How to get Serviio to work with LG HB405SU
madman10
Post Thu Nov 10, 2011 1:40 am
Now I got it to find Serviio but it won't show the folders I have in Serviio, also is there a way to change the way it displays the folers in the LG HB405SU. Like the Music goes in the Music folder, Movies in Movies folder, etc. Does anyone have this Home Theatre and had any success? I don't like the unit but I'm trying to help out my brother.
Any ideas would be great, it sees Serviio in the Home Link, but then I don't see them in the folder options in the Home Link. Can anyone help me out, thank You.
The Madman :D
Post Thu Nov 10, 2011 12:25 pm
Re: How to get Serviio to work with LG HB405SU
did you select the correct profile on the serviio console?
Can you post the serviio.log file.
Return to LG
