need to restart the server
Dydyka
Post Sun Jul 01, 2018 11:09 am
Windows 10, connected via LAN. Do not connect until you restart the server. What can be done?
Post Sun Jul 01, 2018 9:25 pm
Re: need to restart the server
Can you be a little more specific about your issue? Does Serviio not appear at your player unless you've restarted the Serviio service, or do you have to reboot the computer/NAS? How are you restarting the server?
Dydyka
Post Mon Jul 02, 2018 4:53 pm
atc98092 wrote:Can you be a little more specific about your issue? Does Serviio not appear at your player unless you've restarted the Serviio service, or do you have to reboot the computer/NAS? How are you restarting the server?
I restart the server in the Serviio console, turned it off and then it works. TV LG 47LX6500
Direct connection to LAN RJ45> TV
TCP / IPv4
IP 192.168.0.1
Mask 255.255.255.0
DNS 192.168.0.1
LG TV / player does not know the status in the line, although everything works
Image 1.jpg (170.95 KiB) Viewed 18090 times
Post Mon Jul 02, 2018 11:32 pm
There's only one LG profile, so it has been correctly assigned to your TV, assuming your TV is at the IP address of 192.168.0.2.
The Stop Server button at the bottom of the page does not stop/start the Serviio process, only the DLNA server function. I think we'll need to see your Serviio log that shows the initial startup when the computer first starts. I suggest you stop the Serviio service, delete the current log, then start the service. The log will give us a clean picture of any issues at startup. It's possible that you may need to enable debug logging to capture enough detail, but let's try with just the basic log first.
You will find the log at C:\Program Files\Serviio\Log.
Dydyka
Post Wed Jul 04, 2018 4:57 pm
atc98092 wrote:There's only one LG profile, so it has been correctly assigned to your TV, assuming your TV is at the IP address of 192.168.0.2.
in the file not work at the end, in the work file at the beginning (after stopping and starting the DLNA server in the Serviio console)
work.log
(81.1 KiB) Downloaded 1222 times
not work.log
(66.94 KiB) Downloaded 1258 times
Post Wed Jul 04, 2018 6:16 pm
One thing that jumps out to me is the issue it's having with finding your network adapter. I'll have to let Zip look these over and see if anything else is suspect.
Dydyka
Post Fri Jul 13, 2018 5:39 pm
respected zip does not help? The child can not itself include because of this feature
Dydyka
Post Mon Dec 31, 2018 4:51 pm
Happy new year, THANK YOU DON'T SEE YOUR TIME TO ANSWER MY QUESTION
Return to LG
