LG online streams.
levitmic
Post Sat Sep 29, 2012 10:47 am
LG online streams.
Hi'
I have problem with http://212.20.40.223:1234/udp/233.7.70.229:5000
TV: LG 37LV5500
Serviio 1.0.1
C:\Program Files (x86)\Serviio\lib>ffmpeg -i http://212.20.40.223:1234/udp/233.7.70.229:5000
  configuration: --enable-static --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --enable-librtmp --extra-libs='-lrtmp -lpolarssl -lws2_32 -lwinmm' --arch=x86 --enale-runtime-cpudetect --enable-pthreads --target-os=mingw32 --cross-prefix=i686-w64-mingw32- --pkg-config=pkg-config
[h264 @ 0175FA40] non-existing PPS referenced
[h264 @ 0175FA40] non-existing PPS 0 referenced
[h264 @ 0175FA40] decode_slice_header error
[h264 @ 0175FA40] no frame!
[h264 @ 0175FA40] mmco: unref short failure
    Last message repeated 7 times
[mpegts @ 017511C0] max_analyze_duration 5000000 reached at 5016000
[mpegts @ 017511C0] Estimating duration from bitrate, this may be inaccurate
Input #0, mpegts, from 'http://212.20.40.223:1234/udp/233.7.70.229:5000':
  Duration: N/A, start: 41042.089122, bitrate: 256 kb/s
  Program 1
    Stream #0:0[0x81e]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 720x576 [SAR 12:11 DAR 15:11], 54.57 fps, 50 tbr, 90k tbn, 50 tbc
    Stream #0:1[0x81f](eng): Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16, 256 kb/s (clean effects)
In VLC, Wild Media Server it's work.
Sometimes it's work on LG TV.
Also i've problem with http://stream.shura.tv/100/ (VOD ch in russ)
serviio-edit.log
(67.16 KiB) Downloaded 906 times
levitmic
Post Wed Oct 03, 2012 2:18 pm
Re: LG online streams.
Anybody???
http://212.20.40.223:1234/udp/233.7.70.229:5000 - it's VH1 Classic, that can be played on my TV only via Wild Media Server (English version of Home Media Server)
Every time when i try to play via serviio, DLNA connection hangs (lost connection)
Post Wed Oct 03, 2012 2:50 pm
Do you have some Wild Media Server log information ?
Don't know if there were a buffer size difference.
levitmic
Post Wed Oct 03, 2012 3:20 pm
Illico wrote:Do you have some Wild Media Server log information ?
Currently i'm running HMS server (have some troubles with WMS)
HMS.rar
(45.52 KiB) Downloaded 811 times
Post Wed Oct 03, 2012 10:40 pm
levitmic wrote:Anybody???
It plays fine for me in Mediabrowser and on my Samsung.. live stream 786x576. Thanks for the link! Got any more?
Post Fri Oct 05, 2012 4:34 pm
Might be due to the fact that some LG models are having problems with trasncoding and Serviio.
Return to LG
