they are normal jpeg.
Return to LG
