ITV1HD Satreceiver recordings don't run on LG and Philips
u0005
Post Sun Nov 20, 2011 12:53 pm
All (Free) HD Satellite recordings can be played with my LG TV and Philips TV-sets.
The only ones that are not recognized are the ITV1HD recordings.
The server is installed on a Windows 7 Desktop, the recordings were made with Kathrein UFS910HD Enigma2
I've gathered mediainfo for several free channels in a pdf document. The red ones (both ITV1 HD) are the not recognized.
On top of that I've created loggings for the non playable ITV1HD and the playable ZDFHD.
Needles to say that all recordings came from the same receiver, and are all playable on Mediaplayer and Popcornhour.
Satreceiver ZDFHD.txt
(4.6 KiB) Downloaded 863 times
Satreceiver ITV1HD.txt
(7.22 KiB) Downloaded 840 times
Satelliet.pdf
(163.17 KiB) Downloaded 842 times
Post Sun Nov 20, 2011 1:17 pm
Re: ITV1HD Satreceiver recordings don't run on LG and Philip
Could you post MediaInfo result (detail, not tab) of the same two files (previously in txt ffmpeg result)?
u0005
Post Sun Nov 20, 2011 3:30 pm
I hope you mean these files!
ITV1HD.txt
(3.58 KiB) Downloaded 858 times
ZDF HD.txt
(4.88 KiB) Downloaded 957 times
Post Mon Nov 21, 2011 5:00 pm
Thanks,
Sorry, but your media seems good.
I don't know if DRM could be implemented.
You could try with TsMuxer tools to remove extra track like sub or extra audio by remuxing the stream...
u0005
Post Fri Nov 25, 2011 8:45 pm
Sorry for the delay, I was unable to react earlier this week.
It feels strange that the file with all the extra tracks (=ZDF) is playing very good.
The one that's having troubles is ITV which happens to be the channel without extra languages etc.
And most off all ITV is the ONLY ONE (with multiple recordings) that can't be played, every other (free) HD Channel file is playable!
I've just reported this case because I discovered it during my tests and might be helpfull te get most files running with Serviio.
For myself however this is not relevant at all.
Regards
Return to LG
